OfficerTJHooka
a few days ago my laptop started to act weird. Programs would be slow to start up and i would get not responding errors on most programs for a few seconds and then the program would run normally but whenever i click on something in the program or do anything else it would not respond for a few seconds and go back to normal. It even hangs when i try to exit the program it would just sit there for a few seconds then it would finally close out. For example, In Firefox whenever i would click on a link or open a new tab/page it would freeze for a couple of seconds and then go back to normal. Scrolling up and down on pages would freeze it and pressing icons. This is happening in Windows Explorer also. I will attempt to open a folder or access a drive and i will get the blue spinning wheel for a couple of seconds then I would be able to access the folder or drive. I use to be able to access things instantly and open and close programs with ease. This has not happened before and i was wondering if i could get some help.
Things i have tried: Clean Installation, Full system scan on Norton, CCCleaner, Defragmenting the HD. Installing the Latest Drivers, Looking at Event Logger, Looking at Task Manager, Clean Boot, Safe Mode. None of these things worked.
My Laptop: Hp Pavilion g7-1070us, Intel core i3 at 2.53ghz, 4gb ram, Intel HD graphics 3000.
All i do is browse the web, watch video's and run basic applications.
EDIT: Ok now it seems that these problems appear to have gone away. But i still have the issue of Clicking on any links or anything in Firefox and it will stop responding and go back to normal in about 2-3 seconds or it will be very slow. This usually happens when im typing, the browser will freeze and i wont be able to type for a few seconds then it will revert back to normal. The same will happen in any other program. If i click on anything in the program it will stop responding for a second and revert back to normal. This only happens sometimes now. Same with Video Playback. If i try to go to some point in the video/movie it will freeze and take about 1-5 seconds to get to the point i specified it to go to. Those are the only issues im having problems with now.
It sounds like you've been experiencing some performance issues with your HP Pavilion g7-1070us laptop, particularly with program responsiveness and slow behavior in Firefox and other applications. I'm glad to hear that some of the issues have resolved, but you're still facing lingering problems with freezes and slow response times in specific scenarios. Given that you've already tried various troubleshooting steps without success, here are some further suggestions that may help improve the performance of your laptop and address the remaining issues: 1. Browser Optimization: - Clear Browser Cache: Clear the cache, cookies, and browsing history in Firefox to improve its performance. - Disable Add-ons: Some Firefox...
It sounds like you've been experiencing some performance issues with your HP Pavilion g7-1070us laptop, particularly with program responsiveness and slow behavior in Firefox and other applications. I'm glad to hear that some of the issues have resolved, but you're still facing lingering problems with freezes and slow response times in specific scenarios. Given that you've already tried various troubleshooting steps without success, here are some further suggestions that may help improve the performance of your laptop and address the remaining issues: 1. Browser Optimization: - Clear Browser Cache: Clear the cache, cookies, and browsing history in Firefox to improve its performance. - Disable Add-ons: Some Firefox extensions might cause performance issues. Try disabling add-ons to see if it helps. 2. System Maintenance: - Check for Malware: Run a full system scan with another reputable antivirus tool like Malwarebytes to ensure your system is free from malware. - Check for Unwanted Programs: Use tools like "Autoruns" to check for unnecessary startup programs that could be impacting performance. 3. System Performance: - Virtual Memory: Check your virtual memory settings. Ensure that the page file size is managed by the system for optimal performance. - Resource Monitor: Monitor the performance tab in Task Manager or use Resource Monitor to identify any resource-intensive programs. 4. Hardware Considerations: - Check Temperature: Overheating can lead to performance issues. Make sure your laptop is adequately ventilated and not overheating. - RAM Upgrade: Consider upgrading your RAM from 4GB to 8GB if possible, as it can significantly improve multitasking performance. 5. Software Updates: - Driver Updates: Ensure all your drivers are up to date, including graphics and chipset drivers. - Windows Updates: Make sure your Windows OS is up to date with the latest updates and patches. 6. Browser Settings: - Hardware Acceleration: In Firefox, try disabling hardware acceleration from the browser settings to see if it improves performance. By addressing these points, you may be able to further optimize the performance of your laptop and reduce the occurrence of freezes and slow response times in Firefox and other applications. If the issue persists, you may want to consider seeking help from a professional technician for a more in-depth analysis of the problem.
