The thread revolves around a user's inquiry about customizing the Windows Holographic shell, including adjusting tiles and adding new ones, similar to the Windows 10 Start Menu. The original poster clarifies they seek a programmable, OEM-level solution during manufacturing, not manual customization. Responses from another user offer general guidance but acknowledge that the specific technical needs exceed their knowledge, indicating that such customization may require advanced or specialized development. Overall, the discussion highlights a desire for deeper customization capabilities for the Holographic shell.
johnnylq
How to customize the holographic shell just like customize Win10 Start Menu? How to adjust the Tile's sequence and size? How to add new Tile ? ...
Is there or will there be any spec or guidance for holographic shell customization?
MikeHawthorne
Hi
I'm not sure that this is what you are talking about but you can look at this....
Mike
johnnylq
Thread Author #3
Hi
Mike
Mike, Thanks for your reply.
What I want is the programmable solution to OEM customize the holo shell during manufacture. Not operating holo shell manually.
MikeHawthorne
Hi
Well I'll have to admit that you are at over my head on this.
This is out of my area. LOL
Mike
