Xtine Geater
after i installed win 7
This pops out . Can someone help?
I would recommend that you run CHKDSK - start Windows, click Start button, and type chkdsk at the bottom + click "run the typed command". It will fix most problems.
The notification you receive most probably indicates a real problem. If you have a new computer / new disk, with warranty, I suggest you take it to the seller.
Best wishes.
Saltgrass
Do you need help backing up your system, or dealing with the message?
Windows 7 has utilities that checks and repairs the hard drive all the time. Whether it is getting a Smart type of error or some error its utilities are creating, not really sure.
I think I would back up my data to start with, then deal with the hard drive problem.
Having an image backup is always a good idea, if you don't already. Then if the drive does fail, you can just re-image your system.
Pauli
Fantastic Member
Best wishes.
Xtine Geater
Link RemovedLink Removed
it says thAT D that doesn't have a problem but I don't trust this / :)
