The original poster is experiencing difficulty connecting their Microsoft Wireless Display Adapter to a Vizio HDTV, despite multiple troubleshooting efforts like resetting the device and updating Windows. Several replies suggest checking for TV firmware updates or alternative setup methods, but the original poster is unsure if the adapter can be used with a non-smart TV, ultimately questioning the compatibility and usage options for their setup. Overall, the thread highlights challenges with wireless display connectivity on a non-smart TV and seeks guidance on proper configuration.
Gengo
Greetings,
I have recently bought Microsoft Wireless Display Adapter and am unable to sync it with my hdtv. I plugged in the adapter and powered it through a USB extension but when I add a wireless display, it says "No devices found". My computer is unable to pair with the display adapter and it is very troublesome.
Methods I have tested:
Resetting the display adapter
Scanning multiple times
Turning off the firewall
Updating Windows 8
I downloaded the MWDA's app and it will not activate until connected so it is useless for now. Am I missing something? Do I need to download drivers for the adapter? Also, I think it is important to note the computer did scan some phones nearby so that confirms it is not broken.
Any advice would be appreciated!
Jimbo22
Make/model of adapter? Are there any special required for your HDTV for such an adapter? Is there a firmware update for your HDTV, if it's a smart TV?
Gengo
Thread Author #3
Make/model of adapter: Model number is 1628
There is nothing special required for my hdtv that I know of.
No updates required because it is not a smart tv.
Gengo
Thread Author #5
Vizio is the brand of my television.
Edit: Clarification -> Vizio VX32L HDTV10A
ussnorway
Windows Forum Team
I would sugest setting it up by cable first... There is nothing about wireless useage in the user manual = Link Removed
Gengo
Thread Author #7
Yes, the television does connect with the computer via hdmi. I suppose I cannot use the adapter on the television then?
