The thread discusses issues with activating battery level notifications on Windows 8, where the original poster is unable to receive alerts when the battery reaches a certain percentage. Contributors suggest that notification behavior may be influenced by proprietary manufacturer software, which could override Windows settings. The overall sentiment indicates that hardware-specific software might be responsible for the lack of notifications, and consulting the laptop's support is recommended for further assistance.
windowsguy88
How do I activate battery notifications for Windows 8 when the battery reaches a certain level? I did go to Power Options and then to Advanced Settings. I could not find the option to do this. Anyone know?
Doubtful, but possible, it's probably some proprietary software on your laptop from manufacturer. That when it reaches it's threshold it just turns off. Although, ussnorway suggested fix should have worked and I don't know why it didn't. What's the make/model of your laptop? You could put a support ticket into your laptops tech support and find out what they recommend.
ussnorway
Windows Forum Team
Battery settings are on the bottom and has three parts: example;
An image from 'No battery notification'. Windows Power Options settings showing battery levels and notifications customization.
low batty notify = on,
low batty level = 10%
low batty action = hiberate.
windowsguy88
Thread Author #3
I have done that. My computer just shuts off when my
I have that set. However, my laptop still shuts off with out notification when I am using the battery as a power source.
Jimbo22
I think that is dependent on the proprietary software of the laptop itself, if the manufacture even has one. With windows 8/8.1, by default it's set at 10% and for my Samsung RV511 of 3.5 years, it works perfectly fine in my windows 8.1Pro 64 bit. Unplug from batter and at 10% power left, the warning pops up.
windowsguy88
Thread Author #5
My battery notification does not work. Is there something wrong with the OS?
Jimbo22
