Hi all,
I have to admit I have a problem I caused myself. I installed Ubuntu 14.04 on my computer next to a Windows XP/7 installation. I had to install XP before I could install W7 on this system although it is a full version of W7, so no upgrade version.
What happened?
I had a running system with W7 installed. I installed Ubuntu 14.04 in a dual boot setup. I wanted to change the Linux install to another distro, because I could not change Ubuntu as I wanted. I saw some youtube-movies, where it is showed dead simple to change grub and remove Ubuntu. I followed this, but Grub did not change. I tried another movie, in which the install disc of W7 is used to repair in dos with the commands bootrec /fixboot and bootrec /fixmbr. Using the /fixboot command I got an error message I unfortunately can't recall.
Ahter this I wanted to restart the system and got the message "No Operating System found".
I hope you can help me getting this computer back to live, as I need it every day.
If you need extra information, please ask, because I'm helpless in this 🙁
What happened?
