Running Windows 10 home with all updates applied on HP Laptop
On a reboot I have to go into services and manually start WLANSVC (WLAN AutoConfig) before I can get my wireless NIC to connect to my wireless network.
I also have to manually start Windows Audio before my audio system on the laptop will work.
These two services are both suppose to start automatically but after a reboot they do not start until I go into services and start them manually.
This seems to have started since the last update to windows. I am curious if anyone else is having this issue and if there is a way to fix it?
Any and all help is appreciated.
Two screen shots show before I start WLANSVC (right after the reboot) and after I start WLANSVC.
Microsoft Defender: No threats detected Scan detailsWLANSVC001.webp154.6 KB · Views: 196 -
Microsoft Defender: No threats detected Scan detailsWLANSVC002.webp154.6 KB · Views: 192
