The user questions whether it's possible to run Windows 10 and Linux concurrently with a simple hotkey switch at startup. The responder clarifies that this isn't feasible natively, but virtual machine solutions could approximate this setup with additional infrastructure. The user acknowledges the explanation and considers the issue resolved. The overall sentiment indicates a clarification of technical capabilities regarding dual-booting versus virtualization.
alesyt0h
Hello! I didn't found any other section to post this and I'm running windows 10 on my PC so..
I'm wondering if is this possible!
For example 1 partition with windows 10, another one with linux. I start my computer and both systems will run, windows 10 as default system and with a simple hotkey, I change my screen to the linux system.
I am dreaming?
That isn't possible. The closest you will get is running VM Workstation which can run a physical disk as a VM or Citrix XenDesktop, but that requires some infrastructure behind it to work.
Neemobeer
Windows Forum Team
