The original poster reports that their HP LaserJet Pro MFP M26NW printer is not appearing in their device list despite driver installation. In response, ChatGPT provides a detailed troubleshooting guide, including checking connections, running the printer troubleshooter, restarting the print spooler, reinstalling drivers, adding the printer manually, and consulting HP support resources. The overall sentiment is helpful and instructional, aiming to assist users in resolving common connectivity issues with their printer.
finanderson
Hello, all I have HP LaserJet Pro MFP M26NW I have installed the drivers but unfortunately, the device is not showing up in the devices. What will be the issue I am not able to get a clue...
If your HP LaserJet Pro MFP M26nw printer is not showing up in the devices list on your computer despite installing the drivers, here are a few steps you can take to troubleshoot the issue: 1. Check Connections: - Ensure that the printer is properly connected to your computer via a USB cable or a network connection. - Verify that the printer is turned on and in a ready state. 2. Run Printer Troubleshooter: - Go to Settings > Update & Security > Troubleshoot. - Run the Printer troubleshooter to detect and fix common printer problems automatically. 3. Restart Print Spooler: - Press Win + R, type services.msc, and press Enter. - Locate the Print Spooler service, right-click, and select Restart. 4...
If your HP LaserJet Pro MFP M26nw printer is not showing up in the devices list on your computer despite installing the drivers, here are a few steps you can take to troubleshoot the issue: 1. Check Connections: - Ensure that the printer is properly connected to your computer via a USB cable or a network connection. - Verify that the printer is turned on and in a ready state. 2. Run Printer Troubleshooter: - Go to Settings > Update & Security > Troubleshoot. - Run the Printer troubleshooter to detect and fix common printer problems automatically. 3. Restart Print Spooler: - Press Win + R, type services.msc, and press Enter. - Locate the Print Spooler service, right-click, and select Restart. 4. Reinstall Printer Drivers: - Uninstall the current printer drivers from your computer. - Download the latest drivers from the HP website and install them following the on-screen instructions. 5. Add Printer Manually: - Go to Settings > Devices > Printers & scanners. - Click on "Add a printer or scanner" and follow the on-screen prompts to detect your printer. 6. Printer Support: - Visit the https://support.hp.com/ website for your specific printer model. - Search for troubleshooting guides, manuals, and drivers tailored to resolve common printer setup issues. 7. Firmware Updates: - Check if there are any firmware updates available for your printer on the HP support website. - Updating the printer's firmware can sometimes resolve connectivity issues. If these steps do not resolve the issue, you may also consider checking the physical connections, trying a different USB port or cable, and verifying that the printer is compatible with your operating system. Additionally, contacting HP Support directly can provide more tailored assistance for your specific printer model and configuration.
