The thread discusses a recurring static issue with speakers during long video or voice chats on a Dell Inspiron 15 3552, caused by Realtek audio drivers. The original poster has attempted driver updates and sound service restarts without success, noting that only restarting the PC temporarily resolves the problem. A suggested solution involves switching to the Windows generic sound driver via Device Manager, which the user considers a better alternative to Realtek drivers. The overall sentiment indicates frustration with Realtek drivers and hope that using the generic driver will fix the static issue.
NerferMC
Well-Known Member
It occurs every time when having a video chat on google meet or voice chat on discord after 30-45 mins. Speakers turn into static. Even windows sounds are static. I have done sound service restart but it did not work. Only works every time I restart my PC which is very annoying for online classes.
I can't post an attachment here because it contains private info.
I have done a driver update but it gives my speaker static sounds all the times. (Realtek audio)
Device: Dell Inspiron 15 3552, Windows 10 2004 19041
You can try using the Windows generic sound driver instead..
Open the Device Manager (type devmgmt.msc in Windows search box).
Expand the "Sound, video & game controllers" and right click on "Realtek High Definition Audio".
Select to "Update Driver Software".
Click on "Browse my computer for driver software".
Click "Let me pick from a list of drivers on my computer".
Put a check in the box "Show compatible hardware" if not already checked.
In the list of devices, click "High Definition Audio" (the native driver).
Click "Next".
On the Update Driver Warning box (if there is one), click "Yes" (install the driver).
Restart the laptop if prompted. If not prompted, then no need to restart.
Josephur
Windows Forum Admin
Click "Next".
NerferMC
Well-Known Member
Thread Author #3
Click "Next".
Mine currently has "High Definition Audio Device". Realtek Audio brings more problems
