cherrio
Does anyone know why this audio driver produces such a difference in audio level when booting between Win XP and Win7? In Win7 I am using Analog Devices driver version 6.10.1.6585 and I can barley hear an IM voice, a Video playback, or when editing video in Pinnacle Studio 14. I have adjusted the level to the top in the speaker level panel. Then if I go back to Win XP when the bootup occurs the Win XP splash screen audio just about knocks me off the chair if I forget to turn the powered speaker system down with the desktop volume control.
Although the onboard integrated sound system is working OK, this is certainly an anoying problem that I would like to know how to adjust so both Windows operating systems produced comparable sound levels out to the powered speaker system.
The difference in audio levels between Windows XP and Windows 7 when using the Analog Devices driver version 6.10.1.6585 can be attributed to various factors, including differences in audio processing, driver configurations, and system settings between the two operating systems. Here are some steps you can take to address the issue and ensure comparable sound levels between Windows XP and Windows 7:
Adjust Volume Levels:​
  • Windows Volume Mixer: Ensure that the volume levels are consistent in the Windows Volume Mixer for both operating systems.
  • Speaker Levels: Adjust the speaker levels in both Windows XP and Windows 7 to ensure they match or are at a comfortable level.
Driver Configuration:​
  • Driver Settings: Check the audio driver settings in both Windows XP and Windows 7. Make sure that the settings are configured similarly in both operating systems.
  • Driver Updates: Check for any updates to the Analog Devices driver that may address audio level inconsistencies.
System Settings:​
  • Sound Settings: Compare sound settings in both operating systems and ensure that they are set to produce similar audio output levels.
  • Compatibility Mode: If applicable, try running the audio driver in compatibility mode in both Windows XP and Windows 7.
Additional Tips:​
  • Speaker Calibration: Calibrate your speakers to ensure that they are producing sound at the desired levels.
  • Audio Enhancements: Check for any audio enhancements or effects that might be affecting the audio output levels. By adjusting these settings and ensuring consistency in configurations between Windows XP and Windows 7, you should be able to achieve comparable sound levels on your powered speaker system when switching between the two operating systems.
