The thread discusses issues with Amazon Prime video playback causing static or visual artifacts, especially on Windows 10 and Linux systems. The original poster experiences static blips on their TV when streaming Prime videos and resolves the problem temporarily by installing VLC for better codec support. A subsequent user suggests that display or driver issues might be at fault, advising to check drivers, and notes that poor display quality could also be an external monitor problem rather than a software issue. The overall tone indicates troubleshooting efforts with no definitive permanent solution provided.
anotherwindowsuser
Well-Known Member
OK so I normally use Linux as an operating system which I usually use to watch Amazon Prime videos on. I have just reinstalled it on my SSD with a newer version of Linux and have had issues this evening running Amazon Prime video owing I presume to codecs and the dreaded annoyance of DRM (which never stopped piracy anyway) and so this evening I went to watch an episode of a TV show on Prime on my windows installation and it has this strange blip of static on a regular basis. Its like the white bubbles static you used to see on old CRT TVs For anyone under the age of 20 reading this, you'll have to Google that.. BTW something like 1% of that is echo from the Big Bang. Anyway, when I play video from Prim it causes this strange blip of burst of white bubbles on my HDMY connected TV, it does happen with no programmes open or on watching YouTube, it only happens when Amazon Prime is setup to show a video. It even happens when the video is on pause and happens on multiple videos. There are virtually no technical settings for display settings on windows 10 so am not sure what to do. It has happened in Edge and Chrome. During the time I wrote this message it has not happened once and if I were watching Prime it would have happened several times. Any advice welcome, thanks.
GraceGraham
I have never encountered anything like this, but I have never used Amazon Prime on Linux because it is an operating system created for programmers, so this OS is not particularly user-friendly. It is recommended to use Windows or Mac for normal user purposes. But even if you have problems with Amazon Prime, even when you have reinstalled the OS on Windows, then the problem is in your screen. Check the drivers and so on. I recently participated in the amazon gift card giveaway, won $100, and bought a cheap monitor that showed a terrible image on Amazon Prime.
