The forum discussion revolves around the use of BitLocker to encrypt USB drives. The original poster asks how to access a BitLocker-protected drive on Windows XP, but a contributor clarifies that BitLocker is not compatible with XP and suggests alternative encryption tools that work across different Windows versions. The overall sentiment is helpful, providing practical solutions for encrypting USB drives in environments with varying Windows OS versions.
Daniel Mendel
Hello people, I want to know something about the BitLocker protection system:
If I use it to protect my USB pendrive, how can I use it on a Windows XP system for example? How it'll ask me the password?
I want to lock my pendrive because I have important data on it and my school computer has lots of viruses and some people might want to get my pendrive and see what's in there.
Thanks in advance.
Mitchell_A
Former Moderator
Hello, welcome to Windows 7 Forums :)
Unfortunately, there's no way to make Bitlocker compatible with Windows XP (it was a feature first integrated with Vista).
There is thousands of alternative applications which have cross OS compatibility..
For basic password drive encryption, I have used this app Download Perfect Lock Beta Free - Keep your personal data into password protected drive - Softpedia
and can confirm it "gets the job done" and is compatible with all version of Windows.
Daniel Mendel
Thread Author #3
[langtitle=pt]Re: Use a BitLocker protected device on an non-W7 system[/langtitle]
[lang=pt][QUOTE = Mitchell_A; 180342] Olá, bem-vindo ao Windows 7 Fóruns:) Infelizmente, não há nenhuma maneira de fazer Bitlocker compatível com o Windows XP (que era um primeiro recurso integrado com o Vista) compatibilidade. Há milhares de alternativas de aplicações que OS cruz se .. Para criptografia de senha da unidade de base, eu usei este app] [url = http://www.softpedia.com/get/Security/Encrypting/Perfect-Lock.shtml Download Perfect Lock Beta Livre - Mantenha os seus dados pessoais em senha unidade protegida - Softpedia [/ url] e pode confirmá-lo "começa o trabalho feito" e é compatível com todas as versões do Windows]. [/ QUOTE
Thanks for the reply. I'll try this software.[/lang]
Mitchell_A
Former Moderator
Re: [langtitle=pt]Re: Use a BitLocker protected device on an non-W7 system[/langtitle]
No problem, please post back with your results.:)
Nice to see someone my age on the forum, too .
