The thread discusses a Windows 7 user experiencing issues with blank Windows Features screen, difficulties installing and updating Visual Studio 2008 SPI 64-bit, and security errors preventing commands like sfc /scannow from running. The original poster seeks assistance, while respondents suggest clarifying product names and check for specific error messages, with one pointing to a Microsoft support thread for troubleshooting. Overall, the discussion highlights troubleshooting challenges related to software installation and system errors, with no definitive resolution provided.
3doz
windows features are showing blank screen
cant install viguale 2008 spi64
cant update from the original install disc
windows however does update when log on
the fix Kb947821 has no change to this problem
any suggestions
Pauli
Fantastic Member
viguale 2008 spi64 cannot be found. You mean visual 2008 spi 64? Language issue, I presume?
3doz
Thread Author #4
more typo but thats not trying to give a solution is it
add sfc /scannow will not work some error security problem
