bumblebee
hi all im new to this forum i need help with setting up a home group i have just got a new router tp-link TD-W8901G im running windows premium 7 on a lap top and a shop built pc i cannot create a home group i have followerd all in structions i can find on the internet etc and nothing happens please can some one tell me where im going wrong :(
Setting up a Homegroup on Windows 7 should be a straightforward process, but sometimes there can be issues that prevent it from working correctly. Here are some steps you can take to troubleshoot and hopefully resolve the issue:
Troubleshooting Steps for Setting Up a Homegroup:​
  • Check Network Discovery and Sharing Settings:
  • Ensure that network discovery and file sharing are turned on for both computers. You can do this by going to Control Panel > Network and Sharing Center > Change advanced sharing settings. [*Set Network Location:
  • Make sure that the network location is set to Home or Work, not Public. This setting can impact Homegroup functionality. [*Create a New Homegroup:
  • Try creating a new...
  • Try creating a new Homegroup on one of the computers instead of joining an existing one. This can sometimes resolve issues with the existing setup. [*IPv6 Configuration:
  • Homegroup requires IPv6 to be enabled. Check if IPv6 is enabled on both computers. [*Ensure Homegroup Services are Running:
  • Check if the necessary services for Homegroup are running. You can do this by typing "services.msc" in the Start menu search box and ensuring that the following services are running:
  • HomeGroup Listener
  • HomeGroup Provider [*Firewall and Antivirus Settings:
  • Sometimes, firewall or antivirus software can block Homegroup functionality. Try temporarily disabling them to see if it resolves the issue. [*Restart Homegroup Troubleshooter:
  • Run the Homegroup troubleshooter to identify and possibly fix any issues automatically.
  • Go to Control Panel > Troubleshooting > Network and Internet > HomeGroup. [*Network Reset:
  • If all else fails, you can try resetting the network settings on both computers.
  • Open Command Prompt as an administrator and run the command: netsh int ip reset resetlog.txt
Additional Resources:​
[*Microsoft has a detailed guide on setting up a Homegroup on Windows 7: https://support.microsoft.com/en-us...kthrough-3f3a91c1-50e2-3876-57f8-e6c4eeb0c926 Try these steps and see if they help in resolving the issue with setting up your Homegroup. If you encounter any specific errors or issues during these steps, feel free to provide more details for further assistance.
