SuperFlyBoy
I have a Toshiba M750 TabletPC running Win7 Pro 64-bit.
Never had a problem until a few days ago, possibly until I installed SpiderOak's latest version, 9810. (SpiderOak is a backup/sharing software similar to Dropbox)
I'm using IPv4 with the following settings:
Fixed IP of 192.168.200.192
Subnet: 255.255.255.0
Gateway: 192.168.200.100
DNS1: 192.168.200.144 (our SBS2003 server's IP)
DNS2: 208.67.220.220 (OpenDNS)
After I have used the computer for a day or two, IE and FF stop being able to browse, period.
This is both on a home network, as well as when using Wi-Fi networks out of the house. Haven't used the laptop in the office so far.
I have tracerouted sites, which I am able to do successfully when not able to browse.
SpiderOak is not running, but possibly any modifications to the OS/networking might have changed things. However, this could also not be a result of SpiderOak, but rather Windows Updates as well...
Other computers on the network (home) are able to browse the internet.
In this condition, I am only able to browse the net and get e-mail (Outlook) when I log into a VPN connection, and then it works fine.
This occured when I was docked in the docking station, after about 14 hours of using in the DS. Prior to the 14 hours of use in the DS, the unit was docked/undocked multiple times, including sleeping/waking multiple times.
I have tried putting in DNS1 as the gateway IP, like all the other machines have, but the laptop cannot browse or get e-mail access - no idea why.
I have tried disabling the LAN connection in Win7 and then restarting it, but this has no effect.
Any feedback is appreciated.
Edited to Add: No updates of LAN connection/drivers have been installed either.
Edited to Add 2: However, a complete OS/machine restart solves the problem and Win7 behaves normally.
Edited to Add 3: I did nothing to the computer and SUDDENLY the machine starts being able to browse and receive e-mails!! What could be going on??
Posting my ipconfig details:
Windows IP Configuration
Host Name . . . . . . . . . . . . : M750
Primary Dns Suffix . . . . . . . : xxxx.local
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : xxxx.local
Ethernet adapter Local Area Connection 15:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TAP-Win32 Adapter V9
Physical Address. . . . . . . . . : xx-xx-xx-xx-xx-xx
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Mobile Broadband adapter Mobile Broadband Connection:
Description . . . . . . . . . . . : TOSHIBA F3507g Mobile Broadband Network A
dapter
Wireless LAN adapter Wireless Network Connection 2:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Ethernet adapter Local Area Connection 3:
Description . . . . . . . . . . . : Fortinet virtual adapter
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel(R) 82567LM Gigabit Network Connecti
on
DHCP Enabled. . . . . . . . . . . : No
IPv4 Address. . . . . . . . . . . : 192.168.200.192(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.200.100
DNS Servers . . . . . . . . . . . : 192.168.200.144
208.67.220.220
NetBIOS over Tcpip. . . . . . . . : Enabled
SuperFlyBoy
Man, this is a heavily-modded forum - received like 7 PM's from a mod telling me that this was approved - and they keep coming!
(First the post disappears...now magically appears again - I thought I lost it. (the post - that is! :p))
msfanboy98
Sorry for not reading that bit. I recommend you do a system restore to a date when your internet was working on that pc.
