abhijeetiim
Hi
My bsnl wimax connection has stopped working on my laptop...IT WORKS ON MY FREINDS' LAPTOP
On my laptop (windows 7), in the taskbar, it shows connected and everything seems fine but i cant access any sites or download anything
Does this have to do with a bluetooth device i installed a few days back or some other issue...plz guide me
patcooke
Microsoft MVP
Microsoft MVP
Doubt if the bluetooth install has had any effect. Goto a command prompt and enter the commend:
ipconfig /all
to examine your IP configuration. If you need any help inetrpreting it please post the output here.
patcooke
Microsoft MVP
Microsoft MVP
None of those adapters is showing any connection - there must be more further down which you have not shown.
abhijeetiim
Windows IP Configuration
Host Name . . . . . . . . . . . . : EMPERORS-EMPIRE
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : C2-17-FE-9E-88-22
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR5B93 Wireless Network Adapter
Physical Address. . . . . . . . . : C4-17-FE-9E-88-22
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 20-6A-8A-62-33-DD
Link-local IPv6 Address . . . . . : fe80::45a9:d5c7:d471:750%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.51(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 10 February 2013 20:03:02
Lease Expires . . . . . . . . . . : 10 February 2013 21:03:01
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 169896586
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-6B-8B-F3-20-6A-8A-62-33-DD
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{079E895E-A34A-44CA-AB30-B5385D4D0B79}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter Reusable Microsoft 6To4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:2463:119b:8a0c:4ece(Preferred)
Link-local IPv6 Address . . . . . : fe80::2463:119b:8a0c:4ece%15(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{3B7EE1CC-A539-4694-9B23-6D97C1B5FB80}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter isatap.{FFC5FCDF-4747-4712-BF6B-9F99DAAC4582}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
patcooke
Microsoft MVP
Microsoft MVP
I assume that it is the wireless connectio0n you are having problems with. It is not showing as connecting at all. Try going to device manager in control panel, network adapters, removing the device by right clicking on the wireless adapter and selecting uninstall. Reboot and see if Windows picks the adapter up and reinstalls for you.
abhijeetiim
sir, i am not using a wireless connection....its wimax(with wire)...also if i uninstall the adapter can i install it again....plz pardon me for this silly question...i need to be doubly sure...thats all... thx...waiting for ur reply
patcooke
Microsoft MVP
Microsoft MVP
Ok - try removing the wired adapter from your device manager - when you reboot Windows will pick up ont e device and reinstall it.
abhijeetiim
i uninstalled both the wired and wireless adapters and reinstalled on system reboot but still net is not working...the network icon shows my laptop is connected but i cant open any sites, cant access my modem through 192.168.1.1 but when i use utorrent i can connect to seeds/leeches but speed is below 1 kbps...i have set my ip address as auto set and my connection works perfectly fine on my friend's laptop...kindly advise
patcooke
Microsoft MVP
Microsoft MVP
You may have a firewall blocking access - do you have or have you previously had a firewall running on your pc?
patcooke
Microsoft MVP
Microsoft MVP
Try temporarily disabling them all. You should in any case have only one running at a time - more than one can cause conflicts.
abhijeetiim
i also tried to ping google and 8.8.8.8. the results are below
C:\Windows\system32>ping Google
Pinging Google [74.125.235.63] with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 74.125.235.63: bytes=32 time=174ms TTL=52
Reply from 74.125.235.63: bytes=32 time=185ms TTL=52
Ping statistics for 74.125.235.63:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 174ms, Maximum = 185ms, Average = 179ms
C:\Windows\system32>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=173ms TTL=54
Request timed out.
Reply from 8.8.8.8: bytes=32 time=118ms TTL=54
Reply from 8.8.8.8: bytes=32 time=180ms TTL=54
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 118ms, Maximum = 180ms, Average = 157ms
abhijeetiim
C:\Windows\system32>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Request timed out.
Ping statistics for 192.168.1.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Windows\system32>nslookup google.com
Server: WiMaxCPE
Address: 192.168.1.1
DNS request timed out.
timeout was 2 seconds.
Address: 2404:6800:4009:800::1007
Reply from 8.8.8.8: bytes=32 time=120ms TTL=54
Reply from 8.8.8.8: bytes=32 time=113ms TTL=54
Reply from 8.8.8.8: bytes=32 time=119ms TTL=54
Request timed out.
Minimum = 113ms, Maximum = 120ms, Average = 117ms
Pinging Google [173.194.38.152] with 32 bytes of data:
Reply from 173.194.38.152: bytes=32 time=178ms TTL=52
Reply from 173.194.38.152: bytes=32 time=182ms TTL=52
Reply from 173.194.38.152: bytes=32 time=243ms TTL=52
Request timed out.
Ping statistics for 173.194.38.152:
Minimum = 178ms, Maximum = 243ms, Average = 201ms
abhijeetiim
i disabled both firewalls...but to no avail...i have posted some ping stats for u to see..plz advise
patcooke
Microsoft MVP
Microsoft MVP
Ping times are all reasonable - the request timeouts are a bit concerning but you would need to do a more sustained test to see how significant they may be. Try diabling IPv6 from the adapter - it is not being used and has been associated with some problems.
abhijeetiim
i disabled ipv6 from router properties and restarted pc with no firewalls also but still the same issue
