The thread discusses a persistent issue where the user's secondary monitor's desktop is offset by about 1/4 inch to the left, unaffected by various Nvidia Control Panel settings or driver updates. The original poster suspects the problem isn’t related to the graphics card itself but may be linked to driver issues. A respondent inquires whether the problem persists and if it also affects full-screen windows or occurs when the monitor is tested on a different computer.
seekermeister
Honorable Member
I've had a problem for a while now, with my secondary monitor's desktop being offset ~1/4" to the left. I've tried every combination of settings in the Nvidia Control Panel, but none changes this in the least. In fact, the control on the Position tab doesn't seem to work at all. It's not a problem with the graphics card, because it is the same with two different cards that I've tried.
I suppose that it might have to do with the driver, but the last time I updated it, the problem remained constant.
Fixer1234
Seeker, I was just browsing for old, unanswered questions. Is this still an issue? If so, is it just the desktop that's offset (what happens when you make a window full-screen)? Do you have the same problem if you connect the monitor as the primary monitor on another computer?
