The thread discusses performance issues with a new IdeaPad Slim 3 15IIL05, including slow startup, reboot, and overall speed, with users exploring hardware and software causes. Key suggestions include checking hardware health, malware scans, and system temperatures, with the final insight indicating high temperature as the primary concern affecting performance. Overall, the discussion leans toward thermal issues as the main culprit needing resolution.
IdeaPad
IdeaPad slim 3 15IIL05 issues:-
Slow Start-Up
Slow Re-Boot
Comparatively Slow Performance (when compared with other PC's with the same processors)
Q - Control Technology not working -- Fn + Q
Please Help me Resolve theses ISSUES
Neemobeer
Windows Forum Team
Slow boot can be failing hardware or dirty fans, heat sinks or if it's later stages of boot can be software related or problems with the OS
IdeaPad
Thread Author #3
No failed Hardware found
Laptop is brand new
" it's later stages of boot can be software related or problems with the OS"--May I know the 'related problems'?
Neemobeer
Windows Forum Team
Operating system corruption, malware, or too many start up apps. What are the hardware specs?
IdeaPad
Thread Author #6
Neemobeer - No Startup apps
No corruption checked through -sfc & DISM
An image from 'Help needed!!!!!!!!'. System specs show Intel i5-1035G1 CPU at 1.19 GHz with 8 GB RAM installed.
Neemobeer
Windows Forum Team
  • Are you using any type of end point protection software? Is it current or try a number of free scanners to augment the scanning capabilities.
  • Test your hard drive and memory problems with either can cause performance issues.
  • Download a tool and look at system temperatures. High temps can cause system throttling
IdeaPad
Thread Author #8
Found only temperature 🌡️ to be High during the 3rd test
