Could someone give me step by step instructions on how to upgrade from vista home premium 32bit to windows 7 64bit? I have an Acer Aspire notebook. My computer came with windows vista already installed. I cannot get the 64bit windows 7 disk to boot so I can select custom install like the instructions say. ANY help appreciated. Cheryl
The thread discusses a user’s difficulty upgrading from Vista Home Premium 32-bit to Windows 7 64-bit on an Acer Aspire laptop, mainly focusing on boot issues with the installation disk. Several contributors suggest checking BIOS boot priority, ensuring the disk is bootable, and provide detailed instructions for creating a bootable install media, including using ISO files and command-line tools. The overall tone is helpful, with multiple solutions offered, including tips for a clean installation and dual boot setup, though some steps may require more technical familiarity.
Similar threads
- Solved
- Solved
