Clemgoff
Hi all,
I just upgraded from Windows 10 32bits to 64. I used an external hard drive for that and of course, I didn't think about it, everything is gone. Some of it wasn't backed up, so I'd like to get the data back if possible, it'd mean the world to me. My little bit of hope is that my hard drive (which was 250go) is now about 34Go and FAT32 (I believe it was ExFAT beforehand). Could the data still be in a hidden partition somewhere ? Thank you !!!
Neemobeer
Windows Forum Team
You can't upgrade from 32 bit to 64 bit so it would have been a clean install (basically wiping out data).
You shouldn't have any problems recovering your data.
GetDataBackNTFS or Testdisk work really well. Make sure when recovering files you don't recover to the disk you are recovering from.
SyriusNoir
Go to C:/ drive and there should be windows.old folder, there is salvaged (may be missing somewhere) data from previous install.
nmsuk
Not if he did a clean install there won't be a windows.old folder.
Clemgoff
Yeah it is indeed possible to upgrade, I had a 64-bit capable pc but windows 32 was installed on it, upgraded and everything works great. I’ve tried a lot of different software and was never able to recover the data. Gonna take je disk to a computer shop soon... thanks for your reply !
Clemgoff
Nothing there :/ thank you though
Clemgoff
Yeah there was nothing there but the data might still be on the disk. I’ll take it to a computer expert. Thank you !
Mike
Windows Forum Admin
No it is not. You will lose all your data and applications.
