The thread discusses a user's difficulties reinstalling and updating Windows 7 on a Samsung RV 515 laptop, with issues including system restore, image creation, and failed update attempts. The user seeks guidance on whether the reinstall disk contains all software or if reinstallation online might help, expressing frustration after failing to proceed with updates. Contributors provide a guide for updating Windows 7 fully via Microsoft’s Convenience Rollup and clarify that updates can no longer be obtained through regular Windows Update but must be downloaded manually from the Update catalog.
markm
Hello, markm here.
Samsung RV 515. Purchased 2011.
OS win 7 home premium 64. sp 1 is on disk.
I reinstalled os 2 weeks ago. I could not before and can not after use system restore or create disk image.
Hopefully I can upload the screenshots.
Also I'm having trouble updating. I downloaded win catalog, but get add on failed to run message.
Any help or links appreciated.
Pt 2.
I did the reinstall offline (have disk that came with).
Does the disk have all the software on it or does it load files from D drive?
I'm pretty sure my D drive is corrupted. Can I reinstall D drive?
Would I get different results if I reinstall online?
sfc /scannow is happy with the setup.
Thanks,
markm.
markm
Thread Author #3
An image from 'reinstall questions'. System errors shown on Windows: backup failed due to I/O device error, and system restore failed to extract a file.
markm
Thread Author #4
thanks Neemobeer.
Looks like I have those files but I don't know what to do with 'em.
Ill try online install later this week.
markm
Thread Author #5
I was gonna reinstall while online but never got past searching for installation updates.
I GIVE UP!
Neemobeer
Windows Forum Team
As stated in that guide and elsewhere you can't get Windows updates through Control Panel > Windows Updates any more. You have to go to the Update catalog online and download the monthly update patches.
