Turbojoe
Honorable Member
Thanks to kemical's suggestion in my last thread I used the media creation tool. Took a deep breath and clicked "upgrade now". Off it went installing Win 10. It didn't take all that long. I went off and did some other things while it was updating. I'm guessing it took well under 30 minutes to the final desktop. Never asked for a key either. When it was done I thought nothing had updated. My desktop was the same as before with the same wall paper and shortcuts. It wasn't until I went to the start button that I saw all the new goodies. Everything seems to be working just fine so far. I could do without the white background in Edge but I'm sure there is a way to change it. Not a big deal. This upgrade is easily the least painful of any I've done since the early MS-DOS days......
Joe
Hey Joe,
you can always run the Edge in 'Dark mode':
An image from 'Way too easy!'. Settings menu shows dark mode enabled on Bing search page with colorful beach umbrellas background.
Turbojoe
Honorable Member
Yeah, I finally found that. I also found that there is no desktop shortcut function in Edge. Looks like I'll be staying with FireFox for my browser.
Joe
Mark H
Honorable Member
If you mean place an Edge shortcut on the desktop, simply drag the tile to the desktop.
Neemobeer
Windows Forum Team
Another trick, if you have Edge or any other application pinned to the taskbar, hold shift and right click the icon, select create shortcut it will ask to create it on the desktop.
Turbojoe
Honorable Member
No. Not trying to save the browser to the desktop. I like to save websites to the desktop. Like "shortcut" in I.E. or Deskcut in FireFox.
Joe
