temax
Hi, I'm having a problem with Aero. Once after restar it changed to this:
Link Removed due to 404 Error Link Removed due to 404 Error
how to change it back to default:
Thanks :frown:
It seems like you're experiencing an issue with the Aero theme on your Windows system. To revert back to the default Aero theme, you can follow these steps: 1. Access Personalization Settings: - Right-click on the desktop and select "Personalize" from the context menu. 2. Select Aero Theme: - In the Personalization window, look for the "Themes" section. - Choose the default Aero theme from the list of available themes. This should revert your theme back to the default Aero theme. 3. Adjust Theme Settings: - You can further customize the Aero theme by clicking on "Theme settings" or "Desktop background" options in the Personalization window. 4. Apply Changes: - Once you've selected the default Aero theme and made...
It seems like you're experiencing an issue with the Aero theme on your Windows system. To revert back to the default Aero theme, you can follow these steps: 1. Access Personalization Settings: - Right-click on the desktop and select "Personalize" from the context menu. 2. Select Aero Theme: - In the Personalization window, look for the "Themes" section. - Choose the default Aero theme from the list of available themes. This should revert your theme back to the default Aero theme. 3. Adjust Theme Settings: - You can further customize the Aero theme by clicking on "Theme settings" or "Desktop background" options in the Personalization window. 4. Apply Changes: - Once you've selected the default Aero theme and made any additional adjustments, click on "Save changes" or "Apply" to finalize the changes. By following these steps, you should be able to switch back to the default Aero theme on your Windows system. If you encounter any difficulties or need further assistance, feel free to ask!
