Hi
Right click on your desktop.
Select Personalize.
Click on Display.
Click on Calibrate Color.
Go through the process and see if you can get something that you like.
If it still looks too bright, do it again and try to lean toward making it darker.
I'm doing this on a desktop but I think the process will be the same.
With a laptop I'm not sure but it there may be tools that go with the video device as well.
Mike
Select Personalize.
Click on Display.
Mike
- Joined
- May 25, 2009
- Messages
- 6,676
Hi
How did you dim your screen?
Using the knobs on the monitor or through the software?
The software that is associated with your video card probably has a set of tools for making adjustments in the computer.
Brightness, contrast, saturation, and color balance should all be adjustable.
There is also a set of tools in Windows, go to Display, and click on Calibrate Color.
I can adjust mine to the point that you can hardly see it.
What kind of video card do you have?
Mike
Mike
- Joined
- May 25, 2009
- Messages
- 6,676
Hi
Select Personalize.
Click on Display.
Mike
Select Personalize.
Click on Display.
Mike
- Thread Author
- #6
i have windows 7. For my start menu bar properties. Under taskbar appearance, taskbar buttons, i have three options: 1) always combine, hide labels. 2) Combine when taskbar is full. 3) Never combine.
However, these isn't as option for "Never combine, hide labels." Any idea how i can get that?
Thanks!
Thanks!
kaos
- Joined
- May 9, 2011
- Messages
- 1,742
possible but not built in windows for some reason
it does mean changing the registry but only adding keys........simples
go to start > type > regedit > go to > HKEY_CURRENT_USER\ControlPanel\Desktop\WindowMetrics > Create string > name this > MinWidth > right click MinWidth > modify > put the value to > 56 > reboot pc...
NOTE: THE SYMBOL > IS ONLY TO SERPATE EACH COMMAND, DONT INCLUDE THIS IN ANY STEPS
TO REVERSE
DELETE THE "MINWIDTH" KEY
YOU DO THIS AT YOUR OWN RISK! BACKUP THE REGISTRY FIRST, I AM NOT LIABLE FOR ANY DAMAGE DONE
Kind Regard Kaos
KRK
TO REVERSE
Kind Regard Kaos
KRK
naomi105813
- Joined
- Sep 26, 2011
- Messages
- 20
After all, window7 is good than windowXP.
Similar threads
- Article
- Replies
- 0
- Views
- 2K
- Article
- Replies
- 0
- Views
- 934
- Article
- Replies
- 0
- Views
- 3K
- Article
- Replies
- 0
- Views
- 3K
- Article
- Replies
- 0
- Views
- 853
