tjohnxon
I would like pin rklauncher application on to my taskbar.
Right clicking it will not display a pin to taskbar option.
Any ideas how I can accomplish this? I have attached a screenshot of what i want to accomplish.
Link Removed due to 404 Error
Tjohnxon
To pin the RKLauncher application to your taskbar, you can follow these steps since the right-click option to pin it might be unavailable: 1. Create a Shortcut: - Right-click on your desktop or any folder. - Select "New" and then "Shortcut." - In the location field, enter the path to the RKLauncher application. If you're not sure about the exact path, you can search for the application in the File Explorer. - Click "Next" and then name the shortcut, such as "RKLauncher." - Click "Finish" to create the shortcut. 2. Pin the Shortcut to Taskbar: - Find the shortcut you just created on your desktop or in the folder. - Right-click on the shortcut. - Choose "Pin to Taskbar" from the context menu. This should pin the RKLauncher...
To pin the RKLauncher application to your taskbar, you can follow these steps since the right-click option to pin it might be unavailable: 1. Create a Shortcut: - Right-click on your desktop or any folder. - Select "New" and then "Shortcut." - In the location field, enter the path to the RKLauncher application. If you're not sure about the exact path, you can search for the application in the File Explorer. - Click "Next" and then name the shortcut, such as "RKLauncher." - Click "Finish" to create the shortcut. 2. Pin the Shortcut to Taskbar: - Find the shortcut you just created on your desktop or in the folder. - Right-click on the shortcut. - Choose "Pin to Taskbar" from the context menu. This should pin the RKLauncher shortcut to your taskbar for easy access. Once you complete these steps, you should see the RKLauncher shortcut pinned to your taskbar for quick access, similar to the screenshot you provided.
