The thread discusses issues with starting new paragraphs when replying or creating threads using IE 10 on the WindowsForum site, which was not a problem in IE 9. A known bug is identified with the visual editor, with suggestions to fix it, such as switching to Compatibility Mode or using the Standard Editor, which ultimately resolved the problem for the original poster. The overall sentiment reflects relief that the issue was eventually acknowledged and resolved in IE 10.
Jimbo22
When using IE 10 and this site, trying to start a new paragraph in a reply or starting a thread is impossible. Usually when starting a new paragraph one would just hit the return key and it starts a new paragraph. For what every reason, starting a new paragraph using IE 10 and this site just doesn't work.
Look I'm starting a new paragraph but using Firefox. So why is it like this?
Thanks Medicted60, I'll give it a shot.
As for compatibility mode, it's not available...no broken link to change. I did switch to standard editor mode and that did the trick.
AS you can see I now have the ability to create new lines and paragraphs. I would have never guessed in a million years it was the editor causing the problem. I'm wonder if that is also causing the problem with adding an attachment (picture) and it showing up as a link and not the actual picture.
Ah...many thanks again...
Mitchell_A
Former Moderator
This is a known issue with the visual editor & has been for months. vB and the developers are apparently in no rush to find a solution.
Jimbo22
Thread Author #3
yet it works so well in IE 9...oh well...thanks for the info...
Is there any word on the facelift!!!!!!!!!!
Medico
If you change IE10 to Compatibility Mode as a work around you will get the Enter key as a Carriage Return. Or switch the editor under General Settings to the Standard Editor.
Jimbo22
Thread Author #5
Mitchell_A
Former Moderator
Nothing to report on for a new theme at this time. Sorry man.
davehc
I found that the para issue was easily solved by clicking the "double" A icon on the top left of you posts bar menu, and switching to "source" mode.
Jimbo22
Thread Author #8
You know I never even bothered to look and see what any of those tabs would do....nice tip.
Mike
Windows Forum Admin
This should now be resolved in Internet Explorer 10.
