The thread revolves around a user planning a new high-performance PC build, seeking advice on components such as CPU, cooling solutions, and graphics cards while managing a tight budget. Other users suggest alternatives, like choosing a cheaper CPU like the i3, and share experiences with cooling systems and hardware choices, with some emphasizing cost savings and others commenting on the specific components' performance. Overall, the thread reflects careful planning and community support for building a customized PC suited to the user's needs and financial constraints, amidst some personal health challenges shared by the original poster.
brkkab
I'm currently in the process of getting parts for a new computer build.
So far I have a Asus Maximus VIII Hero mobo and a Samsung 850 EVO 500GB. M/2 ssd for it. I'm also going to be re-using the Seagate Barracuda 3.0TB h.d , Intel 530 Series 400GB ssd (for Games), Lite On DVD-RW, Lite ON Blu-ray burner and memory card reader from my current pc.
I'm also going to be getting a NZXT Phantom 820 case. G-Skill Ripjaws-Z DDR 4 3200 ram (32GBS) and a Corsair HX-1000i psu for the new pc.
I need suggestions between the following part's for the new pc.
The heatsink is either going to be a EK-XLC Predator 240 or a Corsair Hydro Series H-100i GTX.
With either one, I'll be using 4 EK-Furious Vardar FF5-120 (3000rpm) fans in push/pull.
I also need help deciding between 2 GeForce GTX 4.0GB or 2 AMD Radeon 390X 4.0GB video cards.
I'm ordering a Intel Core i5 6600K cpu on Thursday and eventually plan on upgrading it to a Core i7 6700K in early 2017.
Keep in mind, I'm on permanent disability (Social Security) for life and can't afford to spend over $300.00 on a part/s in a month.
The pc won't be built until May as I won't have all parts until then minus the new video cards.
I'll be using my current GeForce GTX 760's until then, but they need to go back inn this pc, so I can sell it.
All suggestions appreciated between the AIO's and video card's.
P.S. PC will be running Windows 10 Pro x64.
I'm actually hoping for Tuesday or Wednesday. I have medical stuff Monday & Thursday.
Though, when I ordered my current pc's case, I received it the next day on a Saturday morning.
I very well may be building it tomorrow. I'll know sometime tonight when my tracking number is updated by FedEx.
I already have the number, they're just not as good as UPS or the USPS, in the tracking department. It probably won't give me any results until 11:00 P.M.
brkkab
Thread Author #741
They apparently put out a new version this morning. I uninstalled the old one and installed the new one.
kemical: I never really used it either, until now. On my first pc I upgraded from WD version to the full one and used it for awhile.
nmusk: In the WD version of Acronis, where is the incremental located at ? Do I have to create a new backup and select incremental?
When I click on it's Backup tab it shows the full backup I did Wednesday night.
nmsuk
In the options for the backup there should be a schedule section, in there it does incremental backups
brkkab
Thread Author #743
I'm not seeing it in the new version Western Digital released of the Acronis WD Edition today. Hold on a second and I'll make a screenshot of it.I can't get the options in it to stay open while I open the Snipping Tool. The options listed are Entire PC, Disks and partitions and Files and folders. No other options appear.
nmsuk
In my Acronis 2015 it looks like
An image from 'Need help deciding on 2 components for new pc build'. Acronis backup software is set to run weekly incremental backups with full versions every 5 increments.
brkkab
Thread Author #745
The version Western Digital give you doesn't have that in it.
brkkab
Thread Author #746
An image from 'Need help deciding on 2 components for new pc build'. WD backup software interface showing entire PC backup option with 1.44 TB data.
brkkab
Thread Author #748
I don't have those options. I only have the three I listed previously. Nothing shows up at the top like in your screenshots.
brkkab
Thread Author #750
Yeah, that's what I'm thinking. It may be better for me to uninstall it and reinstall Macrium/EasUS ToDo Backup free. I'm not gonna waste 10+ hours for every backup like I did with the first one.
brkkab
Thread Author #752
I have Macrium Reflect & EasUS ToDoBackup free reinstalled.
Formatted my external hd and made a image with Macrium.
I started doing a backup with EasUS afterwards. I fell asleep for a few hours and apparently the power went out again.
Starting fresh with EasUS and deleted the first backup. I've got it backing up my documents, downloads, favorites, music, pictures, saved games and videos now.
After the first are done, I'll start doing each on a weeklybasis. Probably on Sunday's from now on.
nmsuk
Off topic and all but I've just got a ultra widescreen gaming monitor. Will take some getting used to. Have learned do not look at the sun in game. HDR enabled and it's blinding :D
As Norway say's, the above is a little alarming, do you mean the power in the house failed probably due to the meter running out?? Or did the machine just turned itself off?
brkkab
Thread Author #756
No it's power issues from the hurricane last week. I guess it's taking Florida Power & Light a while to work it all out.
brkkab
Thread Author #757
Yes, it was all the power in the house and area. Neighbors lost it, too.
BIGBEARJEDI
>>>Hi, brkkab: Hey, that's good to know about the backups. A few people here like and have tested the EASE ToDo backup including Mike H. who introduced me to it. He swears by it! I'm going to give it a go in the next few weeks on some of my Test Machines and see how it does. The other reason for the reply was to mention you might consider using CrashPlan (Cloud automated backup) for your incremental backups. I have recently just bought it and am using it for a customer who recently suffered a devastating Ransomware attack. It's $5/mo. per PC [$60/yr.]or $12/mo. for 10 PCs (I got this one since I have a lot of machines). Might be worth looking into as a backup to your Macrium/EASEToDo. You can never have too many backups.;) I think this was a saying attributed to Alan Turing. Anyway, let us know how you like the EASEToDo. It's on our recommended list of tested W10 Image Backup software (at least mine!) here along with Macrium & Acronis both of which I've used quite successfully.
Anyway, I'll let you get back to building that new PC of yours. Hope the hurricane didn't do too much damage to your home or neighbors.:nerves:<<<
Cheers!
BBJ
brkkab
Thread Author #760
Yeah, F.P.L. has kind of sucked during this hurricane.
