The original poster experienced three loud bangs from his Sony speakers at startup, suspecting it might be related to the audio connections or speakers. After troubleshooting, he determined the issue was with the speakers themselves, not the computer or motherboard connections, and decided to continue using the HDMI setup despite minor sounds. Overall, the thread concludes with the user accepting the solution and thanking others for their help.
DENNIS GRAVER
Well-Known Member
When I turn the computer on I get 3 loud bangs on my Sony 2.1 speakers then they work fine. Any ideas out there???
Seems a good first step and easy enough to troubleshoot.... just disconnect it and see if the problem is solved.
I would think that any mis-connection of cables to the motherboard might result in any number of troublesome issues, not the least of which might be a grounding that shouldn't exist or not grounding something that should be.
I was wrong about the plug. It is compatable and is now plugged in. I think it is the speakers. This morning I turned off the computer AND THE SPEAKERS. I plugged in the headset and turned on the computer. NO BANGS. I will check the settings in the ROG that sprang up when I switched to the headset from the speakers. I'll let you know.
Trouble
Noob Whisperer
Have you had an opportunity to check the system with a different set of speakers or perhaps a headset with the problem speakers disconnected?
DENNIS GRAVER
Well-Known Member
Thread Author #3
I use a head set when I excersize so I turned off the computer speakers and pulled the plug from the computer. I plugged the head set into the back of the computer and turned the computer on. I heard 3 beeps in the head set so it seems to be related to the computer. There is a plug marked HD AUDIO from the Corsair 900D case that would plug into the motherboard but where the motherboard guide says it should be plugged in the two plugs are not the same. The motherboard has a blank space at top right and the case has a space top second from right. Could that be it???
Trouble
Noob Whisperer
Could that be it???
DENNIS GRAVER
Well-Known Member
Thread Author #5
DENNIS GRAVER
Well-Known Member
Thread Author #6
With the HDMI setup the 3 bangs are more subdued so I have decided to live with it. Case closed. Thanks everyone.
