DENNIS GRAVER
Well-Known Member
- Joined
- Mar 17, 2015
- Messages
- 10
When I turn the computer on I get 3 loud bangs on my Sony 2.1 speakers then they work fine. Any ideas out there???
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I was wrong about the plug. It is compatable and is now plugged in. I think it is the speakers. This morning I turned off the computer AND THE SPEAKERS. I plugged in the headset and turned on the computer. NO BANGS. I will check the settings in the ROG that sprang up when I switched to the headset from the speakers. I'll let you know.Seems a good first step and easy enough to troubleshoot.... just disconnect it and see if the problem is solved.
I would think that any mis-connection of cables to the motherboard might result in any number of troublesome issues, not the least of which might be a grounding that shouldn't exist or not grounding something that should be.
Seems a good first step and easy enough to troubleshoot.... just disconnect it and see if the problem is solved.Could that be it???
With the HDMI setup the 3 bangs are more subdued so I have decided to live with it. Case closed. Thanks everyone.I was wrong about the plug. It is compatable and is now plugged in. I think it is the speakers. This morning I turned off the computer AND THE SPEAKERS. I plugged in the headset and turned on the computer. NO BANGS. I will check the settings in the ROG that sprang up when I switched to the headset from the speakers. I'll let you know.
