The original poster is seeking recommendations for the best software to sync music from Windows 10 to a Samsung ATIV S, hoping to save time. A respondent suggests trying Mobile Assistant or MoboPlay, which are potential options for accomplishing the task. Overall, the thread provides helpful suggestions for syncing music between Windows 10 and a Samsung device.
incross
Banned
light off topic, but does anyone know the best software to sync music from windows 10 to Samsung ATIV S?
I figure you might know and save me rooting around for 3 hours.:)
byspring
Banned
Have you tried Mobile Assistant? MoboPlay is what I usually use, I think it can accomplish your requirements.
