4Tb Ssd Hdd
clives
Greetings,
I have a Samsung 4TB SSD Drive.
It is shown as 2TB allocated and 2 TB unallocated (free).
I want a single drive/partition of 3.9TB.
I have looked at disk manager, but cannot see how to add the majority of the "free" partition to the 1.9TB allocated??
I have also viewed diskpart, but cannot merge the two partitions into one??
Any suggestions?
Thanks
Clive
An image from '4Tb Ssd Hdd'. Disk management showing Disk 0 with multiple partitions including 950.71 GB NTFS and Disk 1 mostly unallocated with 2048 GB allocated.
If the standard Windows tools do not cope with the task of partitioning or merging a disk partition, then it is better to use third-party software. In this regard, the Partition Recovery program has proven itself very well. She can easily cope with such a task.
Mike
Windows Forum Admin
Right click on the bottom 2048.00GB partition and you should see an option to Extend the volume. If not, you can try a third party partition utility.
Neemobeer
Windows Forum Team
It if doesn't give you the option to extend I would wager it's using the MBR partition scheme. It will need to be changed to GPT since MBR has a 2TB partition size limit.
clives
Greetings,
The drive is MBR format.
I selected the Drive, but the convert from MBR to GPT format is greyed out??
Mirerex
Active Member
