64 bit locking up
Discussion in 'Windows 7 Help and Support' started by chugnalng, Jun 17, 2009.
  1. chugnalng
    chugnalng New Member
    May 22, 2009
    32
    0
    First I am thanking everyone for their past support.
    I am running 7 RC 7100.....Puter continously locks up........I have to shutdown via the on off button.....It will run ok for 10 minutes and lock up again.......
    Thanks
    Dan
  2. JohnJ
    JohnJ New Member
    Jun 5, 2009
    208
    0
    I've never had this problem. What are your PC specifications?
  3. chugnalng
    May 22, 2009
    32
    0
    Intel dual core processor
    160g hard drive
    2g ram
  4. patrickt
    patrickt Honorable Member
    Jan 17, 2009
    169
    3
    I have an Intel E6550 dual-core processor. When I first installed Win7 64bit I had problems and a week later my system died. Intel replaced both the motherboard and the processor. My guess is my processor had a problem that only appeared when I went to 64bit. When the replacement arrived I loaded Win7 64bit and haven't had a problem. FWIW, the processor has a three-year warranty.
  5. chugnalng
    May 22, 2009
    32
    0
    Thank You I don't think its a harware issue, it works with Vista
  6. JohnJ
    JohnJ New Member
    Jun 5, 2009
    208
    0
    Why are you running 64-bit?
  7. Radenight
    Radenight New Member
    Nov 16, 2008
    4,525
    108
    Why not, 64-bit is still worth running even with only 2GB's of ram.. ;) It doesn't run as good as with 4GB's but it's still good in my opinion.. :)
  8. loathe
    loathe New Member
    Jan 16, 2009
    1,718
    66
    32 bit runs better with 4GB too.
    You can run x64 on 512MB just fine. It has nothing to do with how much RAM you have. I know I'd still be using x64 if I only have 2GB of RAM.
    To the OP, what causes it to lock up or is it just a random thing?
  9. JohnJ
    JohnJ New Member
    Jun 5, 2009
    208
    0
    I prefer to run 32-bit with anything up to 3GB RAM and 64-bit with more. :)
  10. crezzlin
    crezzlin New Member
    Jun 18, 2009
    8
    0
    Im getting this aswell... very random the computer will just freeze.. only noticed it more this wk because ive been playing music when it just goes buzzzzzzzzzzzzz and i have to hard reset the power.. also i have i put the x86 version on a mates older PC and his has started to do this aswell.
    What a pain really as Win 7 does run much faster in Games and desktop, im getting 23k with 3dmark06 on vista 64 & 24.5k on Win7 64.. .. back to vista for now..
  11. Radenight
    Nov 16, 2008
    4,525
    108
    Yes indeed 32-bit runs noticeably better on 4GB's of ram.. I wasn't saying it doesn't.. ;)
  12. loathe
    loathe New Member
    Jan 16, 2009
    1,718
    66
    Sorry Rad was just trying to get point across that you do not have to have more than 4GB of RAM in order for x64 to work properly. More RAM is always going to make your system run smoother with either x86 and x64.
    In other words, you should not be put off x64 because you only have 2GB of RAM.
  13. chugnalng
    May 22, 2009
    32
    0
    Can I install Windows 7 32 bit on a 64 bit notebook?
  14. Radenight
    Nov 16, 2008
    4,525
    108
    Exactly right Loathe! :)
    No prob, I knew what ya ment.. ;)
Share This Page
Loading...
