Windows 11 a folder has permissions problems, how to restore to default
amrosia
hi,
video folder and videos inside d drive were not opening because of permissions.
if pc owner did not give control of his pc to anyone, where did permissions on the video folder come from. I used the internet to change permissions for this folder. permissions changed successfully . but opening video files inside the folder give various kinds of errors .
Also, files are not saving to the d drive.
how to fix this problem, please reply.
thanks.
Then it's very likely that drive is having physical problems, or the file system may be corrupt. I'd suggest running chkdisk on it with the following command
chkdsk D: /F
Neemobeer
Windows Forum Team
Unless you backed up the ACLs there is no rollback on ACLs for any given folder save for re-installing Windows.
If you're referring to the C:\Users\<username>\Videos then just turn on inheritance and the permissions will be what they should be
Neemobeer
Windows Forum Team
chkdsk D: /F
amrosia
i ran chkdsk D: /F
below is result
An image from 'a folder has permissions problems, how to restore to default'. A Windows CHKDSK scan completed with no errors and 25.5 GB free disk space.
amrosia
but renaming a folder still wants an administrative password. But previously it didn't want the administrative passwords
plz help..
amrosia
when trying to save a file on d drive gives this error message
renaming a folder on this drive gives the following unexpected message, which has never received before.
and deleting a folder on d drive gives the following message
some nice guy on a forum gave/sent me some commands to execute them in elevated command prompt, which i executed successively but the problem remains
theres no such problem on other drives and on usb drives.
plz help.
thanks.
