jayboy
Hello, I have been constantly getting this message whenever I use troubleshooter...
"An error occurred while troubleshooting
A problem is preventing the troubleshooter from starting"
Path:C:\Windows\diagnostics\system\networking
Error code:0x80070426
Source:engine
Context:restricted
The strange thing is that when I run SFC /SCANNOW it fixes it.....TEMPORARILY
and gives me the same error whenever I restart or reboot my system.
Is there a permanent fix for this?
I posted this in the thread I started about the same problem, but I may have found an answer, so I'll post it here too.
I compared the list of Services when the Troubleshooter is not working to the the list when it is working and there were only 2 changes. Here were the results:
When the Troubleshooter is working:
Background Intelligent Transfer Service Stopped
Cryptographic Services Started
When Troubleshooter Is Not Working:
Background Intelligent Transfer Service Started
Cryptographic Services Stopped
There was no change when turning the Background Intelligence Transfer Service on/off, but when I turn ON Cryptographic Services, the Troubleshooter instantly works! When I turn it off, the...
aliasthad
Hi this seems to be a very common problem if you start googling it. I'm glad I came across this thread eventually because it fixed the problem. Perhaps this should be something for the next Microsoft Update.
Thanks to all who helped solve this problem for me.
You're very welcome! I'm glad the solution helped you. ;)
Kind Regards.
