Saltgrass
It looks like another leaked build is out. If that is the case and we end up getting an official release in the next week, would that be the last build prior to the RTM?
If I was Microsoft, I would release an RC about 2 to 3 weeks prior to the RTM. Depending when the RTM would be finalized, we may be getting close to that time...
The latest builds, including 10134 are setting Local Networks as Public. Since the IP address is within my LAN, why is it showing Public? Does anyone know of a setting to get it back to Private? Could this be related to using the Microsoft sign-in or not?
I have not yet tested Cortana.
The memory error seen during restarts is showing up during the install.
The Recovery Partition for a clean install is larger, 450 MBs with the MSR partition going from 128 MB to 16 MB.
The Tiles do not disappear when moved, the other tiles fade while moving one.
I have been able to resize Edge without it closing, but I do not yet have all the favorites in the favorites bar.
I just don't see a lot of difference. The Network Beta app is still...
davehc
Yet another update on my previous post!
The Start menu stopped again. I have had a chat with MS locally, and they, apparently, can offer no explanation why it should work initially and then stop. Plenty of reasons why, however, it should not work immediately after installation. They suggested a graphic driver problem, but doesn't make sense as everything else, across the board, is working fine.
Meanwhile, in order to continue, I have installed Classic Shell.
davehc
And Again. A ver painful working through the customisation and rebooting each time. Finally!!! tracked it down.
Get into settings (Windows Key and I) Select personalization. Select Start. Select "Store and display recently opened programs in start" off (or on - according to what you have selected.
In my case, one of my first customisations is to turn it off. - dadad
