Windows 7 Application Faulting
xkaosx
I keep randomly getting a faulting error when playing Everquest 2.
This is a brand new system that I just put together.
Stats of my computer are in my info.
I've ran memtest86 on both sticks of ram and they are fine. Im not overclocking the cpu.
I was running previously the same game on AMD 4600+ and asus mb and 3gb ram so Im pretty sure
its something with the system and some stupid setting.
Ive done the timings in the BIOS as well for the ram at 5 5 5 15 which is what the G Skill 2x2gb specs are.
The CPU runs at about 42-47c
Here is the faulting message I get for the Application and its the same one everytime
Log Name: Application
Source: Application Error
Date: 6/2/2009 7:02:12 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: GeneW7
Description:
Faulting application name: EverQuest2.exe, version: 1.0.0.1, time stamp: 0x4a170b6a
Faulting module name: EverQuest2.exe, version: 1.0.0.1, time stamp: 0x4a170b6a
Exception code: 0xc0000005
Fault offset: 0x006d44d0
Faulting process id: 0xa08
Faulting application start time: 0x01c9e3e6cbfa8c31
Faulting application path: H:\Sony\EverQuest II\EverQuest2.exe
Faulting module path: H:\Sony\EverQuest II\EverQuest2.exe
Report Id: 8d126f1a-4fe2-11de-80e1-00241d1e1fbf
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2009-06-03T02:02:12.000000000Z" />
<EventRecordID>1242</EventRecordID>
<Channel>Application</Channel>
<Computer>GeneW7</Computer>
<Security />
</System>
<EventData>
<Data>EverQuest2.exe</Data>
<Data>1.0.0.1</Data>
<Data>4a170b6a</Data>
<Data>c0000005</Data>
<Data>006d44d0</Data>
<Data>a08</Data>
<Data>01c9e3e6cbfa8c31</Data>
<Data>H:\Sony\EverQuest II\EverQuest2.exe</Data>
<Data>8d126f1a-4fe2-11de-80e1-00241d1e1fbf</Data>
</EventData>
</Event>
Any suggestions would be appreciated
reghakr
Location
Erie, PA
Did this start immediately after installing Windows 7, or was it working previously.
Did you perform a "clean" install or an upgrade?
When you said it was working corectly, was that on Windowws 7 or another OS?
maybe EverQuest2 is not supported by Windows 7.
If you're running the paid version, shoot the company off an e-mail and ask about Windows 7 support.
xkaosx
It was working previously on my old amd 4600+ system running W7.
It was clean in the fact that I ran the setup from XP then did a clean install on a different partition.
I actually ran the game on the new system using XP SP3 and it was crashing randomly in game too.
Im starting to wonder if this is even a W7 problem and just a problem with something on my system.
Ive ran memtest86 on both sticks of ram. Ive installed latest nvidia beta drivers for W7 and the ones
that came with W7 and they both crash.
Driving me nuts :(
Top Bottom
