R roman12345 New Member Joined Nov 9, 2009 Messages 44 Feb 7, 2010 Thread Author #1 i'm using HDMI-DVI cable .we know that DVI are not passing sound and HDMI does, so it create collision and the result of this is strong noise from my TV which be stopped only when i do "mute". there is another way to stop the noise?
cybercore New Member Joined Jul 7, 2009 Messages 15,641 Feb 7, 2010 #2 Welcome to the forums, Roman. Did you try connecting through S-Video/VGA ? Upvote 0 Downvote R roman12345 New Member Joined Nov 9, 2009 Messages 44 Feb 7, 2010 Thread Author #3 no i bought this cable for 15K why should i buy another cable which make the same action? Upvote 0 Downvote You must log in or register to reply here. Similar threads Solved Windows 10 Audio problems Ferarri77 Jan 25, 2022 Windows Help and Support Replies 2 Views 865 Jan 25, 2022 Ferarri77 T Solved Windows 10 Audio Problem After Installing update on 12 Mar 2021 tbeinc Mar 13, 2021 Windows Help and Support Replies 4 Views 2K Mar 25, 2021 helpifIcan M Solved Usb audio and 3.5mm audio problem Marios1441 Oct 3, 2018 Windows Hardware Replies 5 Views 2K Oct 5, 2018 livix07 F Question Question Windows 8 Windows 8.1 Wavemaxx audio problem Fauno Nov 13, 2015 Windows Help and Support Replies 2 Views 1K Nov 14, 2015 Fauno F P Solved Windows 10 Windows 10 Audio Problem PoptartGames Aug 15, 2015 Windows Help and Support Replies 1 Views 2K Aug 16, 2015 Neemobeer Share: Facebook X (Twitter) LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link
