Windows 7 Blue screen of death help
Reid
hello, I two days ago I was just editing a video and I didn't install any new software or change anything, all I did is save some pictures from google and opened some pictures that my boss sent me , I shut down my computer like normal and the next day, when i started my computer up I got the blue screen of death, idk how to fix it please help.
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be
found later.
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then……Please read the first post in this sticky thread here Link Removed
Do your best to accumulate the data required...
found later.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder
