Windows 7 BlueScreen : needs analysis of dmp file
DeepakAkundi
Hi Experts
Getting blue screen and unable to read the .dmp file.
Kindly analyze attached dmp file and advise.
thanks and regards
deepak
BugCheck 101, {31, 0, 8e900120, 2}
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
Unfortunately I couldn't get all your details from the dmp file. Please read the thread found here and post results with a few dmp files (it's best if we have...
Unfortunately I couldn't get all your details from the dmp file. Please read the thread found here and post results with a few dmp files (it's best if we have more than one):
Looking at the dmp file you sent you might need to update your bios if an update is available.
Your also missing Service pack 1
In case of issues:
All your drivers are in need of updating but if you can post the information requested I can then advise further.
