Browser stops working after a while
Okay this issue has been banded around the internet for a while, but since we managed to solve the Vista "Black Screen with Documents folder" issue I am keen to see what we can do to solve this one.
Basically the issue is.
1. After a while of not using the web browser (or sometmes while using it), it stops working. The symptoms shown for me is that pictures will stop working first, then the pages wont load properly and finally not at all.
2. This does not effect peer to peer, MSN or online gaming.
3. It effects all browsers
There have been several theories as to why it happens but nothing seems to have solved it yet, not sure if a re-install of IE will do the trick, tweaking the register or something else will help so lets try as much of these as we can and see if we can get it sorted once and for all.
Here is what I have tried but has not worked:
1. Resetting Network Card (funnily enough even though I can peer to peer with this error, it wont allow me to access the router, does that help you guys understanding the issue?).
2. Powering down router
3. Deleting all web browsing history, add-ons etc.
Here is the only way it works for me currently.
By rebooting the PC.
Okay guys lets try to nail this one!
IE Stops
My first post here. I have spent many hours with the Dell help desk.They have replaced practically all my working parts. It still does the same thing. After the computer runs for awhile icons get burry and mixed up and if I hold my mouse over the bottom left or right corners of the bottom of the screen I get the message 'Windows Explorer is Restarting'. What to do?
Tom:mad:
U
Unregistered
Guest
I am seeing the same thing. I also see this commonly happen when I run an app that makes vista change it's color scheme and turn off Aero. This happens a lot with Firefox add-on PicLens.
I have exactly this problem too!
Some facts about this problem:
- IE and other browsers stop working for no obvious reason
- Not even local web servers can be reached (like 192.168.0.1)
- This can happen at any time, not correlated to any special program being used
- *Sometimes* (very seldom) it starts working again, after 5-30 minutes
- Microsoft Mail stops working at the same time.
- Windows Update stops working (it still finds new updates and say "There are new updates" and so on, but when trying to install then it bombs out with a 8-digit hexadecimal error code).
- The help text for the error code is wrong. It is not a dns problem or a connection problem.
- MSN/Windows Live Messenger stops working *sometimes* but not always
- I can still ping hosts on the internet, and DNS works just fine
- This happens on Vista (I have Vista Business)
What i have tried:
- Logging out and logging in again: does not solve the problem
- Disconnecting and reconnecting network: does not solve the problem
- Restarting router etc: does not solve the problem
- Disabling the windows firewall: does not solve the problem
- Disabling and enabling network interface: does not solve the problem
- Suspend/sleep mode and wake up again: does not solve the problem
- Stopping and restarting all "network"-ish services: does not solve the problem
What works?
- Reboot. Nothing else.
What this is NOT:
- This is not a router problem/external network problem
- This is not a DNS problem (not external, not internal)
- This is not a network adapter driver problem
- This is not a hardware problem
- This is not a bug in IE
- This is not a bug in the DNS cache service
So, what is this?
- This is a bug in Vista. A very annoying one!
If someone at M$ reads this, then PLEASE do something about this.
I am thinking about deleting Vista and installing XP or something. This is just to sucky.
Windows Forum Admin
Hi, I still say run anti-spyware and anti-virus and see if any bugs are present Don't just try one utility though, one may pick something up where another won't.
I've run vista for a year now and never come across this 'bug'.
Another thing you could try is updating the 'firmware' on your router...
Yes. Me is teh knows. Now send d0nutz pleese. :p
As you may or may not be aware of, there are lots of bugs in Vista, and some of them only show up in "corner cases" or in some configurations and so on, and are not experienced by everybody.
For example, it sometimes deletes another file (or more file(s)) than the one you specify. This is in part due to the double names on files and folders (Example, just off the top of my head: Vista non-english version: "Program" aka "Program Files", and "Program Files" aka "someAutoGeneratedFilename". Now try to delete "Program" folder. You will not be happy with the results, and you will not understand what happened until you dig deep, using the 'black window' (cmd), and finally find out what Vista does to your files 'under the hood').:eek:
Please re-read my post, section "What this is NOT".
Windows Forum Admin
#7
Is that enough donutz for ya?
#8
Hi Magmatrix
You do not appear to be suffering from a minor glitch or bug as you should have been able to find a solution by now.
As you have tried most of the suggestions that we were likely to come up with, perhaps the problem is with your rig and how you are using it and not with the OS.
If there are so many "bugs" in Vista, why have myself among many others not been effected by any?????????
U
Unregistered
Guest
#9
I was having this problem and I eventually figured out that my anti-spyware program, Spyware Doctor, was causing it. It seized something in my browser and wouldn't allow the process to terminate. When I closed that program, the browser process I was observing in Task Manager closed with it. Since removing Spyware Doctor from my startup, I no longer experience problems with my browser.
U
Unregistered
Guest
#10
Nzealander and magmatrix,
Have you found a solution? I have the very same problem on a recent install of Vista Business.
The strange thing is that it affects only browsers, in my case both IE and Firefox. I can use Windows Live Messenger with no issues, even the advertising box on the bottom receives updates. I can also ping and resolve any domain but through the browsers I cannot reach any site until I reboot and then I might be good for an hour or so.
I don't think there is any problems with my rig. The only things on my system at the time the problem started were Firefox, avast antivirus, Spybot S&D, Windows Live Messenger and the Windows updates including SP1. And I don't have Internet Connection Sharing enabled so the fix from M$'s site wouldn't work for me. I have disabled the antivirus but that didn't work. Resetting the connection doesn't work.
U
Unregistered
Guest
#11
I too have this problem that only manifested itself a couple months ago.
I’ve been running vista ultimate for over a year now with no major problems until a couple months ago when both IE7 and Firefox spontaneously stop working after a while. I know I still have an internet connection because AIM still works and torrents continue to download, but all browsers come up with an error. Another machine running vista ultimate connected to the same router hasn’t shown this issue though. The funny thing is, when the problem started nothing had changed in my machine. No new programs installed, no updates from Microsoft, no new hardware. The only thing that fixes it is a system reboot. There is no error in event viewer that I can trace to this problem.
I do a lot of computer hardware research and built this machine myself so I have in depth knowledge of all the hardware inside, drivers installed, and programs on the system. I’m an electrical design engineer and programmer so I’m no stranger to debugging. Yet this problem has me completely baffled. I agree with magmatrix that this problem doesn’t seem to be any of those things he listed. If anybody figures out anything, please post your solution on this site.
Kemical,
Magmatrix posted all those things it is not to help prevent others from wasting time going down dead ends. Be happy you’ve never run into a problem you couldn’t solve or find someone else’s solution to. Remember, not everyone can be as lucky as you.
#12
i've been having the same problem for quite sometime now... it seems like every hour just about on the hour the IE stops working... and i cant get it to work again until i restat. Sometimes i can post pone the non working of IE by going back a website then trying again, but it only works a few times...
i dont abuse or missuse my computer at all.
And i find it very messed up how the people replying saying we dont know how to use computers and crap just because you dont have the problem our computers are having...
:mad:
#13
Not trying to stir the pot but but to get to a solution....
First of all each of you that are having this "bug" as you want to call it, would you please post a hardware list.
Be specific.
1. Mother board = Example...Asus P5DV2-VM SE
2. CPU
3. Video card
4. Memory
5. and this should have been #1 Make and model of PC..Dell, HP, homebuilt, etc.
If you want us to help don't flame because you don't like or don't want to believe the answer you get. I'd hate for someone to get banned over something silly.
Windows Forum Admin
#14
quote'
Kemical,
Magmatrix posted all those things it is not to help prevent others from wasting time going down dead ends. Be happy you’ve never run into a problem you couldn’t solve or find someone else’s solution to. Remember, not everyone can be as lucky as you. quote'
LOL....:rolleyes:
Perhaps the reason this is happening is that there is a conflict somewhere between certain software.. Unfortunately this is going to take a great deal of trial and error before the 'conflict' can be found. Perhaps if users having this particular problem posted the software they were using for stuff like anti-virus,spyware and so on we could find a common denominator?
#15
i have a Toshiba Satellite A135-S4427
i use...
utorrent,
photoshop
aim
and no AV or anything
and winamp,
winzip
winrar
windows media player
Windows Forum Admin
#16
Thanks for the post misteviouse. Now if we can get a couple more forum users posting the same content hopefully we may find a connection.. Fingers crossed!
#17
i use...
utorrent,
photoshop
aim
and winamp,
winzip
winrar
It would help if we knew the specs of your Satellite
Windows Forum Admin
#18
True but I am starting to think this problem is more software based but having all the information can't hurt.. :)
Windows Forum Admin
#20
Looking at what has already been posted though... Nothing leaps of the page..Thoughts?
