Tieria
Hi there, I just stumbled in your forums looking for a possible fix for this BSOD. Any inputs, advices, fixes are appreciated.
What happened: BSOD caused by some ntoskrnl.exe with a BCS of IRQL_NOT_LESS_OR_EQUAL
What I already did: Reformatted Windows to no avail
OS: Windows 7 Ultimate 64-bit
Mobo: MSI Eclipse SLI
Graphics card: 2x MSI GTX460 Hawk Talon
Memory: 12GB OCZ3G1333LV6GK (Gold Edition) CL9 (9-9-9-20)
Sound Card: Creative X-Fi Extreme Audio
HDD: 1TB WD Caviar Black [Primary], 2x 1TB WD Caviar Green & 1TB Seagate Barracuda for storage
A/V: MSE
Here are my dump files:
View attachment Dump.zip
Thanks.
Set your RAM - 533 Mhz 7-7-7-16 1.5v - load setup defaults in the bios and reattach the memory tab.
First of all be sure to set the RAM right.
Update
t3.sys Wed Jun 03 15:13:51 2009
Creative High Definition Audio Driver
TuneUpUtilitiesDriver64.sys Thu Sep 17 07:54:52 2009
TuneUpUtilities
If blue screens persist, you may wanna temporarily uninstall Daemon Tools Pro.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\010711-51090-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03c4f000 PsLoadedModuleList = 0xfffff800`03e8ce50
Debug session time: Thu Jan  6 11:17:38.526 2011 (UTC - 5:00)
System Uptime: 0 days 0:20:38.697
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {fffffa80389a6ee0, 2, 1, fffff80003ca445b}
Probably caused by : memory_corruption ( nt!MmPurgeSection+4eb )
Followup: MachineOwner
6: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffa80389a6ee0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80003ca445b, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80003ef70e0
 fffffa80389a6ee0
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`03ca445b f00fba6b1000    lock bts dword ptr [rbx+10h],0
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  fffff8800337e1f0 -- (.trap 0xfffff8800337e1f0)
rax=fffff8800337e2e8 rbx=0000000000000000 rcx=fffff8800337e2e8
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80003ca445b rsp=fffff8800337e380 rbp=0000058000000000
 r8=fffffa8000371520  r9=0000000000000000 r10=fffff80003ef9840
r11=fffff8800337e350 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe cy
nt!MmPurgeSection+0x4eb:
fffff800`03ca445b f00fba6b1000    lock bts dword ptr [rbx+10h],0 ds:00000000`00000010=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80003cbeca9 to fffff80003cbf740
STACK_TEXT:
fffff880`0337e0a8 fffff800`03cbeca9 : 00000000`0000000a fffffa80`389a6ee0 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`0337e0b0 fffff800`03cbd920 : 00000000`000007ff fffffa80`389a6ed0 fffff8a0`11b23000 fffffa80`0d3e8a30 : nt!KiBugCheckDispatch+0x69
fffff880`0337e1f0 fffff800`03ca445b : 00000000`012de24f 00000000`00012346 fffffa80`00369d20 00000580`00000000 : nt!KiPageFault+0x260
fffff880`0337e380 fffff800`03ca4b82 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff880`01250500 : nt!MmPurgeSection+0x4eb
fffff880`0337e470 fffff880`012bcd21 : fffffa80`0dce63a8 00000000`00000000 00000000`00000000 fffffa80`00000000 : nt!CcPurgeCacheSection+0x172
fffff880`0337e4e0 fffff880`013bdf32 : fffffa80`13f6be40 fffffa80`0d27b180 00000000`00000000 fffffa80`0d27b101 : Ntfs!NtfsFlushVolume+0x601
fffff880`0337e610 fffff880`01314a7c : fffffa80`13fd23f8 fffffa80`0d27b180 fffffa80`0d27b180 00000000`00000000 : Ntfs!NtfsPerformSurpriseRemoval+0x32
fffff880`0337e660 fffff880`0132020c : fffffa80`13f6be40 fffff880`0337e7e8 fffff880`0337e7f0 00000000`00000001 : Ntfs!NtfsCommonPnp+0x7eb
fffff880`0337e740 fffff880`010af23f : fffffa80`13fd2440 00000000`00000000 fffff880`0337e801 fffffa80`13f6be40 : Ntfs!NtfsFsdPnp+0x1f0
fffff880`0337e7e0 fffff880`010ad6df : fffffa80`0c501060 fffff880`0337e988 fffffa80`0c501000 fffffa80`13fd2010 : fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x24f
fffff880`0337e870 fffff800`03f2b519 : fffffa80`0c501060 00000000`c00000bb fffff880`0337e988 fffffa80`13fd2010 : fltmgr!FltpDispatch+0xcf
fffff880`0337e8d0 fffff800`040a9831 : fffffa80`0c27e060 fffffa80`0d27b030 fffffa80`0c3cb5b0 fffffa80`0c27e060 : nt!IopSynchronousCall+0xc5
fffff880`0337e940 fffff800`040a42a8 : fffff880`0337eb00 fffffa80`0c27e060 00000000`0000030a 00000000`00000308 : nt!IopRemoveDevice+0x101
fffff880`0337ea00 fffff800`040a9377 : fffffa80`0c3cb5b0 00000000`00000000 00000000`00000003 00000000`000007ff : nt!PnpSurpriseRemoveLockedDeviceNode+0x128
fffff880`0337ea40 fffff800`040a9490 : 00000000`00000000 fffff8a0`336de800 fffff8a0`3755bda0 fffff880`0337eb98 : nt!PnpDeleteLockedDeviceNode+0x37
fffff880`0337ea70 fffff800`0413941f : 00000000`00000002 00000000`00000000 fffffa80`0c3cb5b0 00000000`00000000 : nt!PnpDeleteLockedDeviceNodes+0xa0
fffff880`0337eae0 fffff800`04139fdc : fffff880`0337ecb8 00000000`00000000 fffff8a0`3180f200 fffffa80`00000000 : nt!PnpProcessQueryRemoveAndEject+0x6cf
fffff880`0337ec20 fffff800`040250dc : 00000000`00000000 fffffa80`0c4833c0 fffff8a0`336de810 00000000`00000001 : nt!PnpProcessTargetDeviceEvent+0x4c
fffff880`0337ec50 fffff800`03ccc961 : fffff800`03f2b008 fffff8a0`336de810 fffff800`03e645f8 fffff800`03e645f8 : nt! ?? ::NNGAKEGL::`string'+0x58ffb
fffff880`0337ecb0 fffff800`03f63c06 : 3026919a`89c0bda3 fffffa80`09d59b60 00000000`00000080 fffffa80`09d41040 : nt!ExpWorkerThread+0x111
fffff880`0337ed40 fffff800`03c9dc26 : fffff880`0316a180 fffffa80`09d59b60 fffff880`031750c0 ae9b538d`0140d416 : nt!PspSystemThreadStartup+0x5a
fffff880`0337ed80 00000000`00000000 : fffff880`0337f000 fffff880`03379000 fffff880`0337dcd0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MmPurgeSection+4eb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xA_nt!MmPurgeSection+4eb
Drivers:
fffff880`03d81000 fffff880`03dbf000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f69000 fffff880`00fc0000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cf2000 fffff880`02d7c000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03dbf000 fffff880`03dd5000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00ea4000 fffff880`00eaf000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00e9b000 fffff880`00ea4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fd3000 fffff880`00ffd000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`019e0000 fffff880`019e7000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03cce000 fffff880`03cdf000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0c0d6000 fffff880`0c0f4000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`0cb76000 fffff880`0cb86000   BthEnum  BthEnum.sys  Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`0cb86000 fffff880`0cba6000   bthpan   bthpan.sys   Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`0b43e000 fffff880`0b4ca000   bthport  bthport.sys  Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0a459000 fffff880`0a471000   BTHUSB   BTHUSB.sys   Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff960`00660000 fffff960`00687000   cdd      cdd.dll      unavailable (00000000)
fffff880`0cba6000 fffff880`0cbc3000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`0197c000 fffff880`019a6000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01916000 fffff880`01946000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d1c000 fffff880`00d7a000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0116a000 fffff880`011dd000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`07df0000 fffff880`07e00000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0b4ca000 fffff880`0b4d8000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03c2d000 fffff880`03cb0000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03cb0000 fffff880`03cce000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`018a2000 fffff880`018b1000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01900000 fffff880`01916000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0a4ef000 fffff880`0a511000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02c1d000 fffff880`02c60000   dtsoftbus01 dtsoftbus01.sys Wed Dec 22 05:19:28 2010 (4D11D0B0)
fffff880`0b4e4000 fffff880`0b4ed000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0b4d8000 fffff880`0b4e4000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0b4ed000 fffff880`0b500000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0a43f000 fffff880`0a44b000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`06c96000 fffff880`06d8a000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`06d8a000 fffff880`06dd0000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`010f8000 fffff880`0110c000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010ac000 fffff880`010f8000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018c6000 fffff880`01900000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01595000 fffff880`015df000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`06c80000 fffff880`06c8d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03c06000 fffff800`03c4f000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`06dd0000 fffff880`06df4000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0a5e3000 fffff880`0a5fc000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0a400000 fffff880`0a408080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0a5d5000 fffff880`0a5e3000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0c00e000 fffff880`0c0d6000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015f7000 fffff880`01600000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03d05000 fffff880`03d1b000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`08153000 fffff880`08162000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0a409000 fffff880`0a417000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bbb000 fffff800`00bc5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`08173000 fffff880`081b6000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013e5000 fffff880`013ff000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0156a000 fffff880`01595000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0a511000 fffff880`0a516200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0b544000 fffff880`0b559000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0b500000 fffff880`0b523000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cc4000 fffff880`00d08000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`0a44b000 fffff880`0a459000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`08162000 fffff880`08171000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0a417000 fffff880`0a424000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e81000 fffff880`00e9b000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`019a6000 fffff880`019d7000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`0cb1d000 fffff880`0cb2d000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`0c0f4000 fffff880`0c10c000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0c10c000 fffff880`0c139000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0c139000 fffff880`0c187000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0c187000 fffff880`0c1aa000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01850000 fffff880`0185b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fc9000 fffff880`00fd3000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0110c000 fffff880`0116a000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`01897000 fffff880`018a2000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01400000 fffff880`01412000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01418000 fffff880`0150a000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06df4000 fffff880`06e00000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`080c3000 fffff880`080f2000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0805a000 fffff880`0806f000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02df0000 fffff880`02dff000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d7c000 fffff880`02dc1000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0150a000 fffff880`0156a000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`0cb2d000 fffff880`0cb42000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`0185b000 fffff880`0186c000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02ce0000 fffff880`02cec000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03c4f000 fffff800`0422b000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01242000 fffff880`013e5000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019d7000 fffff880`019e0000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`07dee000 fffff880`07def180   nvBridge nvBridge.kmd Sat Jul 31 09:41:19 2010 (4C5427FF)
fffff880`0806f000 fffff880`08092000   nvhda64v nvhda64v.sys Mon Jun 21 18:07:25 2010 (4C1FE29D)
fffff880`0720b000 fffff880`07ded980   nvlddmkm nvlddmkm.sys Sat Jul 31 09:43:08 2010 (4C54286C)
fffff880`02dca000 fffff880`02df0000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e6a000 fffff880`00e71000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e71000 fffff880`00e81000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0c6f4000 fffff880`0c79a000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0a4b2000 fffff880`0a4ef000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d08000 fffff880`00d1c000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03dd5000 fffff880`03df9000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`080f2000 fffff880`0810d000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0810d000 fffff880`0812e000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0812e000 fffff880`08148000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c8f000 fffff880`02ce0000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`08148000 fffff880`08153000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01835000 fffff880`0183e000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0183e000 fffff880`01847000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01847000 fffff880`01850000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0cb4a000 fffff880`0cb76000   rfcomm   rfcomm.sys   Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0b559000 fffff880`0b571000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03d1b000 fffff880`03d81000   Rt64win7 Rt64win7.sys Thu Nov 11 01:35:36 2010 (4CDB8EB8)
fffff880`0c79a000 fffff880`0c7a5000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06c74000 fffff880`06c80000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02c00000 fffff880`02c1d000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015ef000 fffff880`015f7000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0ca87000 fffff880`0cb1d000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0c600000 fffff880`0c667000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`0c7a5000 fffff880`0c7d2000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`08171000 fffff880`08172480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0a517000 fffff880`0a5b6000   t3       t3.sys       Wed Jun 03 15:13:51 2009 (4A26CB6F)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0c7d2000 fffff880`0c7e4000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0188a000 fffff880`01897000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0186c000 fffff880`0188a000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c7b000 fffff880`02c8f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005e0000 fffff960`005ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0cb42000 fffff880`0cb4a000   TuneUpUtilitiesDriver64 TuneUpUtilitiesDriver64.sys Thu Sep 17 07:54:52 2009 (4AB2238C)
fffff880`03cdf000 fffff880`03d05000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`081b6000 fffff880`081c8000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0a5b6000 fffff880`0a5d3000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0a5d3000 fffff880`0a5d4f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06c63000 fffff880`06c74000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`08000000 fffff880`0805a000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`06c0d000 fffff880`06c63000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0a424000 fffff880`0a43f000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`06c00000 fffff880`06c0d000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019e7000 fffff880`019f5000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01800000 fffff880`01825000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015df000 fffff880`015ef000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d7a000 fffff880`00dd6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c60000 fffff880`02c7b000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01825000 fffff880`01835000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eb6000 fffff880`00f5a000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f5a000 fffff880`00f69000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02dc1000 fffff880`02dca000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00310000   win32k   win32k.sys   unavailable (00000000)
fffff880`06c8d000 fffff880`06c96000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fc0000 fffff880`00fc9000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0b523000 fffff880`0b544000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0ca00000 fffff880`0ca71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01946000 fffff880`01954000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01954000 fffff880`01960000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01960000 fffff880`01969000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01969000 fffff880`0197c000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Where in the BIOS do I set this?
Look for "Load Setup Defaults" or "Optimized Defaults" or something to that effect. Save and exit.
OR
RAM is in Chipset >> Advanced Configuration - set all settings AUTO. Save and exit.
Update
TuneUpUtilities
Crash Dumps:
Machine Name:
6: kd> !analyze -v
Arguments:
Debugging Details:
 fffffa80389a6ee0
CURRENT_IRQL:  2
FAULTING_IP:
BUGCHECK_STR:  0xA
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Drivers:
Unloaded modules:
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
Loaded Optimal Defaults, here is my pic
updated all the sound driver you've listed and will uninstall Tuneup Utilities and Daemon Tools
Your current settings are 7-7-7-18, while they should be 7-7-7-16.
Would be great if you gave link to a web page with your RAM specs outlined.
Okay so how do I exactly input them or something to make the readings correct?
First ensure the right settings.
To do so, enter bios setup and load setup defaults, save, and exit. Look up in your bios manual, download one if you don't have it.
RAM settings to adjust manually are usually in Chipset >> Advanced >> Dram.
If you're looking for a simple, lightweight, virtual drive replacement for Daemon Tools, I can recommend Link Removed - Invalid URL. I've never had an issue on my 64bit Win7 set up.
Okay so I edited only the CAS latency, tRCD. tRP and tRAS in the Cell Menu in my bios to 9-9-9-20, however I cannot edit the DRAM voltage to 1.65V because according to my mobo manual and the one in the bios says that 1.65V may damage the CPU permanently and the setting remains gray or cannot be edited.
From my mobo manual:
For DRAM Voltage:
" According to the Intel CPU spec, DRAM Voltage setting 1.65V may damage the CPU permanently. It is strongly recommended that you install the DRAM with the voltage setting below 1.65V. You can read the DRAM voltage in GreenPower Center."
Here is my new memory tab from CPU-Z
For DRAM Voltage:
Your current memory setup is 665Mhz 9-9-9-20-74
What you need is 533 Mhz 7-7-7-16-27 1.5v - leave the voltage "AUTO". That's why I keep talking about this "Optimised Setup Defaults".
You may want to verify the above with the official rated specs for your RAM.
