Windows 7 BSOD Crash Dump - Help!
Yes, if that's the case, they probably were.
Get a whole new RAM set and try it out (or, for starters, use RAM sticks that you know to be working properly from another motherboard) with memtest - if it's the RAM problem then the new sticks should all be fine.
Only 106 updates after SP1, most systems have 130 to 140 updates at this point. Please visit Windows Updates and get ALL available updates.
MSINFO32 file is truncated, please run the data collection tool again for the MSINFO32 report.
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
If it's not the SSD/storage controller drivers, then we have to start suspecting other hardware. Please run these free hardware diagnostics: Link Removed
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon Nov 19 08:24:32.512 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111912-6006-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:53:59.683[/B]
BugCheck Code: [B]BugCheck 4E, {99, 19e09b, 2, 19d79a}[/B]
Probably caused by :[B]memory_corruption ( nt!MiBadShareCount+4c )[/B]
BugCheck Info: [B]PFN_LIST_CORRUPT (4e)[/B]
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 000000000019e09b, page frame number
Arg3: 0000000000000002, current page state
Arg4: 000000000019d79a, 0
BUGCHECK_STR:  0x4E_99
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x4E_99_nt!MiBadShareCount+4c[/B]
**************************Sun Nov 18 21:37:26.047 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111912-5725-01.dmp]
System Uptime:[B]0 days 0:54:21.233[/B]
BugCheck Code: [B]BugCheck 1A, {41790, fffffa8003993ea0, ffff, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35054 )[/B]
BugCheck Info: [B]MEMORY_MANAGEMENT (1a)[/B]
Arguments:
Arg1: 0000000000041790, A page table page has been corrupted. On a 64 bit OS, parameter 2
    contains the address of the PFN for the corrupted page table page.
    On a 32 bit OS, parameter 2 contains a pointer to the number of used
    PTEs, and parameter 3 contains the number of used PTEs.
Arg2: fffffa8003993ea0
Arg3: 000000000000ffff
Arg4: 0000000000000000
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME: [B]wermgr.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35054[/B]
**************************Sat Nov 17 20:04:06.590 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-5600-01.dmp]
System Uptime:[B]0 days 2:48:18.211[/B]
BugCheck Code: [B]BugCheck 1A, {41790, fffffa8003993e40, ffff, 0}[/B]
Arguments:
Arg2: fffffa8003993e40
PROCESS_NAME: [B]conhost.exe[/B]
**************************Sat Nov 17 17:16:07.365 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111712-5522-01.dmp]
System Uptime:[B]0 days 3:54:16.552[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff80002cae383, fffff880098c58e0, 0}[/B]
Probably caused by :[B]memory_corruption ( nt!MmCopyToCachedPage+223 )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002cae383, Address of the instruction which caused the bugcheck
Arg3: fffff880098c58e0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]UnRAR.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MmCopyToCachedPage+223[/B]
**************************Sat Nov 17 08:22:37.542 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111712-6661-01.dmp]
System Uptime:[B]0 days 0:32:02.728[/B]
BugCheck Code: [B]BugCheck 4E, {2, 43adf, 21f5ff, 1}[/B]
Probably caused by :[B]memory_corruption ( nt!MiUnlinkPageFromLockedList+8d )[/B]
Arguments:
Arg1: 0000000000000002, A list entry was corrupt
Arg2: 0000000000043adf, entry in list being removed
Arg3: 000000000021f5ff, highest physical page number
Arg4: 0000000000000001, reference count of entry being removed
BUGCHECK_STR:  0x4E_2
PROCESS_NAME: [B]MsMpEng.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x4E_2_nt!MiUnlinkPageFromLockedList+8d[/B]
**************************Fri Nov 16 17:46:14.633 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111612-5522-01.dmp]
System Uptime:[B]0 days 0:15:46.819[/B]
BugCheck Code: [B]BugCheck 50, {fffff880e88a9f88, 0, fffff80002e01a9b, 5}[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+1df )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
Arguments:
Arg1: fffff880e88a9f88, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002e01a9b, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]TubeDigger.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_nt!ExDeferredFreePool+1df[/B]
**************************Fri Nov 16 14:17:56.916 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111612-6770-01.dmp]
System Uptime:[B]0 days 1:20:44.102[/B]
BugCheck Code: [B]BugCheck 1A, {41790, fffffa8003993e70, ffff, 0}[/B]
Arguments:
Arg2: fffffa8003993e70
**************************Fri Nov 16 08:05:07.358 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111612-5943-01.dmp]
System Uptime:[B]0 days 0:30:56.544[/B]
Arguments:
PROCESS_NAME: [B]rundll32.exe[/B]
**************************Fri Nov 16 07:25:46.752 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111612-6208-01.dmp]
System Uptime:[B]0 days 0:05:15.938[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff80002c91284, 0, ffffffffffffffff}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!SwapContext_PatchXRstor+0 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002c91284, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
PROCESS_NAME: [B]msdt.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!SwapContext_PatchXRstor+0[/B]
**************************Thu Nov 15 07:45:12.524 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111512-6224-01.dmp]
System Uptime:[B]0 days 0:08:00.710[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a0e0379cc4, 0, fffff80002fa993e, 5}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CmpKcbCacheLookup+1de )[/B]
Arguments:
Arg1: fffff8a0e0379cc4, memory referenced.
Arg3: fffff80002fa993e, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]checksur.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_nt!CmpKcbCacheLookup+1de[/B]
**************************Tue Nov 13 18:12:10.328 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111312-6240-01.dmp]
System Uptime:[B]0 days 0:00:49.514[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a08f580ab4, 1, fffff8800125cd5f, 5}[/B]
Probably caused by :[B]Ntfs.sys ( Ntfs!NtfsRemoveClose+a3 )[/B]
Arguments:
Arg1: fffff8a08f580ab4, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff8800125cd5f, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_Ntfs!NtfsRemoveClose+a3[/B]
**************************Tue Nov 13 16:46:43.039 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111312-6146-01.dmp]
System Uptime:[B]0 days 0:04:09.836[/B]
BugCheck Code: [B]BugCheck 19, {3, fffffa8006674c80, fffffa80a8674c80, fffffa80a0674c80}[/B]
*** WARNING: Unable to verify timestamp for MpFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for MpFilter.sys
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+a53 )[/B]
BugCheck Info: [B]BAD_POOL_HEADER (19)[/B]
Arguments:
Arg1: 0000000000000003, the pool freelist is corrupt.
Arg2: fffffa8006674c80, the pool entry being checked.
Arg3: fffffa80a8674c80, the read back flink freelist value (should be the same as 2).
Arg4: fffffa80a0674c80, the read back blink freelist value (should be the same as 2).
BUGCHECK_STR:  0x19_3
PROCESS_NAME: [B]SearchProtocol[/B]
FAILURE_BUCKET_ID: [B]X64_0x19_3_nt!ExDeferredFreePool+a53[/B]
**************************Tue Nov 13 14:02:25.307 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111312-6364-01.dmp]
System Uptime:[B]0 days 0:24:37.494[/B]
BugCheck Code: [B]BugCheck 19, {3, fffffa8006676180, fffffa8027676180, fffffa8006676180}[/B]
Arguments:
Arg2: fffffa8006676180, the pool entry being checked.
Arg3: fffffa8027676180, the read back flink freelist value (should be the same as 2).
Arg4: fffffa8006676180, the read back blink freelist value (should be the same as 2).
PROCESS_NAME: [B]lsass.exe[/B]
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
MBfilt64.sys                Thu Jul 30 23:40:32 2009 (4A7267B0)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
rtl8192se.sys               Fri Apr 30 04:04:26 2010 (4BDA8F0A)
asmtxhci.sys                Fri Mar  4 02:54:59 2011 (4D709AD3)
asmthub3.sys                Fri Mar  4 02:55:10 2011 (4D709ADE)
k57nd60a.sys                Tue May 10 00:42:30 2011 (4DC8C236)
ISCTD64.sys                 Tue Aug 23 13:32:39 2011 (4E53E437)
WPRO_41_2001.sys            Mon Nov  7 16:04:48 2011 (4EB847F0)
IntcDAud.sys                Tue Dec  6 06:23:07 2011 (4EDDFB1B)
ikbevent.sys                Tue Jan  3 19:35:09 2012 (4F039EBD)
imsevent.sys                Tue Jan  3 19:35:31 2012 (4F039ED3)
RTKVHD64.sys                Tue Jan 31 05:55:06 2012 (4F27C88A)
iusb3hub.sys                Mon Feb 27 05:56:50 2012 (4F4B6172)
iusb3xhc.sys                Mon Feb 27 05:56:53 2012 (4F4B6175)
iusb3hcs.sys                Mon Feb 27 05:58:49 2012 (4F4B61E9)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
MpFilter.sys                Thu Aug 23 19:03:14 2012 (5036B6B2)
SbieDrv.sys                 Sat Aug 25 16:27:46 2012 (50393542)
igdkmd64.sys                Wed Sep 26 15:49:04 2012 (50635C30)
HECIx64.sys                 Wed Nov  9 19:52:25 2011 (4EBB2049)
igdkmd64.sys                Mon May 21 15:04:11 2012 (4FBA91AB)
[/font]
Thanks for the extensive reply.
Just when i was starting to think it was a RAM issue (i ran memtest86+ and got thousands of errors shortly after the test started), my Crucial M4 SSD stopped booting after the latest BSOD.
The firmware was already the latest, updated a few days ago, but that didn't help. Both components (the RAM and the SSD) are just 3 months old and worked fine for about 2 months. I had Hard Disk Sentinel Pro installed and the SSD had a 100% health indication.
Can the SSD failure be related to the RAM?
Try running HDtune (link to download in signature) for 1 or 2 days - if the perf bar goes too low then it could be your SSD's problem.
I was wondering if this set of dumps would become the poster child for SSD issues (it had that "feel" to me).
Fix the RAM issues (start with step 6b in this procedure: Link Removed )
Once they are fixed, see if that stops the BSOD's. If not, then we can look at the SSD again.
Actually i saw the HDTune's link in your signature before and had it run for 1,5 days or so. I ran all tests and everything looked fine. If i get the pc to boot i'll try it again.
From what i've read, Crucial advises a Link Removed when the BIOS fails to recognize the drive. I'll try that when i get back home, although i had the BSOD's happening way before the drive fail.
Thanks guys.
Alright, try running HDTune once more if you can - it's better to get multiple tests.
The Power Cycle looks like an answer though I'm not entirely sure (me having never used an SSD before).
Yesterday the pc booted perfectly fine again and i was able to run HDTune all day long. No warning signs there whatsoever.
Today i was finally able to play around with the RAM's. I took one of them off and tried the other one on both slots. Both tests were faulty under memtest86+. I'm trying the remaining one for over 1h now and no errors thus far (the errors used to pop out of memtest86+ 1 second after i started it). I'm fairly confident the BSOD's were due to the faulty RAM.
Thanks for the help guys.
