- Thread Author
- #1
I have 2 BSOD on newly installed win 7 ultimate 64 bit and need some help
i will post also debugging detailsLink Removed
***Here is debugging details***
Opened log file 'c:\debug.txt'
1: kd> .sympath srv*c:\symbols*[URL]http://msdl.microsoft.com/download/symbols[/URL]
Symbol search path is: srv*c:\symbols*[URL]http://msdl.microsoft.com/download/symbols[/URL]
Expanded Symbol search path is: srv*c:\symbols*[URL]http://msdl.microsoft.com/download/symbols[/URL]
1: kd> .reload;!analyze -v;r;kv;lmnt;.logclose;q
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: 0000000000000000, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cfb0e0
0000000000000000
CURRENT_IRQL: 2
FAULTING_IP:
+3134333464363637
00000000`00000000 ?? ???
PROCESS_NAME: utorrent.exe
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xD1
TRAP_FRAME: fffff88006468680 -- (.trap 0xfffff88006468680)
rax=000000007ef9e000 rbx=0000000000000000 rcx=00000000c0000102
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=0000000000000000 rsp=fffff88006468810 rbp=0000000000000000
r8=fffffa8004959bb8 r9=0000000000000000 r10=fffffffffffffffd
r11=fffff880009e8180 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei ng nz na pe nc
.trap
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002ac2b29 to fffff80002ac35c0
FAILED_INSTRUCTION_ADDRESS:
+3134333464363637
STACK_TEXT:
fffff880`06468538 fffff800`02ac2b29 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffff880`06468540 fffff800`02ac17a0 : 00000000`00000000 fffff880`009e8180 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`06468680 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiPageFault+260
fffff800`02ac17a0 440f20c0 mov rax,cr8
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiPageFault+260
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aa44
FAILURE_BUCKET_ID: X64_0xD1_CODE_AV_NULL_IP_nt!KiPageFault+260
Followup: MachineOwner
rax=fffff88006468640 rbx=fffff880009e8180 rcx=000000000000000a
rdx=0000000000000000 rsi=fffffa8004810b60 rdi=fffffa8005032360
rip=fffff80002ac35c0 rsp=fffff88006468538 rbp=fffff88006468700
r8=0000000000000002 r9=0000000000000008 r10=0000000000000000
r11=fffff6fb40000000 r12=0000000000000000 r13=0000000000000000
r14=fffffa8004959b30 r15=fffff880009ecec0
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00000282
nt!KeBugCheckEx:
fffff800`02ac35c0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff880`06468540=000000000000000a
Child-SP RetAddr : Args to Child : Call Site
fffff880`06468680 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260 (TrapFrame @ fffff880`06468680)
start end module name
fffff800`00bb9000 fffff800`00bc3000 kdcom kdcom.dll Sat Feb 05 14:21:45 2011 (4D4D40D9)
fffff800`02a0a000 fffff800`02a53000 hal hal.dll Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`02a53000 fffff800`0302f000 nt ntkrnlmp.exe Thu Jun 23 05:51:48 2011 (4E02AA44)
fffff880`00c00000 fffff880`00c5c000 volmgrx volmgrx.sys unavailable (00000000)
fffff880`00c63000 fffff880`00ca7000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:29:10 2009 (4A5BDF66)
fffff880`00ca7000 fffff880`00cbb000 PSHED PSHED.dll Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00cbb000 fffff880`00d19000 CLFS CLFS.SYS Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d19000 fffff880`00dd9000 CI CI.dll Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00dd9000 fffff880`00dfa000 raspptp raspptp.sys Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`00e00000 fffff880`00e1a000 mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e1a000 fffff880`00e23000 atapi atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000 ataport ataport.SYS Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00e51000 fffff880`00ef5000 Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ef5000 fffff880`00f04000 WDFLDR WDFLDR.SYS Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f04000 fffff880`00f5b000 ACPI ACPI.sys Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f5b000 fffff880`00f64000 WMILIB WMILIB.SYS Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f64000 fffff880`00f6e000 msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f6e000 fffff880`00fa1000 pci pci.sys Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fa1000 fffff880`00fae000 vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00fae000 fffff880`00fc3000 partmgr partmgr.sys Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00fc3000 fffff880`00fd8000 volmgr volmgr.sys Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00fd8000 fffff880`00fe0000 intelide intelide.sys Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00fe0000 fffff880`00ff0000 PCIIDEX PCIIDEX.SYS Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00ff0000 fffff880`00ffb000 amdxata amdxata.sys Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`01000000 fffff880`0104c000 volsnap volsnap.sys Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0104c000 fffff880`01086000 rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01086000 fffff880`010c0000 fvevol fvevol.sys Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`010c2000 fffff880`0110e000 fltmgr fltmgr.sys Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`0110e000 fffff880`01122000 fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`01122000 fffff880`01180000 msrpc msrpc.sys unavailable (00000000)
fffff880`01180000 fffff880`011f3000 cng cng.sys Thu Nov 17 06:26:35 2011 (4EC48CFB)
fffff880`01200000 fffff880`01216000 disk disk.sys Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`0121d000 fffff880`013c0000 Ntfs Ntfs.sys Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013c0000 fffff880`013da000 ksecdd ksecdd.sys Thu Nov 17 05:54:33 2011 (4EC48579)
fffff880`013da000 fffff880`013eb000 pcw pcw.sys Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`013eb000 fffff880`013f5000 Fs_Rec Fs_Rec.sys unavailable (00000000)
fffff880`01400000 fffff880`01460000 NETIO NETIO.SYS Fri Apr 09 05:43:59 2010 (4BBE946F)
fffff880`01460000 fffff880`0148b000 ksecpkg ksecpkg.sys Thu Nov 17 06:27:30 2011 (4EC48D32)
fffff880`0148b000 fffff880`014d5000 fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`014d5000 fffff880`014de000 hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`014e3000 fffff880`015d5000 ndis ndis.sys Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`015d5000 fffff880`015e5000 vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`015e5000 fffff880`015ed000 spldr spldr.sys Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`015ed000 fffff880`015ff000 mup mup.sys Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01600000 fffff880`017fe000 tcpip tcpip.sys Thu Sep 29 06:52:31 2011 (4E83EB7F)
fffff880`01800000 fffff880`0181b000 raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`01824000 fffff880`01854000 CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`0188a000 fffff880`018b4000 cdrom cdrom.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`018b4000 fffff880`018e5000 MpFilter MpFilter.sys Wed Apr 06 23:07:29 2011 (4D9CC801)
fffff880`018e5000 fffff880`018ee000 Null Null.SYS unavailable (00000000)
fffff880`018ee000 fffff880`018f5000 Beep Beep.SYS Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`018f5000 fffff880`01903000 vga vga.sys Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`01903000 fffff880`01928000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`01928000 fffff880`01938000 watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`01938000 fffff880`01941000 RDPCDD RDPCDD.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`01941000 fffff880`0194a000 rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`0194a000 fffff880`01953000 rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`01953000 fffff880`0195e000 Msfs Msfs.SYS unavailable (00000000)
fffff880`0195e000 fffff880`0196f000 Npfs Npfs.SYS Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`0196f000 fffff880`0198d000 tdx tdx.sys Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`0198d000 fffff880`0199a000 TDI TDI.SYS Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`0199a000 fffff880`019be000 rasl2tp rasl2tp.sys Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`019be000 fffff880`019ed000 ndiswan ndiswan.sys Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`02c00000 fffff880`02c14000 termdd termdd.sys Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02c14000 fffff880`02c3b000 SCDEmu SCDEmu.SYS Tue Nov 15 05:18:27 2011 (4EC1DA03)
fffff880`02c3b000 fffff880`02c8c000 rdbss rdbss.sys Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`02c8c000 fffff880`02c98000 nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`02c98000 fffff880`02ca3000 mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`02ca9000 fffff880`02d32000 afd afd.sys Mon Apr 25 05:43:58 2011 (4DB4DFEE)
fffff880`02d32000 fffff880`02d77000 netbt netbt.sys Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02d77000 fffff880`02d80000 wfplwf wfplwf.sys Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d80000 fffff880`02da6000 pacer pacer.sys Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02da6000 fffff880`02db5000 netbios netbios.sys Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02db5000 fffff880`02dd2000 serial serial.sys Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02dd2000 fffff880`02ded000 wanarp wanarp.sys Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02ded000 fffff880`02dfc000 discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03a00000 fffff880`03a56000 USBPORT USBPORT.SYS Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`03a56000 fffff880`03a65000 kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03a65000 fffff880`03a75000 CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`03a75000 fffff880`03a8b000 AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`03a8b000 fffff880`03a97000 ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`03aa3000 fffff880`03b26000 csc csc.sys Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03b26000 fffff880`03b44000 dfsc dfsc.sys Wed Apr 27 05:57:39 2011 (4DB78623)
fffff880`03b44000 fffff880`03b55000 blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03b55000 fffff880`03b7b000 tunnel tunnel.sys Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03b7b000 fffff880`03b91000 intelppm intelppm.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03b91000 fffff880`03bf8000 Rt64win7 Rt64win7.sys Fri Jan 21 09:34:00 2011 (4D3936E8)
fffff880`03c00000 fffff880`03c03e80 BdaSup BdaSup.SYS Tue Jul 14 03:06:40 2009 (4A5BCC10)
fffff880`03c04000 fffff880`03c09200 ksthunk ksthunk.sys Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`03c0a000 fffff880`03c17000 fdc fdc.sys unavailable (00000000)
fffff880`03c17000 fffff880`03c23000 serenum serenum.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`03c23000 fffff880`03c40000 parport parport.sys Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`03c40000 fffff880`03c5e000 i8042prt i8042prt.sys Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`03c5e000 fffff880`03c6d000 mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03c77000 fffff880`03dbc880 3xHybr64 3xHybr64.sys Wed Aug 26 06:53:20 2009 (4A94B1B0)
fffff880`03dbd000 fffff880`03e00000 ks ks.sys Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`04200000 fffff880`042c8000 HTTP HTTP.sys Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`042d8000 fffff880`042f2000 rassstp rassstp.sys Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`042f2000 fffff880`042fd000 rdpbus rdpbus.sys Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`042fd000 fffff880`042fe480 swenum swenum.sys Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`042ff000 fffff880`04311000 umbus umbus.sys Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`04311000 fffff880`0436b000 usbhub usbhub.sys Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`0436b000 fffff880`04376000 flpydisk flpydisk.sys unavailable (00000000)
fffff880`04376000 fffff880`0438b000 NDProxy NDProxy.SYS Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`0438b000 fffff880`043d9000 mrxsmb10 mrxsmb10.sys Sat Jul 09 05:44:55 2011 (4E17C0A7)
fffff880`043d9000 fffff880`043fc000 mrxsmb20 mrxsmb20.sys Wed May 04 05:51:05 2011 (4DC0BF19)
fffff880`04800000 fffff880`04818000 rspndr rspndr.sys Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`04818000 fffff880`04836000 bowser bowser.sys Wed Feb 23 07:15:06 2011 (4D6497DA)
fffff880`04836000 fffff880`0484e000 mpsdrv mpsdrv.sys Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`0484e000 fffff880`0487b000 mrxsmb mrxsmb.sys Wed May 04 05:51:06 2011 (4DC0BF1A)
fffff880`04891000 fffff880`04acf580 RTKVHD64 RTKVHD64.sys Fri Apr 30 12:05:58 2010 (4BDA9D76)
fffff880`04ad0000 fffff880`04b0d000 portcls portcls.sys Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`04b0d000 fffff880`04b2f000 drmk drmk.sys Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`04b2f000 fffff880`04b3b000 Dxapi Dxapi.sys Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`04b3b000 fffff880`04b56000 USBSTOR USBSTOR.SYS Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`04b56000 fffff880`04b57f00 USBD USBD.SYS Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`04b58000 fffff880`04b66000 crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`04b66000 fffff880`04b72000 dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`04b72000 fffff880`04b7b000 dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`04b7b000 fffff880`04b8e000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`04b8e000 fffff880`04b9c000 monitor monitor.sys Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`04b9c000 fffff880`04bbf000 luafv luafv.sys Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`04bbf000 fffff880`04be0000 WudfPf WudfPf.sys Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`04be0000 fffff880`04bf5000 lltdio lltdio.sys Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05c00000 fffff880`05c67000 srv2 srv2.sys Fri Apr 29 06:12:51 2011 (4DBA2CB3)
fffff880`05cd2000 fffff880`05d78000 peauth peauth.sys Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`05d78000 fffff880`05d83000 secdrv secdrv.SYS Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`05d83000 fffff880`05db0000 srvnet srvnet.sys Fri Apr 29 06:12:35 2011 (4DBA2CA3)
fffff880`05db0000 fffff880`05dc2000 tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`06000000 fffff880`06018000 NisDrvWFP NisDrvWFP.sys Wed Apr 06 23:08:53 2011 (4D9CC855)
fffff880`060b8000 fffff880`0614d000 srv srv.sys Fri Apr 29 06:13:05 2011 (4DBA2CC1)
fffff880`0614d000 fffff880`0617e000 WUDFRd WUDFRd.sys Tue Jul 14 03:06:06 2009 (4A5BCBEE)
fffff880`061ef000 fffff880`061ff000 MpNWMon MpNWMon.sys Wed Apr 06 23:07:23 2011 (4D9CC7FB)
fffff880`0f000000 fffff880`0f046000 dxgmms1 dxgmms1.sys Wed Jan 26 06:22:12 2011 (4D3FA174)
fffff880`0f046000 fffff880`0f06a000 HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`0f06a000 fffff880`0f077000 usbuhci usbuhci.sys Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`0f077000 fffff880`0f088000 usbehci usbehci.sys Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`0f091000 fffff880`0fd08000 nvlddmkm nvlddmkm.sys Sat Oct 15 09:07:55 2011 (4E99233B)
fffff880`0fd08000 fffff880`0fdfc000 dxgkrnl dxgkrnl.sys Wed Jan 26 06:22:56 2011 (4D3FA1A0)
fffff960`00050000 fffff960`00364000 win32k win32k.sys Thu Nov 24 07:00:11 2011 (4ECDCF5B)
fffff960`005a0000 fffff960`005aa000 TSDDD TSDDD.dll unavailable (00000000)
fffff960`006e0000 fffff960`00707000 cdd cdd.dll Wed Jan 26 08:31:34 2011 (4D3FBFC6)
Unloaded modules:
fffff880`0617e000 fffff880`061ef000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`01854000 fffff880`01862000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01862000 fffff880`0186e000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`0186e000 fffff880`01877000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`01877000 fffff880`0188a000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Closing open log file c:\debug.txt
