BSOD DRIVER_POWER_STATE_FAILURE ntoskrnl.exe +70740
Help! Keep getting this BSOD at reandom times.
The mini-dump is attached and CPU-Z snaps are pasted below
Thanks!
1. Enable CPU EIST feature (to keep CPU frequency down when idling)
2. Attach the .dmp files
3. Attach RAMMon HTML.zip
Cybercore:
Thanks for the help!
I've attached a new minidump (crashed again after enabling CPU EIST) and a RAMMon.html zip.
My .dmp file is 500MB, 150MB compressed. Can I upload it...or compress/read it with a different tool?
Saltgrass
You need to attach the dump in its proper component. Just zip it to make it attachable.
Have you looked at the sticky for attaching dump files and set your system to record mini-dump files?
RAM is alright. It's some driver bugging out. Navigate to C:\Windows\Minidump, copy out, zip and attach the .dmp files.
Here are the last three mini-dumps in a zip file.
THANKS AGAIN!!
#7
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
0x9F_3_disk_IMAGE_sbp2port.sys -- MS SBP-2 Protocol Driver
Update old drivers:
WD External Storage
wdcsam64.sys Wed Apr 16 04:39:08 2008
Broadcom iLine10(tm) PCI Network Adapter
BCM42RLY.sys Tue Jul 07 20:34:55 2009
Pinnacle
MarvinBus64.sys Fri Sep 23 17:17:03 2005
bender64.sys Mon Nov 27 05:13:48 2006
Broadcom NetLink (TM) Gigabit Ethernet Driver
k57nd60a.sys Sat Jun 20 07:34:49 2009
nVidia
nvlddmkm.sys Fri Jun 26 18:15:53 2009
CRASH DUMPS
Loading Dump File [F:\DMP\042611-29406-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02e13000 PsLoadedModuleList = 0xfffff800`03050e50
Debug session time: Tue Apr 26 15:38:49.984 2011 (UTC - 4:00)
System Uptime: 0 days 2:43:43.139
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 9F, {3, fffffa800c8bb050, fffff80000b9c518, fffffa800c666d80}
Probably caused by : sbp2port.sys
Followup: MachineOwner
0: kd> !analyze -v
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa800c8bb050, Physical Device Object of the stack
Arg3: fffff80000b9c518, Functional Device Object of the stack
Arg4: fffffa800c666d80, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  sbp2port.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc119
MODULE_NAME: sbp2port
FAULTING_MODULE: fffff88009181000 sbp2port
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c4c8 fffff800`02ef2273 : 00000000`0000009f 00000000`00000003 fffffa80`0c8bb050 fffff800`00b9c518 : nt!KeBugCheckEx
fffff800`00b9c4d0 fffff800`02e8f29e : fffff800`00b9c600 fffff800`00b9c600 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x292b0
fffff800`00b9c570 fffff800`02e8edd6 : fffffa80`0b227c68 fffffa80`0b227c68 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5e0 fffff800`02e8f4be : 00000016`df0c1bf8 fffff800`00b9cc58 00000000`00099bb4 fffff800`03001908 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cc30 fffff800`02e8ecb7 : 00000006`3d07f0c2 00000006`00099bb4 00000006`3d07f00b 00000000`000000b4 : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`02e8beea : fffff800`02ffde80 fffff800`0300bc40 00000000`00000000 fffff880`0499adb0 : nt!KiRetireDpcList+0x277
fffff800`00b9cd80 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_disk_IMAGE_sbp2port.sys
Loading Dump File [F:\DMP\042611-34554-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02e1f000 PsLoadedModuleList = 0xfffff800`0305ce50
Debug session time: Tue Apr 26 17:47:47.448 2011 (UTC - 4:00)
System Uptime: 0 days 2:07:56.604
BugCheck 9F, {3, fffffa800c61e050, fffff80000b9c518, fffffa800ca71010}
0: kd> !analyze -v
Arguments:
Arg2: fffffa800c61e050, Physical Device Object of the stack
Arg4: fffffa800ca71010, The blocked IRP
Debugging Details:
FAULTING_MODULE: fffff88009228000 sbp2port
BUGCHECK_STR:  0x9F
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c4c8 fffff800`02efe273 : 00000000`0000009f 00000000`00000003 fffffa80`0c61e050 fffff800`00b9c518 : nt!KeBugCheckEx
fffff800`00b9c4d0 fffff800`02e9b29e : fffff800`00b9c600 fffff800`00b9c600 00000000`00000003 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x292b0
fffff800`00b9c570 fffff800`02e9add6 : fffffa80`09a08210 00000000`00078236 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5e0 fffff800`02e9b4be : 00000011`df9cd4e4 fffff800`00b9cc58 00000000`00078236 fffff800`0300c948 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cc30 fffff800`02e9acb7 : 00000004`e01024c3 00000004`00078236 00000004`e0102484 00000000`00000036 : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`02e97eea : fffff800`03009e80 fffff800`03017c40 00000000`00000000 fffff800`02fafdb0 : nt!KiRetireDpcList+0x277
STACK_COMMAND:  kb
Loading Dump File [F:\DMP\042711-29031-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02e4c000 PsLoadedModuleList = 0xfffff800`03089e50
Debug session time: Wed Apr 27 05:12:12.827 2011 (UTC - 4:00)
System Uptime: 0 days 11:23:26.982
BugCheck 9F, {3, fffffa800f933050, fffff80000b9c518, fffffa800f7309b0}
Probably caused by : disk.sys
0: kd> !analyze -v
Arguments:
Arg2: fffffa800f933050, Physical Device Object of the stack
Arg4: fffffa800f7309b0, The blocked IRP
Debugging Details:
IRP_ADDRESS:  fffffa800f7309b0
DEVICE_OBJECT: fffffa8008fc7440
DRIVER_OBJECT: fffffa8007c479d0
IMAGE_NAME:  disk.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc11d
MODULE_NAME: disk
FAULTING_MODULE: fffff880013cf000 disk
BUGCHECK_STR:  0x9F
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c4c8 fffff800`02f2b273 : 00000000`0000009f 00000000`00000003 fffffa80`0f933050 fffff800`00b9c518 : nt!KeBugCheckEx
fffff800`00b9c4d0 fffff800`02ec829e : fffff800`00b9c600 fffff800`00b9c600 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x292b0
fffff800`00b9c570 fffff800`02ec7dd6 : fffff800`0306c700 00000000`00281c1b 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5e0 fffff800`02ec84be : 0000005f`7a10fe43 fffff800`00b9cc58 00000000`00281c1b fffff800`030395e8 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cc30 fffff800`02ec7cb7 : 0000001a`0ac1fac1 0000001a`00281c1b 0000001a`0ac1fa6b 00000000`0000001b : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`02ec4eea : fffff800`03036e80 fffff800`03044c40 00000000`00000000 fffff880`04802db0 : nt!KiRetireDpcList+0x277
STACK_COMMAND:  kb
FAILURE_BUCKET_ID:  X64_0x9F_3_IMAGE_disk.sys
DRIVERS
fffff880`061ac000 fffff880`061ea000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f76000 fffff880`00fcd000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02d60000 fffff880`02dea000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`061ea000 fffff880`06200000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c8f000 fffff880`00c9a000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`08b3a000 fffff880`08b45000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00c86000 fffff880`00c8f000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dd2000 fffff880`00dfc000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`00db1000 fffff880`00dbd000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`08c2a000 fffff880`08c33000   BCM42RLY BCM42RLY.sys Tue Jul 07 20:34:55 2009 (4A53E9AF)
fffff880`0167d000 fffff880`01684000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`05651000 fffff880`0568ee80   bender64 bender64.sys Mon Nov 27 05:13:48 2006 (456ABA5C)
fffff880`044bf000 fffff880`045d7000   BHDrvx64 BHDrvx64.sys Wed Apr 13 20:16:01 2011 (4DA63CC1)
fffff880`043b8000 fffff880`043c9000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06315000 fffff880`06333000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`007b0000 fffff960`007d7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`01030000 fffff880`0105a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ea7000 fffff880`00f67000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01000000 fffff880`01030000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d0b000 fffff880`00d69000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0135c000 fffff880`013cf000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00fed000 fffff880`00ff6000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0568f000 fffff880`0569f000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`063e9000 fffff880`063f2000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`08bde000 fffff880`08bec000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0439a000 fffff880`043b8000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0438b000 fffff880`0439a000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`013cf000 fffff880`013e5000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05253000 fffff880`0527b000   Dot4     Dot4.sys     Mon Jul 13 20:00:16 2009 (4A5BCA90)
fffff880`05288000 fffff880`05292000   Dot4Prt  Dot4Prt.sys  Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`05243000 fffff880`05253000   dot4usb  dot4usb.sys  Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`053ae000 fffff880`053d0000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`08afc000 fffff880`08b05000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`08bec000 fffff880`08bf8000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`08b05000 fffff880`08b18000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06ac8000 fffff880`06ad4000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04884000 fffff880`04978000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`04978000 fffff880`049be000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`042f0000 fffff880`04366000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`08c00000 fffff880`08c20000   ENG64    ENG64.SYS    Fri Mar 04 17:02:16 2011 (4D716168)
fffff880`04366000 fffff880`0438b000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`08c33000 fffff880`08df6000   EX64     EX64.SYS     Fri Mar 04 17:10:51 2011 (4D71636B)
fffff880`06a92000 fffff880`06ac8000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01128000 fffff880`0113c000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0106b000 fffff880`010b7000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01411000 fffff880`0141b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`011c2000 fffff880`011fc000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0162b000 fffff880`01675000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`049e6000 fffff880`049f3000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02e03000 fffff800`02e4c000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04856000 fffff880`0487a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05315000 fffff880`05371000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`053e2000 fffff880`053fb000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05200000 fffff880`05208080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`053d4000 fffff880`053e2000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0624d000 fffff880`06315000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017f3000 fffff880`017fc000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04173000 fffff880`041ee000   IDSvia64 IDSvia64.sys Fri Mar 11 21:15:42 2011 (4D7AD74E)
fffff880`04400000 fffff880`04416000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`040c8000 fffff880`040f5000   Ironx64  Ironx64.SYS  Fri Nov 12 18:06:50 2010 (4CDDC88A)
fffff880`05600000 fffff880`05651000   k57nd60a k57nd60a.sys Sat Jun 20 07:34:49 2009 (4A3CC959)
fffff880`044ac000 fffff880`044bb000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06a84000 fffff880`06a92000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bbb000 fffff800`00bc5000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`04416000 fffff880`04459000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`015dd000 fffff880`015f7000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`049e0000 fffff880`049e5200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06b26000 fffff880`06b3b000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06ae2000 fffff880`06b05000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`08c20000 fffff880`08c2a000   LVPr2M64 LVPr2M64.sys Fri May 07 21:38:16 2010 (4BE4C088)
fffff880`06a32000 fffff880`06a83d00   lvrs64   lvrs64.sys   Tue Nov 09 21:36:46 2010 (4CDA053E)
fffff880`06601000 fffff880`069f7a80   lvuvc64  lvuvc64.sys  Tue Nov 09 21:37:14 2010 (4CDA055A)
fffff880`0424a000 fffff880`0428e000   MarvinBus64 MarvinBus64.sys Fri Sep 23 17:17:03 2005 (433470CF)
fffff880`00cb3000 fffff880`00cf7000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`06ad4000 fffff880`06ae2000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0423b000 fffff880`0424a000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0527b000 fffff880`05288000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c6c000 fffff880`00c86000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`06333000 fffff880`0634b000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0634b000 fffff880`06378000   mrxsmb   mrxsmb.sys   Wed Feb 23 00:15:23 2011 (4D6497EB)
fffff880`06378000 fffff880`063c6000   mrxsmb10 mrxsmb10.sys Wed Feb 23 00:15:14 2011 (4D6497E2)
fffff880`063c6000 fffff880`063e9000   mrxsmb20 mrxsmb20.sys Wed Feb 23 00:15:13 2011 (4D6497E1)
fffff880`02d19000 fffff880`02d24000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fd6000 fffff880`00fe0000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`012fe000 fffff880`0135c000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`04168000 fffff880`04173000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0141b000 fffff880`0142d000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01684000 fffff880`01776000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0569f000 fffff880`056ab000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`06b8e000 fffff880`06ba1000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0447d000 fffff880`044ac000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05300000 fffff880`05315000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02c8a000 fffff880`02c99000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02c00000 fffff880`02c45000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01776000 fffff880`017d6000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02d24000 fffff880`02d35000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0415c000 fffff880`04168000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e4c000 fffff800`03429000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0143a000 fffff880`015dd000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01213000 fffff880`0121c000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`061aa000 fffff880`061ab180   nvBridge nvBridge.kmd Fri Jun 26 17:22:03 2009 (4A453BFB)
fffff880`056b0000 fffff880`061a9d80   nvlddmkm nvlddmkm.sys Fri Jun 26 18:15:53 2009 (4A454899)
fffff880`06b3b000 fffff880`06b8e000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02c4e000 fffff880`02c74000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00d9c000 fffff880`00db1000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d69000 fffff880`00d9c000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00ff6000 fffff880`00ffd000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01411000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`08200000 fffff880`082a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05371000 fffff880`053ae000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cf7000 fffff880`00d0b000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`012f2000 fffff880`012fde00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`04459000 fffff880`0447d000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`043c9000 fffff880`043e4000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04200000 fffff880`04221000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04221000 fffff880`0423b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0410b000 fffff880`0415c000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02cfe000 fffff880`02d07000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02d07000 fffff880`02d10000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02d10000 fffff880`02d19000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01188000 fffff880`011c2000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`06ba1000 fffff880`06bb9000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`08bba000 fffff880`08bd7000   sbp2port sbp2port.sys Mon Jul 13 19:19:53 2009 (4A5BC119)
fffff880`082a6000 fffff880`082b1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`08b45000 fffff880`08b4d000   serscan  serscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`01675000 fffff880`0167d000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08a01000 fffff880`08ac0000   SRTSP64  SRTSP64.SYS  Fri Nov 19 19:17:58 2010 (4CE713B6)
fffff880`040f5000 fffff880`0410b000   SRTSPX64 SRTSPX64.SYS Fri Nov 19 19:18:10 2010 (4CE713C2)
fffff880`08357000 fffff880`083ec000   srv      srv.sys      Wed Feb 23 00:16:24 2011 (4D649828)
fffff880`082f0000 fffff880`08357000   srv2     srv2.sys     Wed Feb 23 00:15:59 2011 (4D64980F)
fffff880`082b1000 fffff880`082de000   srvnet   srvnet.sys   Wed Feb 23 00:15:49 2011 (4D649805)
fffff880`049cf000 fffff880`049dfd00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`049fb000 fffff880`049fc480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`010b7000 fffff880`01128000   SYMDS64  SYMDS64.SYS  Fri Oct 15 13:53:54 2010 (4CB89532)
fffff880`01229000 fffff880`012f2000   SYMEFA64 SYMEFA64.SYS Mon Nov 15 16:56:23 2010 (4CE1AC87)
fffff880`04092000 fffff880`040c8000   SYMEVENT64x86 SYMEVENT64x86.SYS Fri Jul 30 19:05:59 2010 (4C535AD7)
fffff880`0402c000 fffff880`04092000   SYMNETS  SYMNETS.SYS  Tue Nov 30 18:24:40 2010 (4CF587B8)
fffff880`01801000 fffff880`019fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`082de000 fffff880`082f0000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02d53000 fffff880`02d60000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02d35000 fffff880`02d53000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02cb4000 fffff880`02cc8000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00410000 fffff960`0041a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`045d7000 fffff880`045fd000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0428e000 fffff880`042a0000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`042a0000 fffff880`042bac00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05226000 fffff880`05243000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`05209000 fffff880`0520af00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`049be000 fffff880`049cf000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`052a6000 fffff880`05300000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04800000 fffff880`04856000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0520b000 fffff880`05226000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00fe0000 fffff880`00fed000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0105a000 fffff880`01068000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02cc9000 fffff880`02cee000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00dbd000 fffff880`00dd2000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0113c000 fffff880`01188000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c74000 fffff880`02c8a000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`02c99000 fffff880`02cb4000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02cee000 fffff880`02cfe000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`08dfa000 fffff880`08dfd880   wdcsam64 wdcsam64.sys Wed Apr 16 04:39:08 2008 (4805BB2C)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f67000 fffff880`00f76000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02c45000 fffff880`02c4e000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00372000   win32k   win32k.sys   Wed Mar 02 22:58:01 2011 (4D6F11C9)
fffff880`00fcd000 fffff880`00fd6000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`08af1000 fffff880`08afc000   WSDPrint WSDPrint.sys Mon Jul 13 20:39:20 2009 (4A5BD3B8)
fffff880`06b05000 fffff880`06b26000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`08ac0000 fffff880`08af1000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`08b18000 fffff880`08b24000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b24000 fffff880`08b2d000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08b4d000 fffff880`08b60000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08b75000 fffff880`08b92000   sbp2port.sys
    Checksum:  00000000
    ImageSize:  0001D000
fffff880`08df6000 fffff880`08dfa000   wdcsam64.sys
    Checksum:  00000000
    ImageSize:  00004000
fffff880`08b92000 fffff880`08b9e000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b9e000 fffff880`08ba7000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08ba7000 fffff880`08bba000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08b18000 fffff880`08b35000   sbp2port.sys
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00004000
fffff880`08b4d000 fffff880`08b59000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b59000 fffff880`08b62000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08b62000 fffff880`08b75000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08c00000 fffff880`08c20000   ENG64.SYS
    Checksum:  00000000
    ImageSize:  00020000
fffff880`08c33000 fffff880`08df6000   EX64.SYS
    Checksum:  00000000
    ImageSize:  001C3000
fffff880`08ba7000 fffff880`08baf000   serscan.sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`08b8a000 fffff880`08ba7000   sbp2port.sys
    Checksum:  00000000
    ImageSize:  0001D000
fffff880`08dfa000 fffff880`08dfe000   wdcsam64.sys
    Checksum:  00000000
    ImageSize:  00004000
fffff880`08baf000 fffff880`08bbb000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08bbb000 fffff880`08bc4000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08bc4000 fffff880`08bd7000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08bb2000 fffff880`08bba000   serscan.sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`08b62000 fffff880`08b6e000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b6e000 fffff880`08b77000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08b77000 fffff880`08b8a000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08b45000 fffff880`08b62000   sbp2port.sys
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00004000
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00004000
fffff880`08bba000 fffff880`08bc6000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08bc6000 fffff880`08bcf000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08b18000 fffff880`08b2b000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00004000
fffff880`08bcd000 fffff880`08bd9000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b18000 fffff880`08b21000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08b21000 fffff880`08b34000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08b58000 fffff880`08b75000   sbp2port.sys
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00004000
fffff880`08b9d000 fffff880`08ba9000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08ba9000 fffff880`08bb2000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08bba000 fffff880`08bcd000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08b75000 fffff880`08b81000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b81000 fffff880`08b8a000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08b8a000 fffff880`08b9d000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08bba000 fffff880`08bd7000   sbp2port.sys
    Checksum:  00000000
    ImageSize:  0001D000
    Checksum:  00000000
    ImageSize:  00004000
#8
Thanks!!
I checked them all. Only bender64.sys had a more current version available.
Rebooted...and waiting to see if that does the trick.
#9
Thanks!!
It'll crash again. If your hardware is compatible with Windows 7, you'll find the updates:
WD External Storage
Pinnacle
nVidia
#10
Ok, I guess I need help then. I found each driver through Device Manager and selected "update driver."
In every case but bender64.sys, windows reported I had the most recent driver. Is there a better way to find/update the right ones?
Sorry for being dense
#11
