spoonracer
Here's what I got: PLEASE HELP!!!!
AMD Phenom II x4 3.20 GHz
2 x 2GB Corsair Ram DDR3
Biostar TA880GB+
Corsair 400w power supply
1TB Samsung Spinpoint F3 HD103SJ
Acer H2038 Monitor
HP DVD1270 DVD ROM
Microsoft Wireless 5000 keyboard and mouse
Windows 7 Ultimate
I put the PC together my self a couple months ago..since then I've been getting random, almost always different BSOD's when starting up my PC. It seems to happen more often on cold starts after hours of not turning on the pc. I am also gettin BSOD's while using windows if I am able to load it.
-I've done a clean install of windows 7 ultimate several times.
-I've run memtest through 7 passes and haven't found errors on either stick..I also tried using each memory stick individually and still came up with BSOD's
-I tried sfc /scannow several times as well as chkdsk
-I tried startup repair...sometimes it works, sometimes it doesn't work.
-System restore usally lets me boot up after restart, but later I will get BSOD again. Sometimes I get the "referenced memory could not be read" error during system restore process and I have to reboot.
-I updated my bios after about 2 weeks of getting errors and also tried updating everything else of the motherboard manufac. site.
-I tried all windows updates for my hardware
-I ran the samsung hard drive diagnostic and didn't get any errors.
-I get BSOD's even without installing any software on clean installs
-I tried reseating everything on my MOBO
-I don't have an extra PC to swap out hardware with..
I don't know if I can give anymore useful info, but I have attached my dumpfiles and hopefully someone can please help me!!! I finally built this PC and haven't been able to enjoy it yet...PLEASE HELP.... SOMEONE!!
OK! I think I may have solved the problem.
Being that I was ONLY getting BSOD's on Cold Starts seemed fishy.
Although I had tested the memory numerous times overnight after the computer was already warmed up without any errors. I just tested it for the first time with memtest86+ on a cold start and got over 50,000 errors within the first pass. Unless you guys suspect that is anything besides bad memory, I will go ahead and RMA it. Thanks for the help
Use this to uninstall sptd.sys (and not update - there's a choice while using):
Update those 2 other drivers Cybercore has shown.
Are you sure the good stick is in place?
(St:nt!MmAccessFault+0x877)
Uninstall:
sptd.sys Sun Oct 11 23:54:02 2009
Uninstall this, Daemon/Alcohol/Duplex Secure
These drivers are good enough for Windows XP, but I would try to update them:
rt2870.sys Wed Oct 29 08:34:39 2008
Ralink 802.11 USB Wireless Adapter
BS_I2cIo.sys Mon Jun 16 04:02:32 2008
BIOSTAR I2C I/O
Test the hard disk too:
chkdsk /r
S.M.A.R.T. HDDScan
Yes, I'm sure it was just the error-free RAM stick in place.
I used Link Removed to uninstall sptd.sys
I uninstalled Daemon Tools
I believe I updated the USB adaptor driver
I couldn't find an update for BS_I2cIo.sys
I went through chkdsk /r
I ran HDDScan and hit the S.M.A.R.T button and got one error it looks like. It is attached.
should I run anything else from HDDScan?
I will report back in the morning about whether I'm still getting BSOD's after cold start.
DMA - dirrect memory access of your hdd. Ultra dma crc errors - it's not critical, but:
1. chkdsk /r
2. defragment your hdd
3. make sure the hard drive is properly connected
then run hdd scan again.
Next, run memtest overnight:
RAM - Test with Memtest86+ - Windows 7 Forums
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\D M P\Mini101310-01.dmp]
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 3) MP (4 procs) Free x86 compatible
Built by: 2600.xpsp_sp3_gdr.100427-1636
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Wed Oct 13 16:53:34.734 2010 (GMT-5)
System Uptime: 0 days 0:00:21.734
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1000008E, {c0000005, 8054b10d, af20c80c, 0}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+107 )
Followup: Pool_corruption
2: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 8054b10d, The address that the exception occurred at
Arg3: af20c80c, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
8054b10d 893b            mov     dword ptr [ebx],edi
TRAP_FRAME:  af20c80c -- (.trap 0xffffffffaf20c80c)
ErrCode = 00000002
eax=e1690c38 ebx=00000000 ecx=000001ff edx=e1690c38 esi=89e69078 edi=00000000
eip=8054b10d esp=af20c880 ebp=af20c8c0 iopl=0         nv up ei ng nz ac pe cy
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010297
nt!ExDeferredFreePool+0x107:
8054b10d 893b            mov     dword ptr [ebx],edi  ds:0023:00000000=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  DRIVER_FAULT
BUGCHECK_STR:  0x8E
PROCESS_NAME:  svchost.exe
LAST_CONTROL_TRANSFER:  from 8054b75f to 8054b10d
STACK_TEXT:
af20c8c0 8054b75f 00000001 89e32510 89b893d8 nt!ExDeferredFreePool+0x107
af20c900 805bfea6 e2222c20 00000000 af20c93c nt!ExFreePoolWithTag+0x47f
af20c910 805c021e e2222c20 af20c901 00000000 nt!ObReleaseObjectSecurity+0x1a
af20c93c 8062e967 e20fc170 89b893d8 00000001 nt!ObCheckObjectAccess+0xd6
af20c988 8062f608 e1769008 00000410 00000000 nt!CmpDoOpen+0x2d5
af20cb88 805bf011 00000410 00000000 89b893d8 nt!CmpParseKey+0x5a6
af20cc00 805bb9c0 000002d4 af20cc40 00000040 nt!ObpLookupObjectName+0x119
af20cc54 80624d6e 00000000 89e324d0 00fe0001 nt!ObOpenObjectByName+0xea
af20cd50 8054164c 000a4c00 00020019 0174fa08 nt!NtOpenKey+0x1c8
af20cd50 7c90e514 000a4c00 00020019 0174fa08 nt!KiFastCallEntry+0xfc
WARNING: Frame IP not in any known module. Following frames may be wrong.
0174fa48 00000000 00000000 00000000 00000000 0x7c90e514
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExDeferredFreePool+107
FOLLOWUP_NAME:  Pool_corruption
IMAGE_NAME:  Pool_Corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: Pool_Corruption
FAILURE_BUCKET_ID:  0x8E_nt!ExDeferredFreePool+107
Loading Dump File [F:\a\Minidump\D M P\Mini101310-02.dmp]
Machine Name:
Debug session time: Wed Oct 13 16:59:32.671 2010 (GMT-5)
System Uptime: 0 days 0:05:29.294
BugCheck 4E, {7, 57241, 57f38, 0}
Probably caused by : memory_corruption ( nt!MiDeferredUnlockPages+17c )
Followup: MachineOwner
1: kd> !analyze -v
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc).  If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 00000007, A driver has unlocked a page more times than it locked it
Arg2: 00057241, page frame number
Arg3: 00057f38, current share count
Arg4: 00000000, 0
Debugging Details:
BUGCHECK_STR:  0x4E_7
CUSTOMER_CRASH_COUNT:  2
PROCESS_NAME:  wuauclt.exe
LAST_CONTROL_TRANSFER:  from 80522d33 to 804f9f43
STACK_TEXT:
af3d2b08 80522d33 0000004e 00000007 00057241 nt!KeBugCheckEx+0x1b
af3d2b28 805067be af3d2c0c af3d2c0c 0000000f nt!MiDecrementReferenceCount+0x33
af3d2b6c 805096d5 8055c588 08548020 ae710020 nt!MiDeferredUnlockPages+0x17c
af3d2b9c 805b3f27 af3d2bb4 af3d2d00 0001258d nt!MmUnlockPages+0x201
af3d2c70 805b4233 895dd9e0 03b90020 898f8348 nt!MiDoMappedCopy+0x175
af3d2ca0 805a5dee 898f83c8 03b90020 898f8348 nt!MmCopyVirtualMemory+0x63
af3d2d20 805a5e78 00000001 00000218 000c5ed0 nt!LpcpCopyRequestData+0x1fc
af3d2d44 8054164c 00000218 000c5ed0 00000000 nt!NtWriteRequestData+0x1e
af3d2d44 7c90e514 00000218 000c5ed0 00000000 nt!KiFastCallEntry+0xfc
011ffe28 00000000 00000000 00000000 00000000 0x7c90e514
STACK_COMMAND:  kb
FOLLOWUP_IP:
805067be 8b55e0          mov     edx,dword ptr [ebp-20h]
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!MiDeferredUnlockPages+17c
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4bd6e0e8
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  0x4E_7_nt!MiDeferredUnlockPages+17c
804d7000 806e4000   nt       ntkrpamp.exe Tue Apr 27 16:04:40 2010 (4BD6E0E8)
806e4000 80704d00   hal      halmacpi.dll Sun Apr 13 21:31:27 2008 (4802517F)
ae6b1000 ae6f1e00   HTTP     HTTP.sys     Tue Oct 20 19:20:15 2009 (4ADDE33F)
aee4a000 aeea0800   srv      srv.sys      Mon Jun 21 18:27:09 2010 (4C1F84CD)
aeec9000 aeedd480   wdmaud   wdmaud.sys   Sun Apr 13 22:17:18 2008 (48025C3E)
aefce000 aeffa180   mrxdav   mrxdav.sys   Sun Apr 13 21:32:42 2008 (480251CA)
af28b000 af299d80   sysaudio sysaudio.sys Sun Apr 13 22:15:55 2008 (48025BEB)
af32b000 af32e900   ndisuio  ndisuio.sys  Sun Apr 13 21:55:57 2008 (4802573D)
af633000 af64a900   dump_atapi dump_atapi.sys Sun Apr 13 21:40:29 2008 (4802539D)
af673000 af723f00   rt2870   rt2870.sys   Mon Aug 03 05:57:37 2009 (4A765221)
af74c000 af7bb400   mrxsmb   mrxsmb.sys   Wed Feb 24 15:11:05 2010 (4B852569)
af7bc000 af7e6e80   rdbss    rdbss.sys    Sun Apr 13 22:28:38 2008 (48025EE6)
af7e7000 af808d00   afd      afd.sys      Thu Aug 14 13:04:35 2008 (48A40333)
af809000 af82e500   ipnat    ipnat.sys    Sun Apr 13 21:57:10 2008 (48025786)
af82f000 af856c00   netbt    netbt.sys    Sun Apr 13 22:20:59 2008 (48025D1B)
af857000 af8af480   tcpip    tcpip.sys    Fri Jun 20 14:51:09 2008 (485B99AD)
af8b0000 af8c2600   ipsec    ipsec.sys    Sun Apr 13 22:19:42 2008 (48025CCE)
af8e3000 af906000   MpFilter MpFilter.sys Sat Mar 20 06:03:26 2010 (4BA4490E)
af93a000 af93cf80   mouhid   mouhid.sys   Fri Aug 17 23:47:57 2001 (3B7D82FD)
af93e000 af941900   kbdhid   kbdhid.sys   Sun Apr 13 21:39:47 2008 (48025373)
af952000 af954880   hidusb   hidusb.sys   Sun Apr 13 21:45:27 2008 (480254C7)
af956000 af979a80   portcls  portcls.sys  Sun Apr 13 22:19:40 2008 (48025CCC)
af97a000 aff79000   RtkHDAud RtkHDAud.sys Fri Apr 30 11:56:08 2010 (4BDA9B28)
aff8d000 aff90580   BIOS     BIOS.sys     Wed Mar 16 08:23:52 2005 (4237D0F8)
b2e09000 b2e0b280   rasacd   rasacd.sys   Fri Aug 17 23:55:39 2001 (3B7D84CB)
b2e40000 b2e9df00   update   update.sys   Sun Apr 13 21:39:46 2008 (48025372)
b2e9e000 b2ecde80   rdpdr    rdpdr.sys    Sun Apr 13 21:32:50 2008 (480251D2)
b2ece000 b2edee00   psched   psched.sys   Sun Apr 13 21:56:36 2008 (48025764)
b2edf000 b2ef5580   ndiswan  ndiswan.sys  Sun Apr 13 22:20:41 2008 (48025D09)
b2ef6000 b2f09900   parport  parport.sys  Sun Apr 13 21:40:09 2008 (48025389)
b2f0a000 b2f32000   HDAudBus HDAudBus.sys Thu May 26 18:46:29 2005 (4295EF55)
b2f32000 b2f55200   USBPORT  USBPORT.SYS  Sun Apr 13 21:45:34 2008 (480254CE)
b2f56000 b2f78700   ks       ks.sys       Sun Apr 13 22:16:34 2008 (48025C12)
b2f79000 b2f8cf00   VIDEOPRT VIDEOPRT.SYS Sun Apr 13 21:44:39 2008 (48025497)
b2f8d000 b39a9e60   nv4_mini nv4_mini.sys Sat Jul 10 00:19:49 2010 (4C379275)
b7daa000 b7dadc80   mssmbios mssmbios.sys Sun Apr 13 21:36:45 2008 (480252BD)
b7dc6000 b7dc8780   ndistapi ndistapi.sys Sun Apr 13 21:57:27 2008 (48025797)
b7dca000 b7dcc280   wmiacpi  wmiacpi.sys  Sun Apr 13 21:36:37 2008 (480252B5)
b7dee000 b7e07b80   Mup      Mup.sys      Sun Apr 13 22:17:05 2008 (48025C31)
b7e08000 b7e34980   NDIS     NDIS.sys     Sun Apr 13 22:20:35 2008 (48025D03)
b7e35000 b7ec1600   Ntfs     Ntfs.sys     Sun Apr 13 22:15:49 2008 (48025BE5)
b7ec2000 b7ed8b00   KSecDD   KSecDD.sys   Wed Jun 24 14:18:40 2009 (4A420B90)
b7ed9000 b7eeaf00   sr       sr.sys       Sun Apr 13 21:36:50 2008 (480252C2)
b7eeb000 b7f0ab00   fltMgr   fltMgr.sys   Sun Apr 13 21:32:58 2008 (480251DA)
b7f0b000 b7f22900   atapi    atapi.sys    Sun Apr 13 21:40:29 2008 (4802539D)
b7f23000 b7f48700   dmio     dmio.sys     Sun Apr 13 21:44:45 2008 (4802549D)
b7f49000 b7f67880   ftdisk   ftdisk.sys   Fri Aug 17 23:52:41 2001 (3B7D8419)
b7f68000 b7f78a80   pci      pci.sys      Sun Apr 13 21:36:43 2008 (480252BB)
b7f79000 b7fa6d80   ACPI     ACPI.sys     Sun Apr 13 21:36:33 2008 (480252B1)
b80a8000 b80b1180   isapnp   isapnp.sys   Sun Apr 13 21:36:40 2008 (480252B8)
b80b8000 b80c2580   MountMgr MountMgr.sys Sun Apr 13 21:39:45 2008 (48025371)
b80c8000 b80d4c80   VolSnap  VolSnap.sys  Sun Apr 13 21:41:00 2008 (480253BC)
b80d8000 b80e0e00   disk     disk.sys     Sun Apr 13 21:40:46 2008 (480253AE)
b80e8000 b80f4180   CLASSPNP CLASSPNP.SYS Sun Apr 13 22:16:21 2008 (48025C05)
b8138000 b8146b00   drmk     drmk.sys     Sun Apr 13 21:45:12 2008 (480254B8)
b8158000 b8160700   wanarp   wanarp.sys   Sun Apr 13 21:57:20 2008 (48025790)
b8168000 b8170780   netbios  netbios.sys  Sun Apr 13 21:56:01 2008 (48025741)
b8188000 b8192e00   Fips     Fips.SYS     Sun Apr 13 21:33:27 2008 (480251F7)
b81a8000 b81b1000   HIDCLASS HIDCLASS.SYS Sun Apr 13 21:45:25 2008 (480254C5)
b81b8000 b81c7900   Cdfs     Cdfs.SYS     Sun Apr 13 22:14:21 2008 (48025B8D)
b8268000 b8270c00   processr processr.sys Sun Apr 13 21:31:29 2008 (48025181)
b8278000 b8282480   imapi    imapi.sys    Sun Apr 13 21:40:57 2008 (480253B9)
b8288000 b8297600   cdrom    cdrom.sys    Sun Apr 13 21:40:45 2008 (480253AD)
b8298000 b82a6100   redbook  redbook.sys  Sun Apr 13 21:40:27 2008 (4802539B)
b82a8000 b82b7c00   serial   serial.sys   Sun Apr 13 22:15:44 2008 (48025BE0)
b82b8000 b82c4880   rasl2tp  rasl2tp.sys  Sun Apr 13 22:19:43 2008 (48025CCF)
b82c8000 b82d2200   raspppoe raspppoe.sys Sun Apr 13 21:57:31 2008 (4802579B)
b82d8000 b82e3d00   raspptp  raspptp.sys  Sun Apr 13 22:19:47 2008 (48025CD3)
b82e8000 b82f0900   msgpc    msgpc.sys    Sun Apr 13 21:56:32 2008 (48025760)
b82f8000 b8301f00   termdd   termdd.sys   Sun Apr 13 21:38:36 2008 (4802532C)
b8308000 b8316880   usbhub   usbhub.sys   Sun Apr 13 21:45:36 2008 (480254D0)
b8318000 b8321e80   NDProxy  NDProxy.SYS  Sun Apr 13 21:57:28 2008 (48025798)
b8328000 b832e180   PCIIDEX  PCIIDEX.SYS  Sun Apr 13 21:40:29 2008 (4802539D)
b8330000 b8334d00   PartMgr  PartMgr.sys  Sun Apr 13 21:40:48 2008 (480253B0)
b83e0000 b83e4300   usbohci  usbohci.sys  Sun Apr 13 21:45:34 2008 (480254CE)
b83e8000 b83edc80   usbfilter usbfilter.sys Tue Dec 22 10:26:07 2009 (4B30829F)
b83f0000 b83f7600   usbehci  usbehci.sys  Sun Apr 13 21:45:34 2008 (480254CE)
b83f8000 b83fca80   TDI      TDI.SYS      Sun Apr 13 22:00:04 2008 (48025834)
b8400000 b8404580   ptilink  ptilink.sys  Fri Aug 17 23:49:53 2001 (3B7D8371)
b8408000 b840c080   raspti   raspti.sys   Fri Aug 17 23:55:32 2001 (3B7D84C4)
b8410000 b8416000   kbdclass kbdclass.sys Sun Apr 13 21:39:46 2008 (48025372)
b8418000 b841da00   mouclass mouclass.sys Sun Apr 13 21:39:47 2008 (48025373)
b8440000 b8447d80   usbccgp  usbccgp.sys  Sun Apr 13 21:45:38 2008 (480254D2)
b8450000 b8456180   HIDPARSE HIDPARSE.SYS Sun Apr 13 21:45:22 2008 (480254C2)
b8458000 b845d200   vga      vga.sys      Sun Apr 13 21:44:40 2008 (48025498)
b8460000 b8464a80   Msfs     Msfs.SYS     Sun Apr 13 21:32:38 2008 (480251C6)
b8468000 b846f880   Npfs     Npfs.SYS     Sun Apr 13 21:32:38 2008 (480251C6)
b8470000 b8474280   BS_I2cIo BS_I2cIo.sys Mon Jun 16 04:02:32 2008 (4855BBA8)
b8478000 b847c500   watchdog watchdog.sys Sun Apr 13 21:44:59 2008 (480254AB)
b8498000 b849c880   pnarp    pnarp.sys    Tue Oct 28 07:57:27 2008 (4906A9C7)
b84a0000 b84a4d80   purendis purendis.sys Tue Oct 28 06:31:49 2008 (490695B5)
b84b8000 b84bb000   BOOTVID  BOOTVID.dll  Fri Aug 17 23:49:09 2001 (3B7D8345)
b859c000 b859e900   Dxapi    Dxapi.sys    Fri Aug 17 23:53:19 2001 (3B7D843F)
b85a4000 b85a7d80   serenum  serenum.sys  Sun Apr 13 21:40:12 2008 (4802538C)
b85a8000 b85a9b80   kdcom    kdcom.dll    Fri Aug 17 23:49:10 2001 (3B7D8346)
b85aa000 b85ab100   WMILIB   WMILIB.SYS   Sat Aug 18 00:07:23 2001 (3B7D878B)
b85ac000 b85ad700   dmload   dmload.sys   Fri Aug 17 23:58:15 2001 (3B7D8567)
b85ee000 b85ef100   swenum   swenum.sys   Sun Apr 13 21:39:52 2008 (48025378)
b85f2000 b85f3280   USBD     USBD.SYS     Sat Aug 18 00:02:58 2001 (3B7D8682)
b8600000 b8601f00   Fs_Rec   Fs_Rec.SYS   Fri Aug 17 23:49:37 2001 (3B7D8361)
b8602000 b8603080   Beep     Beep.SYS     Fri Aug 17 23:47:33 2001 (3B7D82E5)
b8604000 b8605080   mnmdd    mnmdd.SYS    Fri Aug 17 23:57:28 2001 (3B7D8538)
b8606000 b8607080   RDPCDD   RDPCDD.sys   Fri Aug 17 23:46:56 2001 (3B7D82C0)
b8608000 b8609100   dump_WMILIB dump_WMILIB.SYS Sat Aug 18 00:07:23 2001 (3B7D878B)
b862e000 b862fa80   ParVdm   ParVdm.SYS   Fri Aug 17 23:49:49 2001 (3B7D836D)
b8670000 b8670d00   pciide   pciide.sys   Fri Aug 17 23:51:49 2001 (3B7D83E5)
b869c000 b869cc00   audstub  audstub.sys  Fri Aug 17 23:59:40 2001 (3B7D85BC)
b86d6000 b86d6b80   Null     Null.SYS     Fri Aug 17 23:47:39 2001 (3B7D82EB)
b8721000 b8721d00   dxgthk   dxgthk.sys   Fri Aug 17 23:53:12 2001 (3B7D8438)
bd000000 bd011600   dxg      dxg.sys      Sun Apr 13 21:38:27 2008 (48025323)
bd012000 bd61e980   nv4_disp nv4_disp.dll Sat Jul 10 00:18:40 2010 (4C379230)
bf800000 bf9c4200   win32k   win32k.sys   Wed Jun 23 16:43:54 2010 (4C220F9A)
bffa0000 bffe5c00   ATMFD    ATMFD.DLL    Tue Apr 20 08:30:07 2010 (4BCD3BDF)
Unloaded modules:
ad99e000 ad9c9000   kmixer.sys
    Checksum:  00000000
    Checksum:  00000000
aed0c000 aed37000   kmixer.sys
    Checksum:  00000000
aee27000 aee4a000   aec.sys
    Checksum:  00000000
b876e000 b876f000   drmkaud.sys
    Checksum:  00000000
af063000 af070000   DMusic.sys
    Checksum:  00000000
af073000 af081000   swmidi.sys
    Checksum:  00000000
b863e000 b8640000   splitter.sys
    Checksum:  00000000
b8178000 b8184000   SysTool.sys
    Checksum:  00000000
b2e0d000 b2e11000   kbdhid.sys
    Checksum:  00000000
b8148000 b8155000   i8042prt.SYS
    Checksum:  00000000
b8448000 b844d000   Cdaudio.SYS
    Checksum:  00000000
b2e1d000 b2e20000   Sfloppy.SYS
    Checksum:  00000000
b8428000 b842d000   Flpydisk.SYS
    Checksum:  00000000
b8420000 b8427000   Fdc.SYS
    Checksum:  00000000
I ran chkdsk /r
I checked the hard drive connection and even changed the cable
But I ran defrag about 5 days ago and I ran memtest about 2 days ago with each stick overnight like you previously suggested and reported that previously.
Do I really need to do that again?
Are there any bios setting I need to look at? The only bios setting I have changed since getting the motherboard it fan calibration because it ran at full speed out of the box.
I ran chkdsk /r
Run Driver Verifier then post new crash dumps after it's enabled:
Alright, we've found the culprit: nv4_mini.sys
BugCheck 10000050, {ffffffff, 1, cbcbcc50, 0}
Unable to load image nv4_mini.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nv4_mini.sys
*** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys
Probably caused by : nv4_mini.sys ( nv4_mini+8cf2b )
So update your chipset drivers for your motherboard from the following link. You want nForce type driver package - not the video GeForce - change the dropdown to suit:
Link Removed - Invalid URL
And Veritas disk manager software was responsible for another. Uninstall that completely.
BugCheck 100000D1, {0, 2, 1, b7f41962}
Probably caused by : dmio.sys ( dmio!dmdbg+2 )
ok, my graphics card is a GeForce 9800 GT
the only option under nForce on the site is nForce 980a SLI .... is that what I need?
I have no idea what Veritas disk manager software is, but I do see dmio.sys in the system file. Should I just delete that file? I'm not sure how to uninstall it because I don't know what it is...?
For now, do only this:
Navigate to C:\Windows\System32\drivers and rename dmio.sys to dmio.BAK.
Reboot and run Ccleaner to clean the registry. That could actually be the only problem.
If new crashes happen, post them before doing anything else.
Actually, I wouldn't even do that. I just checked on it some more and it shows it's from Microsoft.
1: kd> lmvm dmio
start    end        module name
b7f23000 b7f48700   dmio       (pdb symbols)          c:\symcache\dmio.pdb\7DD31474CC0941E9B2175DDBC956E4601\dmio.pdb
    Loaded symbol image file: dmio.sys
    Mapped memory image file: c:\symcache\dmio.sys\4802549D25700\dmio.sys
    Image path: dmio.sys
    Image name: dmio.sys
    Timestamp:        Sun Apr 13 14:44:45 2008 (4802549D)
    CheckSum:         00034FCE
    ImageSize:        00025700
    File version:     2600.5512.503.0
    Product version:  1.0.0.0
    File flags:       0 (Mask 3F)
    File OS:          40004 NT Win32
    File type:        3.7 Driver
    File date:        00000000.00000000
    Translations:     0409.04e4
    CompanyName:      Microsoft Corp., Veritas Software
    ProductName:      VERITAS® NT Disk Manager
    InternalName:     dmio.sys
    OriginalFilename: dmio.sys
    ProductVersion:   1.0
    FileVersion:      2600.5512.503.0
    FileDescription:  NT Disk Manager I/O Driver
    LegalCopyright:   Copyright © 1985-2000 Microsoft Corporation.  All rights reserved.
Portions Copyright © 1997-2000 Veritas Software.  All rights reserved.
You have faulty memory or a bad bios setting involving memory.
ok, I haven't changed any bios settings other than calibrating the cpu fan because it was running full blast out of the box, so I put it on quiet mode. any recommended settings to check?
ok, done. The only thing is that the cpu fan runs constantly at 6000 RPM now. I will have to wait for another cold start to check for blue screens.
Loaded Optimized defaults and cold started and of course more blue screens. It never ends.
Anyone know if Fry's will exchange my mobo, memory, or CPU for the same if it's been 4 months since I bought them there? My nearest Fry's is 2 hours away
Mini101310-11.dmp
BugCheck 4E, {99, 59ad1, 1, 0}
Probably caused by : memory_corruption ( nt!MiDecrementShareCount+3a )
Mini101310-10.dmp
BugCheck 1000007E, {c0000005, 2e73a392, b8513a9c, b8513798}
Probably caused by : HTTP.sys ( HTTP+2b6b2 )
Update all your motherboard drivers, such as:
BIOSTAR I2C I/O driver flles
Set all your hardware clocks standard, and test hardware - memory, hdd. If crashes persist, reformat and reinstall. If the memory is fine, upgrade bios.
Loading Dump File [F:\a\Minidump\D M P\Mini101310-09.dmp]
Machine Name:
Debug session time: Thu Oct 14 07:25:40.812 2010 (GMT-5)
System Uptime: 0 days 0:00:21.799
BugCheck 4E, {99, 5ad67, 1, 0}
1: kd> !analyze -v
Arguments:
Arg1: 00000099, A PTE or PFN is corrupt
Arg2: 0005ad67, page frame number
Arg3: 00000001, current page state
Arg4: 00000000, 0
Debugging Details:
BUGCHECK_STR:  0x4E_99
CUSTOMER_CRASH_COUNT:  9
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
PROCESS_NAME:  MsMpEng.exe
LAST_CONTROL_TRANSFER:  from 80522dfc to 804f9f43
STACK_TEXT:
af324794 80522dfc 0000004e 00000099 0005ad67 nt!KeBugCheckEx+0x1b
af3247c4 8051a59d c0039338 c0039340 89605820 nt!MiDecrementShareCount+0x3a
af324860 8051aa4e af3249ac 00000067 89605820 nt!MiProcessValidPteList+0x9b
af324ca4 805b34e6 07268000 c0039338 89605820 nt!MiDecommitPages+0x3f0
af324d4c 8054164c ffffffff 00adf874 00adf878 nt!NtFreeVirtualMemory+0x588
af324d4c 7c90e514 ffffffff 00adf874 00adf878 nt!KiFastCallEntry+0xfc
00adf820 00000000 00000000 00000000 00000000 0x7c90e514
STACK_COMMAND:  kb
FOLLOWUP_IP:
80522dfc ff4e08          dec     dword ptr [esi+8]
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiDecrementShareCount+3a
MODULE_NAME: nt
FAILURE_BUCKET_ID:  0x4E_99_nt!MiDecrementShareCount+3a
Loading Dump File [F:\a\Minidump\D M P\Mini101310-10.dmp]
Machine Name:
Debug session time: Thu Oct 14 07:26:26.031 2010 (GMT-5)
System Uptime: 0 days 0:00:22.650
Unable to load image HTTP.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for HTTP.sys
*** ERROR: Module load completed but symbols could not be loaded for HTTP.sys
2: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
happening.
Arguments:
Arg2: 2e73a392, The address that the exception occurred at
Arg3: b8513a9c, Exception Record Address
Arg4: b8513798, Context Record Address
Debugging Details:
FAULTING_IP:
+16
2e73a392 ??              ???
EXCEPTION_RECORD:  b8513a9c -- (.exr 0xffffffffb8513a9c)
ExceptionAddress: 2e73a392
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000008
   Parameter[1]: 2e73a392
Attempt to execute non-executable address 2e73a392
CONTEXT:  b8513798 -- (.cxr 0xffffffffb8513798)
eax=ae74cd53 ebx=00000003 ecx=0000000d edx=00000031 esi=8053058a edi=00000000
eip=2e73a392 esp=b8513b64 ebp=b8513ba8 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
2e73a392 ??              ???
CUSTOMER_CRASH_COUNT:  10
PROCESS_NAME:  System
ERROR_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_PARAMETER1:  00000008
EXCEPTION_PARAMETER2:  2e73a392
WRITE_ADDRESS:  2e73a392
FOLLOWUP_IP:
HTTP+2b6b2
ae7596b2 ??              ???
FAILED_INSTRUCTION_ADDRESS:
+2b6b2
2e73a392 ??              ???
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from ae7596b2 to 2e73a392
STACK_TEXT:
b8513b60 ae7596b2 ae74cd53 0000000d 00000000 0x2e73a392
b8513ba8 ae73a986 00000001 f6fd49b4 01cb6b57 HTTP+0x2b6b2
b8513be0 ae73a9d0 ae768ccb 89b61348 e187319a HTTP+0xc986
b8513c84 80581377 89b61348 89007000 00000000 HTTP+0xc9d0
b8513d54 80581487 80000cf4 00000001 00000000 nt!IopLoadDriver+0x66d
b8513d7c 8053879d 80000cf4 00000000 89e3e3c8 nt!IopLoadUnloadDriver+0x45
b8513dac 805cff62 aef36cf4 00000000 00000000 nt!ExpWorkerThread+0xef
b8513ddc 8054612e 805386ae 00000001 00000000 nt!PspSystemThreadStartup+0x34
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
SYMBOL_NAME:  HTTP+2b6b2
MODULE_NAME: HTTP
IMAGE_NAME:  HTTP.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4adde33f
STACK_COMMAND:  .cxr 0xffffffffb8513798 ; kb
FAILURE_BUCKET_ID:  0x7E_BAD_IP_HTTP+2b6b2
Loading Dump File [F:\a\Minidump\D M P\Mini101310-11.dmp]
Machine Name:
Debug session time: Thu Oct 14 07:27:11.671 2010 (GMT-5)
System Uptime: 0 days 0:00:23.670
3: kd> !analyze -v
Arguments:
Arg2: 00059ad1, page frame number
Arg4: 00000000, 0
Debugging Details:
CUSTOMER_CRASH_COUNT:  11
STACK_TEXT:
af31f794 80522dfc 0000004e 00000099 00059ad1 nt!KeBugCheckEx+0x1b
af31f7c4 8051a59d c002a5b0 c002a5b8 89bcaa80 nt!MiDecrementShareCount+0x3a
af31f860 8051aa4e af31f8d0 00000077 89bcaa80 nt!MiProcessValidPteList+0x9b
af31fca4 805b34e6 054b7000 c002a5b0 89bcaa80 nt!MiDecommitPages+0x3f0
af31fd4c 8054164c ffffffff 00adf8bc 00adf8c0 nt!NtFreeVirtualMemory+0x588
af31fd4c 7c90e514 ffffffff 00adf8bc 00adf8c0 nt!KiFastCallEntry+0xfc
00adf868 00000000 00000000 00000000 00000000 0x7c90e514
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
ae72e000 ae76ee00   HTTP     HTTP.sys     Tue Oct 20 19:20:15 2009 (4ADDE33F)
aeb09000 aeb33180   kmixer   kmixer.sys   Sun Apr 13 21:45:07 2008 (480254B3)
aeb34000 aeb56d00   aec      aec.sys      Thu May 24 22:53:32 2007 (4655ED3C)
aeb57000 aeb6b480   wdmaud   wdmaud.sys   Sun Apr 13 22:17:18 2008 (48025C3E)
aeddc000 aede8e80   DMusic   DMusic.sys   Sun Apr 13 21:45:00 2008 (480254AC)
aee3c000 aee92800   srv      srv.sys      Mon Jun 21 18:27:09 2010 (4C1F84CD)
aefab000 aefd7180   mrxdav   mrxdav.sys   Sun Apr 13 21:32:42 2008 (480251CA)
af330000 af333900   ndisuio  ndisuio.sys  Sun Apr 13 21:55:57 2008 (4802573D)
af638000 af64f900   dump_atapi dump_atapi.sys Sun Apr 13 21:40:29 2008 (4802539D)
af678000 af728f00   rt2870   rt2870.sys   Mon Aug 03 05:57:37 2009 (4A765221)
af751000 af7c0400   mrxsmb   mrxsmb.sys   Wed Feb 24 15:11:05 2010 (4B852569)
af7c1000 af7ebe80   rdbss    rdbss.sys    Sun Apr 13 22:28:38 2008 (48025EE6)
af7ec000 af80dd00   afd      afd.sys      Thu Aug 14 13:04:35 2008 (48A40333)
af80e000 af833500   ipnat    ipnat.sys    Sun Apr 13 21:57:10 2008 (48025786)
af834000 af85bc00   netbt    netbt.sys    Sun Apr 13 22:20:59 2008 (48025D1B)
af85c000 af8b4480   tcpip    tcpip.sys    Fri Jun 20 14:51:09 2008 (485B99AD)
af8b5000 af8c7600   ipsec    ipsec.sys    Sun Apr 13 22:19:42 2008 (48025CCE)
af8e8000 af90b000   MpFilter MpFilter.sys Sat Mar 20 06:03:26 2010 (4BA4490E)
af92f000 af931900   Dxapi    Dxapi.sys    Fri Aug 17 23:53:19 2001 (3B7D843F)
af93f000 af941f80   mouhid   mouhid.sys   Fri Aug 17 23:47:57 2001 (3B7D82FD)
af943000 af946900   kbdhid   kbdhid.sys   Sun Apr 13 21:39:47 2008 (48025373)
af957000 af959880   hidusb   hidusb.sys   Sun Apr 13 21:45:27 2008 (480254C7)
af95b000 af97ea80   portcls  portcls.sys  Sun Apr 13 22:19:40 2008 (48025CCC)
af97f000 aff7e000   RtkHDAud RtkHDAud.sys Fri Apr 30 11:56:08 2010 (4BDA9B28)
aff96000 aff99580   BIOS     BIOS.sys     Wed Mar 16 08:23:52 2005 (4237D0F8)
b2e12000 b2e14280   rasacd   rasacd.sys   Fri Aug 17 23:55:39 2001 (3B7D84CB)
b2e45000 b2ea2f00   update   update.sys   Sun Apr 13 21:39:46 2008 (48025372)
b2ea3000 b2ed2e80   rdpdr    rdpdr.sys    Sun Apr 13 21:32:50 2008 (480251D2)
b2ed3000 b2ee3e00   psched   psched.sys   Sun Apr 13 21:56:36 2008 (48025764)
b2ee4000 b2efa580   ndiswan  ndiswan.sys  Sun Apr 13 22:20:41 2008 (48025D09)
b2efb000 b2f0e900   parport  parport.sys  Sun Apr 13 21:40:09 2008 (48025389)
b2f0f000 b2f37000   HDAudBus HDAudBus.sys Thu May 26 18:46:29 2005 (4295EF55)
b2f37000 b2f5a200   USBPORT  USBPORT.SYS  Sun Apr 13 21:45:34 2008 (480254CE)
b2f5b000 b2f7d700   ks       ks.sys       Sun Apr 13 22:16:34 2008 (48025C12)
b2f7e000 b2f91f00   VIDEOPRT VIDEOPRT.SYS Sun Apr 13 21:44:39 2008 (48025497)
b2f92000 b39aee60   nv4_mini nv4_mini.sys Sat Jul 10 00:19:49 2010 (4C379275)
b8128000 b8130700   wanarp   wanarp.sys   Sun Apr 13 21:57:20 2008 (48025790)
b8138000 b8140780   netbios  netbios.sys  Sun Apr 13 21:56:01 2008 (48025741)
b8148000 b8156d80   sysaudio sysaudio.sys Sun Apr 13 22:15:55 2008 (48025BEB)
b8158000 b8162e00   Fips     Fips.SYS     Sun Apr 13 21:33:27 2008 (480251F7)
b8178000 b8187900   Cdfs     Cdfs.SYS     Sun Apr 13 22:14:21 2008 (48025B8D)
b8188000 b8191000   HIDCLASS HIDCLASS.SYS Sun Apr 13 21:45:25 2008 (480254C5)
b81a8000 b81b5d00   swmidi   swmidi.sys   Sun Apr 13 21:45:07 2008 (480254B3)
b8238000 b8240c00   processr processr.sys Sun Apr 13 21:31:29 2008 (48025181)
b8248000 b8252480   imapi    imapi.sys    Sun Apr 13 21:40:57 2008 (480253B9)
b8258000 b8267600   cdrom    cdrom.sys    Sun Apr 13 21:40:45 2008 (480253AD)
b8268000 b8276100   redbook  redbook.sys  Sun Apr 13 21:40:27 2008 (4802539B)
b8278000 b8287c00   serial   serial.sys   Sun Apr 13 22:15:44 2008 (48025BE0)
b8288000 b8294880   rasl2tp  rasl2tp.sys  Sun Apr 13 22:19:43 2008 (48025CCF)
b8298000 b82a2200   raspppoe raspppoe.sys Sun Apr 13 21:57:31 2008 (4802579B)
b82a8000 b82b3d00   raspptp  raspptp.sys  Sun Apr 13 22:19:47 2008 (48025CD3)
b82b8000 b82c0900   msgpc    msgpc.sys    Sun Apr 13 21:56:32 2008 (48025760)
b82c8000 b82d1f00   termdd   termdd.sys   Sun Apr 13 21:38:36 2008 (4802532C)
b82d8000 b82e6880   usbhub   usbhub.sys   Sun Apr 13 21:45:36 2008 (480254D0)
b82e8000 b82f1e80   NDProxy  NDProxy.SYS  Sun Apr 13 21:57:28 2008 (48025798)
b8308000 b8316b00   drmk     drmk.sys     Sun Apr 13 21:45:12 2008 (480254B8)
b83c8000 b83cc300   usbohci  usbohci.sys  Sun Apr 13 21:45:34 2008 (480254CE)
b83d0000 b83d5c80   usbfilter usbfilter.sys Tue Dec 22 10:26:07 2009 (4B30829F)
b83d8000 b83df600   usbehci  usbehci.sys  Sun Apr 13 21:45:34 2008 (480254CE)
b83e0000 b83e4a80   TDI      TDI.SYS      Sun Apr 13 22:00:04 2008 (48025834)
b83e8000 b83ec580   ptilink  ptilink.sys  Fri Aug 17 23:49:53 2001 (3B7D8371)
b83f0000 b83f4080   raspti   raspti.sys   Fri Aug 17 23:55:32 2001 (3B7D84C4)
b83f8000 b83fe000   kbdclass kbdclass.sys Sun Apr 13 21:39:46 2008 (48025372)
b8400000 b8405a00   mouclass mouclass.sys Sun Apr 13 21:39:47 2008 (48025373)
b8438000 b843e180   HIDPARSE HIDPARSE.SYS Sun Apr 13 21:45:22 2008 (480254C2)
b8440000 b8445200   vga      vga.sys      Sun Apr 13 21:44:40 2008 (48025498)
b8448000 b844ca80   Msfs     Msfs.SYS     Sun Apr 13 21:32:38 2008 (480251C6)
b8450000 b8457880   Npfs     Npfs.SYS     Sun Apr 13 21:32:38 2008 (480251C6)
b8458000 b845c280   BS_I2cIo BS_I2cIo.sys Mon Jun 16 04:02:32 2008 (4855BBA8)
b8460000 b8467d80   usbccgp  usbccgp.sys  Sun Apr 13 21:45:38 2008 (480254D2)
b8468000 b846c500   watchdog watchdog.sys Sun Apr 13 21:44:59 2008 (480254AB)
b8478000 b847c880   pnarp    pnarp.sys    Tue Oct 28 07:57:27 2008 (4906A9C7)
b8480000 b8484d80   purendis purendis.sys Tue Oct 28 06:31:49 2008 (490695B5)
b857c000 b857fd80   serenum  serenum.sys  Sun Apr 13 21:40:12 2008 (4802538C)
b8580000 b8582280   wmiacpi  wmiacpi.sys  Sun Apr 13 21:36:37 2008 (480252B5)
b8584000 b8586780   ndistapi ndistapi.sys Sun Apr 13 21:57:27 2008 (48025797)
b85a0000 b85a3c80   mssmbios mssmbios.sys Sun Apr 13 21:36:45 2008 (480252BD)
b85c6000 b85c7100   swenum   swenum.sys   Sun Apr 13 21:39:52 2008 (48025378)
b85ca000 b85cb280   USBD     USBD.SYS     Sat Aug 18 00:02:58 2001 (3B7D8682)
b85de000 b85dff00   Fs_Rec   Fs_Rec.SYS   Fri Aug 17 23:49:37 2001 (3B7D8361)
b85e0000 b85e1080   Beep     Beep.SYS     Fri Aug 17 23:47:33 2001 (3B7D82E5)
b85e2000 b85e3080   mnmdd    mnmdd.SYS    Fri Aug 17 23:57:28 2001 (3B7D8538)
b85e4000 b85e5080   RDPCDD   RDPCDD.sys   Fri Aug 17 23:46:56 2001 (3B7D82C0)
b85e6000 b85e7100   dump_WMILIB dump_WMILIB.SYS Sat Aug 18 00:07:23 2001 (3B7D878B)
b860e000 b860fa80   ParVdm   ParVdm.SYS   Fri Aug 17 23:49:49 2001 (3B7D836D)
b865e000 b865f880   splitter splitter.sys Sun Apr 13 21:45:07 2008 (480254B3)
b8697000 b8697b80   Null     Null.SYS     Fri Aug 17 23:47:39 2001 (3B7D82EB)
b8719000 b8719b80   drmkaud  drmkaud.sys  Sun Apr 13 21:45:13 2008 (480254B9)
b873e000 b873ed00   dxgthk   dxgthk.sys   Fri Aug 17 23:53:12 2001 (3B7D8438)
b87d1000 b87d1c00   audstub  audstub.sys  Fri Aug 17 23:59:40 2001 (3B7D85BC)
Unloaded modules:
b8148000 b8154000   SysTool.sys
    Checksum:  00000000
b2e16000 b2e1a000   kbdhid.sys
    Checksum:  00000000
b8318000 b8325000   i8042prt.SYS
    Checksum:  00000000
b8430000 b8435000   Cdaudio.SYS
    Checksum:  00000000
b2e26000 b2e29000   Sfloppy.SYS
    Checksum:  00000000
b8418000 b841d000   Flpydisk.SYS
    Checksum:  00000000
b8410000 b8417000   Fdc.SYS
    Checksum:  00000000
