I suspect it may be the 2/3rd HDDs. They are Samsung 204UI rain in RAID 0 and seem be slow to detect after a crash. See dumps & files.
https://dl.dropbox.com/u/11121327/dan7u.zip
* Bugcheck Analysis *
BugCheck F4, {3, fffffa8009d50b30, fffffa8009d50e10, fffff80002f8c460}
Probably caused by : wininit.exe
Followup: MachineOwner
At work we run diagnostics on every system that we take in for repair (before we even start working on it). At a minimum, please run the free diagnostics here: Initial Hardware Diagnostics. For more in-depth diagnostics, please run those listed here: Hardware Diagnostics
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
10 Nov 2012 - I'm seeing an upswing in SSD errors - but most appear due to older storage controller drivers. I strongly suggest NOT using storage controller drivers that don't date from 2012 (if none are available, don't connect an SSD to that controller)
[font=lucida console]**************************Sat Dec 15 01:28:30.226 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\121412-6988-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:42:57.038[/B]
Probably caused by :[B]wininit.exe[/B]
BugCheck [B]F4, {3, fffffa8009ddfb30, fffffa8009ddfe10, fffff80002f94460}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000F4]CRITICAL_OBJECT_TERMINATION (f4)[/url]
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8009ddfb30, Terminating object
Arg3: fffffa8009ddfe10, Process image file name
Arg4: fffff80002f94460, Explanatory message (ascii)
PROCESS_NAME: [B]wininit.exe[/B]
BUGCHECK_STR: 0xF4_c0000005
FAILURE_BUCKET_ID: [B]X64_0xF4_c0000005_IMAGE_wininit.exe[/B]
CPUID: "Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz"
MaxSpeed: 3100
CurrentSpeed: [B]3093[/B]
BIOS Version F10
BIOS Release Date 02/23/2012
Manufacturer Gigabyte Technology Co., Ltd.
Product Name Z68MA-D2H-B3
**************************Sun Dec 9 04:42:32.790 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120912-10342-01.dmp]
System Uptime:[B]0 days 0:10:49.070[/B]
BugCheck [B]F4, {3, fffffa8009de6b30, fffffa8009de6e10, fffff80002fda460}[/B]
Arguments:
Arg2: fffffa8009de6b30, Terminating object
Arg3: fffffa8009de6e10, Process image file name
Arg4: fffff80002fda460, Explanatory message (ascii)
MaxSpeed: 3100
BIOS Version F10
**************************Sun Dec 2 01:59:02.258 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120112-8096-01.dmp]
System Uptime:[B]0 days 0:50:50.070[/B]
BugCheck [B]F4, {3, fffffa8009d56b30, fffffa8009d56e10, fffff80002f98460}[/B]
Arguments:
Arg2: fffffa8009d56b30, Terminating object
Arg3: fffffa8009d56e10, Process image file name
Arg4: fffff80002f98460, Explanatory message (ascii)
BUGCHECK_STR: 0xF4_IOERR
FAILURE_BUCKET_ID: [B]X64_0xF4_IOERR_IMAGE_wininit.exe[/B]
MaxSpeed: 3100
BIOS Version F10
[/font]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
pbfilter.sys Thu Oct 14 21:39:45 2010 (4CB7B0E1)
iaStor.sys Fri May 20 12:52:24 2011 (4DD69C48)
EtronXHCI.sys Thu Aug 4 18:00:24 2011 (4E3B1678)
EtronHub3.sys Thu Aug 4 18:00:28 2011 (4E3B167C)
Rt64win7.sys Tue Aug 23 09:55:41 2011 (4E53B15D)
RTKVHD64.sys Tue Aug 30 05:24:37 2011 (4E5CAC55)
[COLOR=RED][B]AppleCharger.sys Tue Nov 1 22:46:00 2011 (4EB0AEE8)[/B][/COLOR]
IntcDAud.sys Tue Dec 6 06:23:07 2011 (4EDDFB1B)
igdkmd64.sys Thu Jan 5 22:36:45 2012 (4F066C4D)
MpFilter.sys Thu Aug 23 19:03:14 2012 (5036B6B2)
ssudbus.sys Thu Jul 26 21:15:16 2012 (5011EBA4)
[/font]
