Windows 8 BSOD mainly after sleep/hibernation and bluetooth short mouse freeze problems
maja
I am having BSOD mainly after sleep/hibernation. But the problem started to occur more frequently and yesterday it happened when I was using my compuer.
At the begining I came in the morning to wake my PC and would find that it is already on (without any bsod message). But my applications were closed as if the computer was rapidly rebooted. It happened at night. Perhaps there was a planned task that I later turned off. I mean the task waked the comuper, an error occured and restarted the message without me seeing bsod. (Of course this might only be my imagination).
EDIT:
Sometimes when I found the computer on in the morning there a black screen with a message that there was no drive detected (exactly 0 drives and asking for a booting device). But when I pressed power on button the computer would wake perfectly fine without any problems, just as I left it the day before (and without loosing my data).
Right from the beginning I had bluetooth short mouse freeze problems. The mouse freezes and after a delay it accelerates quickly. Sometimes freezes are short that it only worsens accuracy and sometimes even 2 seconds. But mainly short freezez occur.
I checked that I have no such option in my mouse drivers as energy management. It is an A4tech bluetooth mouse G7-600NX. I have no problems with this mouse on Windows 7. And the drivers seem to work fine, since the dpi adjustment works for me.
I thought that the problem might by GPU: AMD Fire Pro v5900. But when I use ArchiCAD in 3D window there are no delays (I would say the card is much better than I need). And I installed latest drivers. When I downloaded the drivers again a few days ago, the installation went on quickly and finished. Then a communicate went on screen (that I should have run it as an administrator). So I tried to install the drivers as administrator but after the installation finished there was no "successfully installed window" (no idea why). But nothing changed (for better or worse).
When I tried to plug a wired mouse (some cheep one), it would install and work for 2 minutes. Then the USB socket was disabled until a reboot. So I switched the mouse from USB socket to socket. And in one socket it worked for 2 hours. And then it stopped. Once it stopped even my keyboard (Microsoft keybord).
I can't say why my SSD drive could make problems since it is an Intel SSD which got a reward on tom's hardware.
All the drivers that I have were downloaded from internet in late February 2013.
Some of them I reinstalled in an effort to stop BSODs.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): Link Removed (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
Drivers...
usasma
Fantastic Member
Drivers from Microsoft Security Essentials are showing in the memory dumps also.
Please:
1) Uninstall/reinstall Microsoft Security Essentials.
2) Please perform a couple of the free scans here to be sure that no virus' have slipped through: Link Removed
ASUSFILTER.sys Tue Sep 20 11:46:33 2011 (4E78B559)
ASUS USB Hub filter driver
WibuKey64.sys Thu Sep 22 07:24:10 2011 (4E7B1ADA)
WIBU-KEY Windows NT Kernel Driver for WIBU-KEY Software Protection System
Rt630x64.sys Wed Oct 19 08:12:55 2011 (4E9EBEC7)
Realtek PCI/PCIe Adapters
AiChargerPlus.sys Wed Apr 18 21:17:35 2012 (4F8F67AF)
Asus Charger Driver [br] Likely BSOD cause - haven't seen recently (15Jan2013)
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sat Mar 23 15:20:49.545 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032313-7125-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]0 days 5:58:39.143[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2337e )[/B]
BugCheck [B]7A, {4, 0, fffffa80125d0830, 5b4ae0914f}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: 0000000000000004, lock type that was held (value 1,2,3, or PTE address)
Arg2: 0000000000000000, error status (normally i/o status code)
Arg3: fffffa80125d0830, current process (virtual address for lock type 3, or PTE)
Arg4: 0000005b4ae0914f, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
BUGCHECK_STR:  0x7a_0
PROCESS_NAME:  dwm.exe
FAILURE_BUCKET_ID: [B]0x7a_0_nt!_??_::FNODOBFM::_string_[/B]
CPUID:        "Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz"
MaxSpeed:     3300
CurrentSpeed: [B]3310[/B]
  BIOS Version                  1708
  BIOS Release Date             11/09/2012
**************************Sat Mar 23 09:21:48.537 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032313-7156-01.dmp]
System Uptime:[B]0 days 1:44:00.630[/B]
Probably caused by :[B]memory_corruption ( nt!MiRevertValidPte+1e2 )[/B]
BugCheck [B]A, {10, 2, 1, fffff8021630d7a2}[/B]
Arguments:
Arg1: 0000000000000010, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff8021630d7a2, address which referenced memory
BUGCHECK_STR:  AV
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
PROCESS_NAME:  ArchiCAD.exe
FAILURE_BUCKET_ID: [B]AV_nt!MiRevertValidPte[/B]
MaxSpeed:     3300
  BIOS Version                  1708
**************************Sat Mar 23 07:37:25.562 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032313-6375-01.dmp]
System Uptime:[B]0 days 3:19:11.274[/B]
BugCheck [B]7A, {4, 0, fffffa80155c6010, e56cec59e0}[/B]
Arguments:
Arg3: fffffa80155c6010, current process (virtual address for lock type 3, or PTE)
Arg4: 000000e56cec59e0, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  MsMpEng.exe
MaxSpeed:     3300
  BIOS Version                  1708
**************************Fri Mar 22 12:13:41.574 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032213-7093-01.dmp]
System Uptime:[B]0 days 6:36:55.267[/B]
BugCheck [B]7A, {4, 0, fffffa80100793e0, fffff8a0025b4026}[/B]
Arguments:
Arg3: fffffa80100793e0, current process (virtual address for lock type 3, or PTE)
Arg4: fffff8a0025b4026, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  svchost.exe
MaxSpeed:     3300
  BIOS Version                  1708
**************************Sun Mar 17 06:24:48.321 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031713-10187-01.dmp]
System Uptime:[B]1 days 15:44:03.233[/B]
BugCheck [B]7A, {4, 0, fffffa801362d010, fffff8a005826c7e}[/B]
Arguments:
Arg3: fffffa801362d010, current process (virtual address for lock type 3, or PTE)
Arg4: fffff8a005826c7e, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  wmpnetwk.exe
MaxSpeed:     3300
  BIOS Version                  1708
**************************Wed Mar 13 07:54:12.639 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031313-7156-01.dmp]
System Uptime:[B]3 days 15:05:55.533[/B]
BugCheck [B]7A, {4, 0, fffffa8012fbb290, 76c86f69f8}[/B]
Arguments:
Arg3: fffffa8012fbb290, current process (virtual address for lock type 3, or PTE)
Arg4: 00000076c86f69f8, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
MaxSpeed:     3300
  BIOS Version                  1708
**************************Sat Mar  9 16:46:43.148 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-10796-01.dmp]
System Uptime:[B]6 days 9:09:12.756[/B]
BugCheck [B]7A, {4, 0, fffffa801d543700, 62fcc3ae90}[/B]
Arguments:
Arg3: fffffa801d543700, current process (virtual address for lock type 3, or PTE)
Arg4: 00000062fcc3ae90, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  lsass.exe
MaxSpeed:     3300
  BIOS Version                  1708
**************************Sat Mar  2 00:15:14.598 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030213-6187-01.dmp]
System Uptime:[B]2 days 5:13:01.622[/B]
BugCheck [B]7A, {4, 0, fffffa80158ebe00, fffff8a0033c8c9e}[/B]
Arguments:
Arg3: fffffa80158ebe00, current process (virtual address for lock type 3, or PTE)
Arg4: fffff8a0033c8c9e, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
MaxSpeed:     3300
  BIOS Version                  1708
**************************Wed Feb 27 05:22:26.667 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022713-7078-01.dmp]
System Uptime:[B]0 days 13:31:57.366[/B]
BugCheck [B]7A, {4, 0, fffffa800d6272b0, 7bcfa660bd}[/B]
Arguments:
Arg3: fffffa800d6272b0, current process (virtual address for lock type 3, or PTE)
Arg4: 0000007bcfa660bd, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
MaxSpeed:     3300
  BIOS Version                  1708
**************************Tue Feb 26 15:49:53.921 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022613-7171-01.dmp]
System Uptime:[B]2 days 20:33:47.770[/B]
BugCheck [B]7A, {4, 0, fffffa800d7e5af0, fffff8a004410554}[/B]
Arguments:
Arg3: fffffa800d7e5af0, current process (virtual address for lock type 3, or PTE)
Arg4: fffff8a004410554, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  LogonUI.exe
MaxSpeed:     3300
  BIOS Version                  1708
[/FONT]
3rd Party Drivers:
MpKsl7546ca96.sys           Fri Sep 16 18:25:48 2011 (4E73CCEC)
[B]ASUSFILTER.sys              Tue Sep 20 11:46:33 2011 (4E78B559)[/B]
[B]WibuKey64.sys               Thu Sep 22 07:24:10 2011 (4E7B1ADA)[/B]
[B]Rt630x64.sys                Wed Oct 19 08:12:55 2011 (4E9EBEC7)[/B]
a98rmz8n.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
[B]AiChargerPlus.sys           Wed Apr 18 21:17:35 2012 (4F8F67AF)[/B]
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
iaStorA.sys                 Mon Jul  9 16:42:33 2012 (4FFB4239)
dump_iaStorA.sys            Mon Jul  9 16:42:33 2012 (4FFB4239)
RTKVHD64.sys                Tue Aug  7 06:49:39 2012 (5020F2C3)
[B]sptd.sys                    Sat Aug 18 17:05:38 2012 (503003A2)[/B]
asmtxhci.sys                Mon Aug 20 08:28:15 2012 (50322D5F)
asmthub3.sys                Mon Aug 20 08:28:29 2012 (50322D6D)
AtihdW86.sys                Tue Aug 21 22:26:37 2012 (5034435D)
AsIO.sys                    Wed Aug 22 05:54:47 2012 (5034AC67)
intelppm.sys                Mon Nov  5 22:55:02 2012 (50988A16)
atikmdag.sys                Tue Nov 20 22:18:06 2012 (50AC47EE)
atikmpag.sys                Tue Nov 20 22:46:39 2012 (50AC4E9F)
ayytbj8b.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
abgz80q9.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
ae70u8x3.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
awrumyu1.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
MpKsl0a079ad8.sys           Fri Sep 16 18:25:48 2011 (4E73CCEC)
auwgnzzs.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
MpKsld4b16a7b.sys           Fri Sep 16 18:25:48 2011 (4E73CCEC)
a9x69dvx.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
a9et2mb2.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
avah4iqt.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
ak6msug1.SYS                Tue Dec 27 17:30:45 2011 (4EFA4715)
[/FONT]
MpKsl7546ca96.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a98rmz8n.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ayytbj8b.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
abgz80q9.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ae70u8x3.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
awrumyu1.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
MpKsl0a079ad8.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
auwgnzzs.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
MpKsld4b16a7b.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a9x69dvx.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a9et2mb2.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
avah4iqt.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ak6msug1.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
maja
Thank you very much. Now I have a lot to think of :) I will analyze everything and let know if BSOD problem was solved. Unless I understand your instruction I will post some questions :)
maja
As for now I was able to perform
ASUS ROOT HUB driver update, USB 3.0 Boost update
Realtek PCI/PCIe update
I was unable to uninstall AiChargerPlus.sys ... It is probably impossible without unsinstalling the whole AI Suite. Some people suggested using Revo software with no success (it was very useful with other stuff).
No luck with WibuKey64. There were no options for Windows 8 update. Any clues how to do it safely?
So, to help others having same problems:
1)
This problem occured to me not that often, so I ignored it. I week ago or something (October 2013) there was an update of my Intel SSD 520 120GB. And the problem disappeared! For now.
2) I suffered from "power supply surges" that occured more often recently. It was before the system Was able to start. After that message I had to use power button (in windows it responsible for "hibernate function"). And system would start of course and everything would be fine (with a windows communicate: "System Has Recovered from a Serious Error ...
Well, for me it Was a sure message every morning.
I don't know for sure, but I think I have Secure Boot turned on in Bios and as it says about my Asus motherboard P8Z77-M Pro: "The current build of Lucid Virtu Universal MVP software does not support Windows 8 Secure Boot function."
So, I will have to check it out.
3) Bluetooth and cable mouse problems: not solved. My A4tech bluetooth mouse was crazy, my noname cable mouse would switch off (and freeze usb socket). So I borrowed Logitech M-BZ105A mouse from my father and had no problems with that.
4) BSOD - I will have to wait some time to be sure that they are gone.
I will let you know.
maja
1)
So, I will have to check it out, however I don't use this Lucid Virtu... I have AMD Firepro v5900 GPU. So, is there anything in common??
EDIT: Too bad, but this morning my PC would do the same thing. "Power supply surges". And again system restarted after a serious problem.
badrobot
You might also want to change your power setting to "never" sleep.It is a good power saving feature but very troublesome with hardwares. The hard drive being not detected could also be due to auto off. Disable that feature also from power management.
maja
Well, my computer never sleeps as it hibernates. So it is different to "sleep"?
And I forgot. Probably the most important thing was UNINSTALLING DAEMON TOOLS.
After uninstalling daemon lite there were no problems with start up. But didn't test more.
I can't be sure though.
maja
Two days without BSOD. I removed some USB cables that weren't attached to any media. No problems so far. Perhaps a hanging USB cable implied "power suppy surges", I mean some potential differences that my motherboard detects? I sound weird, but like Sherlock Holmes says: "if you eliminate the impossible whatever remains however improbable must be the truth"
maja
After some time I have to say, that DAEMON TOOLS was not the problem.
There was no real software problem though. My OCZ Stealth X Stream 600 W (awarded by hardware secrets) caused the problems. I replaced it with a no-name 400 W (paid $12 for it). OCZ has a due warranty, so I will probably have it replaced.
Just before my decision to replace the power supply unit I had colorful screen during startup (software working fine, system getting up). So I blamed GPU. On the other hand I thought "why asus anti surge shouts at me?". And sending supply unit, GPU and motherboard to service <=> not having PC for 3 weeks (being unemploed for 3 weeks).
Now, I even hear the difference during start up. And ASUS anti surge system worked for me :) It's been just 3 days, so I will wait 2 more to be sure :)
