BSOD... Out of ideas.
Trouble
Noob Whisperer
We can't do anything with the information you've provided, so....
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here How to ask for help with a BSOD problem
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area http://windows7forums.com/windows-7...you-filling-your-system-specs.html#post235529 .
Good luck
Randy
Hey there ! Sorry I was too frustrated so I went straight to the headache ;-)
However I have a zip file now with everything ( I hope )
How do I attach it to thi tread?
Trouble
Noob Whisperer
I would start by going here ASUS - Notebooks- ASUS K50IJ
Catch up all drivers to most current version available for your product. Additionally your BIOS version is a bit dated
Version 207 05/08/2009
There have been six revisions since that version so you may want to consider catching up to the latest (according to their note version212 added Win7 Support).
After which I might suggest considering updating Windows 7 to Service Pack 1, after first checking your system using this
UPDATE READINESS TOOL.
Download and install the correct system readiness tool prior to installing SP1.
System Update Readiness Tool for 32bit (x86)
System Update Readiness Tool for 64bit (x64)
Update these two drivers
L1E62x86.sys 6/11/2009 Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller from here ATHEROS drivers for Microsoft Windows (Atheros?????)
and
athr.sys 6/9/2009 Atheros Extensible Wireless LAN driver for CB42/CB43/MB42/MB43 Network Adapter from here ATHEROS drivers for Microsoft Windows (Atheros?????)
