BSOD Please Help!!
Hi and thanks in advance
I think i have followed all the new thread instruction and have attached everything required
So far i have only tried a system restore but that was a fail
BSOD only shows up when i try to login normally .... computer runs fine when in safe mode i left it on all day while i was at work to see if it would restart itself again but all good
I can't get CUPID screen shot as i get an error in safe mode trying to use it and has no info in mem and spd and i can't sign into none safe mode for long enough to get a screen shot
attached is all the dump files and SF diagnostic tool file
thanks jamie
View attachment dump files.zip
View attachment Seven Forums.zip
Hey Jamie, you are welcome to the forums. : )
011711-18688-01.dmp
IRQL_NOT_LESS_OR_EQUAL (a)
This is usually
caused by drivers using improper addresses
Probably caused by : ntkrnlmp.exe ( [B]nt!ObpQueryNameString[/B]+4ed )
1. Update drivers:
WD External Storage WD SCSI Architecture Model (SAM) driver
Western Digital Technologies
-> wdcsam.sys Wed Apr 16 04:39:08 2008
Logitech Webcam
->lvuvc64.sys Wed Oct 07 04:28:44 2009
Marvell 6G SATA Controller Marvell 91xx Confige Device Driver
->mv91cons.sys Tue Sep 22 17:36:37 2009
Realtek NDIS Protocol Driver
->RtNdPt60.sys Sun Jul 19 22:27:32 2009
2. If bsods are frequent, and I see you've had quite a few over the past few days, you may want to remove Symantec to replace it with BSOD-proof Microsoft Security Essentials:
Download and run the Norton Removal Tool to uninstall your Norton product | Norton Support
www.microsoft.com/security_essentials/
Attaching your most recent crash dump read + your current list of drivers:
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\011711-18688-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`0301f000 PsLoadedModuleList = 0xfffff800`0325ce50
Debug session time: Mon Jan 17 06:58:08.301 2011 (UTC - 5:00)
System Uptime: 0 days 0:01:45.706
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {fffff8a0040a703e, 2, 1, fffff80003375901}
Probably caused by : ntkrnlmp.exe ( nt!ObpQueryNameString+4ed )
Followup: MachineOwner
0: kd> !analyze -v
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffff8a0040a703e, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80003375901, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800032c70e0
 fffff8a0040a703e
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`03375901 668939          mov     word ptr [rcx],di
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  taskhost.exe
TRAP_FRAME:  fffff8800bbf7240 -- (.trap 0xfffff8800bbf7240)
rax=0000000000000020 rbx=0000000000000000 rcx=fffff8a0040a703e
rdx=fffff8a00000c930 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80003375901 rsp=fffff8800bbf73d0 rbp=fffff8800bbf7780
 r8=0000000000002000  r9=fffff8800bbf75d0 r10=0000000000000000
r11=00000000000001c8 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz ac pe nc
nt!ObpQueryNameString+0x4ed:
fffff800`03375901 668939          mov     word ptr [rcx],di ds:28b0:fffff8a0`040a703e=????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff8000308eca9 to fffff8000308f740
STACK_TEXT:
fffff880`0bbf70f8 fffff800`0308eca9 : 00000000`0000000a fffff8a0`040a703e 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`0bbf7100 fffff800`0308d920 : 00000000`00000000 fffffa80`081e4c80 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`0bbf7240 fffff800`03375901 : fffff880`0bbf7780 fffff8a0`0000c950 00000000`00000001 fffffa80`0aeb1000 : nt!KiPageFault+0x260
fffff880`0bbf73d0 fffff800`0337656a : fffffa80`081e4cd0 fffff8a0`040a7000 fffffa80`00002000 fffff880`0bbf75d0 : nt!ObpQueryNameString+0x4ed
fffff880`0bbf74d0 fffff800`03375ecf : fffff880`0bbf7798 fffffa80`09862360 fffff8a0`20206f49 00000000`00000001 : nt!ObQueryNameString+0xe
fffff880`0bbf7510 fffff800`03376612 : fffffa80`09862360 fffff960`00401802 00000000`00000000 fffffa80`0aeb1000 : nt!IopQueryNameInternal+0x9f
fffff880`0bbf75b0 fffff800`033754c4 : 00000000`00000000 fffff800`00401802 00000000`00000000 fffffa80`0aeb1000 : nt!IopQueryName+0x26
fffff880`0bbf7600 fffff800`032eada3 : fffffa80`09862360 fffffa80`0aeb1000 fffff8a0`00002000 fffff880`0bbf7798 : nt!ObpQueryNameString+0xb0
fffff880`0bbf7700 fffff800`0334c43e : fffffa80`0a235810 00000000`00000000 fffffa80`09ed5b60 00000000`00000001 : nt! ?? ::NNGAKEGL::`string'+0x210a4
fffff880`0bbf78a0 fffff800`03374cd4 : 000007ff`fffda000 fffff880`0bbf7c20 00000000`00000000 fffffa80`09d5d090 : nt!PspExitProcess+0x4e
fffff880`0bbf7900 fffff800`0334d635 : 00000000`00000000 fffffa80`09ed5b01 000007ff`fffda000 00000000`00000000 : nt!PspExitThread+0x834
fffff880`0bbf79c0 fffff800`0306c1db : 00000000`00000000 00000000`00000000 fffffa80`09ed5230 00000000`00000000 : nt!PsExitSpecialApc+0x1d
fffff880`0bbf79f0 fffff800`0306c620 : 00000000`002d7270 fffff880`0bbf7a70 fffff800`0334d74c 00000000`00000001 : nt!KiDeliverApc+0x2eb
fffff880`0bbf7a70 fffff800`0308ea37 : ffffffff`ffffffff 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInitiateUserApc+0x70
fffff880`0bbf7bb0 00000000`776efdba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
00000000`00cff508 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x776efdba
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!ObpQueryNameString+4ed
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0xA_nt!ObpQueryNameString+4ed
Drivers:
fffff880`00e00000 fffff880`00e57000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02f06000 fffff880`02f90000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04057000 fffff880`0406d000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0118c000 fffff880`01197000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`043e3000 fffff880`043eb000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`0114e000 fffff880`01157000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01157000 fffff880`01181000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00900000 fffff960`00961000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`01a99000 fffff880`01aa0000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`042f6000 fffff880`043e3000   BHDrvx64 BHDrvx64.sys Mon Nov 15 18:11:35 2010 (4CE1BE27)
fffff880`042e5000 fffff880`042f6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`069bd000 fffff880`069db000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`04249000 fffff880`042e5000   ccHPx64  ccHPx64.sys  Fri Feb 05 16:05:45 2010 (4B6C8829)
fffff960`00640000 fffff960`00667000   cdd      cdd.dll      unavailable (00000000)
fffff880`01a66000 fffff880`01a90000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00e5e000 fffff880`00f1e000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01a00000 fffff880`01a30000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d02000 fffff880`00d60000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01200000 fffff880`01273000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`043eb000 fffff880`043fb000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0279b000 fffff880`027a9000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`041d8000 fffff880`041f6000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`041c9000 fffff880`041d8000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01bc5000 fffff880`01bdb000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`068e4000 fffff880`06906000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`027b5000 fffff880`027be000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`027a9000 fffff880`027b5000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`027be000 fffff880`027d1000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`027d1000 fffff880`027dd000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`044f7000 fffff880`045eb000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04400000 fffff880`04446000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`04153000 fffff880`041c9000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`0131b000 fffff880`0132f000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01197000 fffff880`011e3000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01411000 fffff880`0141b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b8b000 fffff880`01bc5000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01789000 fffff880`017d3000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`045eb000 fffff880`045f8000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`035fb000 fffff800`03644000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04446000 fffff880`0446a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0690c000 fffff880`06968000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`02731000 fffff880`0274a000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0274a000 fffff880`02752080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`02723000 fffff880`02731000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`06800000 fffff880`068c8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01b82000 fffff880`01b8b000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`01030000 fffff880`0114e000   iaStorV  iaStorV.sys  Wed Apr 08 12:57:17 2009 (49DCD76D)
fffff880`040d8000 fffff880`04153000   IDSvia64 IDSvia64.sys Fri Nov 05 17:13:11 2010 (4CD47367)
fffff880`04226000 fffff880`0423c000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`013c8000 fffff880`013ef000   Ironx64  Ironx64.SYS  Tue Apr 27 20:48:23 2010 (4BD785D7)
fffff880`046f7000 fffff880`04706000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0276c000 fffff880`0277a000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00b9e000 fffff800`00ba1000   kdcom    kdcom.dll    Tue Nov 30 09:40:39 2010 (4CF50CE7)
fffff880`04717000 fffff880`0475a000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`015db000 fffff880`015f5000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0175e000 fffff880`01789000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06906000 fffff880`0690b200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02757000 fffff880`0276c000   LHidFilt LHidFilt.Sys Thu Mar 18 04:51:17 2010 (4BA1E985)
fffff880`02044000 fffff880`02059000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02787000 fffff880`0279b000   LMouFilt LMouFilt.Sys Thu Mar 18 04:51:24 2010 (4BA1E98C)
fffff880`02000000 fffff880`02023000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`0b518000 fffff880`0b522000   LVPr2M64 LVPr2M64.sys Wed Oct 07 04:26:50 2009 (4ACC50CA)
fffff880`026c1000 fffff880`0270f600   lvrs64   lvrs64.sys   Wed Oct 07 04:27:59 2009 (4ACC510F)
fffff880`02092000 fffff880`026a5d00   lvuvc64  lvuvc64.sys  Wed Oct 07 04:28:44 2009 (4ACC513C)
fffff880`00caa000 fffff880`00cee000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`027dd000 fffff880`027eb000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04706000 fffff880`04715000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0277a000 fffff880`02787000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c76000 fffff880`00c90000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`069db000 fffff880`069f3000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`01a30000 fffff880`01a5d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0aa34000 fffff880`0aa82000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0aa82000 fffff880`0aaa5000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01181000 fffff880`0118c000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`017d3000 fffff880`017de000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fda000 fffff880`00fe4000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0136a000 fffff880`013c8000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`040cd000 fffff880`040d8000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b70000 fffff880`01b82000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`00c6c000 fffff880`00c76000   mv91cons mv91cons.sys Tue Sep 22 17:36:37 2009 (4AB94365)
fffff880`0160c000 fffff880`016fe000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`055f2000 fffff880`055fe000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04672000 fffff880`046a1000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`047dd000 fffff880`047f2000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02e26000 fffff880`02e35000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02f90000 fffff880`02fd5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`016fe000 fffff880`0175e000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`017de000 fffff880`017ef000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`040c1000 fffff880`040cd000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0301f000 fffff800`035fb000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01438000 fffff880`015db000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01a90000 fffff880`01a99000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`047c6000 fffff880`047dd000   nusb3hub nusb3hub.sys Mon Oct 26 10:19:44 2009 (4AE5B000)
fffff880`01000000 fffff880`0102f000   nusb3xhc nusb3xhc.sys Mon Oct 26 10:19:48 2009 (4AE5B004)
fffff880`055f0000 fffff880`055f1180   nvBridge nvBridge.kmd Sat Jul 31 09:41:19 2010 (4C5427FF)
fffff880`04600000 fffff880`04623000   nvhda64v nvhda64v.sys Mon Jun 21 18:07:25 2010 (4C1FE29D)
fffff880`04a0d000 fffff880`055ef980   nvlddmkm nvlddmkm.sys Sat Jul 31 09:43:08 2010 (4C54286C)
fffff880`02e00000 fffff880`02e26000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`011e3000 fffff880`01200000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00d93000 fffff880`00da8000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d60000 fffff880`00d93000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00ff1000 fffff880`00ff8000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01411000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0aaa5000 fffff880`0ab4b000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`02059000 fffff880`02065000   pnarp    pnarp.sys    Sat Jun 06 02:06:44 2009 (4A2A0774)
fffff880`04623000 fffff880`04660000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cee000 fffff880`00d02000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`02065000 fffff880`02071000   purendis purendis.sys Sat Jun 06 00:32:06 2009 (4A29F146)
fffff880`00dbd000 fffff880`00de1000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`046a1000 fffff880`046bc000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`046bc000 fffff880`046dd000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`046dd000 fffff880`046f7000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04070000 fffff880`040c1000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01beb000 fffff880`01bf4000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01bf4000 fffff880`01bfd000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01ad3000 fffff880`01adc000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01b36000 fffff880`01b70000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02071000 fffff880`02089000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04000000 fffff880`04057000   Rt64win7 Rt64win7.sys Thu Mar 04 08:42:52 2010 (4B8FB8DC)
fffff880`027eb000 fffff880`027f7000   RtNdPt60 RtNdPt60.sys Sun Jul 19 22:27:32 2009 (4A63D614)
fffff880`0ab4b000 fffff880`0ab56000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`044e0000 fffff880`044ec000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02e35000 fffff880`02e52000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01b2e000 fffff880`01b36000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01291000 fffff880`012a5000   SRTSPX64 SRTSPX64.SYS Wed Feb 24 18:59:48 2010 (4B85BD74)
fffff880`0b482000 fffff880`0b518000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0ab95000 fffff880`0abfc000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`0ab56000 fffff880`0ab83000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04715000 fffff880`04716480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`012ad000 fffff880`0131b000   SYMDS64  SYMDS64.SYS  Mon Aug 17 19:35:30 2009 (4A89E942)
fffff880`0132f000 fffff880`0136a000   SYMEFA64 SYMEFA64.SYS Wed Apr 21 17:47:39 2010 (4BCF727B)
fffff880`02ed0000 fffff880`02f06000   SYMEVENT64x86 SYMEVENT64x86.SYS Thu Aug 13 18:28:21 2009 (4A849385)
fffff880`02e5a000 fffff880`02ed0000   SYMTDIV  SYMTDIV.SYS  Tue May 04 00:38:27 2010 (4BDFA4C3)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0ab83000 fffff880`0ab95000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02710000 fffff880`02723000   tcusb    tcusb.sys    Thu Jul 23 19:11:04 2009 (4A68EE08)
fffff880`017ef000 fffff880`017fc000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01273000 fffff880`01291000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`0141b000 fffff880`0142f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005a0000 fffff960`005aa000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04200000 fffff880`04226000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0475a000 fffff880`0476c000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`026a6000 fffff880`026c0c00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06968000 fffff880`06985000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`044de000 fffff880`044dff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`044cd000 fffff880`044de000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0476c000 fffff880`047c6000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04477000 fffff880`044cd000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06996000 fffff880`069a2000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`06985000 fffff880`06996000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`069a2000 fffff880`069bd000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`0446a000 fffff880`04477000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fe4000 fffff880`00ff1000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01aa0000 fffff880`01aae000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01aae000 fffff880`01ad3000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00da8000 fffff880`00dbd000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01ae2000 fffff880`01b2e000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02fde000 fffff880`02ff9000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01bdb000 fffff880`01beb000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`02753000 fffff880`02756880   wdcsam   wdcsam.sys   Wed Apr 16 04:39:08 2008 (4805BB2C)
fffff880`00f1e000 fffff880`00fc2000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00fc2000 fffff880`00fd1000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02fd5000 fffff880`02fde000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`00fd1000 fffff880`00fda000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02023000 fffff880`02044000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`0b522000 fffff880`0b553000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`01a30000 fffff880`01a3e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01a3e000 fffff880`01a4a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01a4a000 fffff880`01a53000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01a53000 fffff880`01a66000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Thanks i will try updating those
then if i still get BSOD i'll try the different security
well what ever i installed didn't work now win7 won't even load :s
i guess i'll rip it apart and try to recover some data and format everything and start from scratch again
any idea why all of a sudden after several months of not missing a beat it goes and shits itself??
---> Old drivers, update them as soon as you reinstall the system:
Logitech Webcam
Use MSE.
If crashes reoccur, attach the newest crash dumps
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
#7
I would try last good known configuration and startup repair from 7 DVD.
#8
Also unplug WD External Storage.
#9
backup and running in normal mode for now with no problems as yet
i booted from win 7 disk and repaired and that has seemed to fix it as i don't think i properly updated the drivers you listed as i couldn't find them online anywhere
i've got my external hard drives and webcam unplugged currently and will try plugging them back in and see what happens
thanks for your help
#11
yep i've been to all those sites yesterday to look for what you said to update but i couldn't see anything i needed and i installed something that i thought was right from the marvell site and then i couldn't even get to safe mode after that so i won't be doing that again now that its running fine
i've done a check in my device manager and have gone through everything in there and all are up-to-date drivers except one which it updated
could i have got a virus and it effected some of the drivers to the all of a sudden start doing BSOD? because i was thiking back to what happened just before it BSODed and i had downloaded a dodgy file that same day
thanks jamie
#12
I doubt it was a virus, just Symantec doesn't like old drivers.
I can help you update those drivers but not all at once. First, let's do Marvell, go to Marvell: Support and choose your platform (OS) and Marvell ID number --> which you can find in windows device manager by right clicking on your Marvell device.
#13
ok done most of that but am stuck trying to find the marvell ID number
i've been through every part of the details tab but can't find a number that looks like the 88E#### in the drop down menu on the marvell site
#14
Ok, then what is the name of your Marvell as it appears in the device manager?
#15
sorry should of put that
it's "Marvell 91xx Config Device"
#16
Download these two drivers from your motherboard support site.
#17
That explains why i couldn't find them!
Ok i have done those now thanks
#18
Let's see what else we need to update,
Logitech Webcam
Logitech Support + Downloads
WD Support / Downloads / Select Product
